Hi… Now it kind of works… a couple of queues are working alright while the others still doesn’t work.
Only queues number 1 and number 12 are working… but all queues have similar rules. The only thing that is different are IP addresses and bandwidth limit.
EDIT: Queue 14 also works.
[admin@CAPUAVA1] > /queue simple print
0 name=“Modelarte - 2Mb” target=XXX.38.23.139/32 parent=none packet-marks=“”
priority=8/8 queue=default-small/default-small limit-at=0/0
max-limit=2M/2M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
1 name=“Vertas - 2Mb” target=XXX.38.23.193/32 parent=none packet-marks=“”
2 name=“Primotec - 512k” target=XXX.38.23.243/32 parent=none packet-marks=“”
max-limit=512k/512k burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
3 name=“Estapostes - 1Mb” target=XXX.38.23.119/32 parent=none packet-marks=">
max-limit=1M/1M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
4 name=“Primework 1 (Walmart) - 2Mb” target=XXX.38.23.77/32 parent=none
packet-marks=“” priority=8/8 queue=default-small/default-small
limit-at=0/0 max-limit=2M/2M burst-limit=0/0 burst-threshold=0/0
burst-time=0s/0s
5 name=“Sipra - 2Mb” target=XXX.38.23.164/32 parent=none packet-marks=“”
6 name=“Premold - 1Mb” target=XXX.38.23.222/32 parent=none packet-marks=“”
7 name=“TCM - 1Mb” target=XXX.38.23.97/32 parent=none packet-marks=“”
8 name=“NSEquipamentos - 512k” target=XXX.38.23.92/32 parent=none
limit-at=0/0 max-limit=512k/512k burst-limit=0/0 burst-threshold=0/0
burst-time=0s/0s
9 name=“Coremil - 1Mb” target=XXX.38.23.50/32 parent=none packet-marks=“”
10 name=“Incopel - 2Mb” target=XXX.38.23.182/32 parent=none packet-marks=“”
11 name=“Ajofer - 4Mb” target=XXX.38.23.86/32 parent=none packet-marks=“”
max-limit=4M/4M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
12 name=“Houghton - 6Mb” target=XXX.38.24.234/32 parent=none packet-marks=“”
max-limit=6M/6M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
13 name=“Tora Transportes - 1Mb” target=XXX.38.23.33/32 parent=none
limit-at=0/0 max-limit=1M/1M burst-limit=0/0 burst-threshold=0/0
burst-time=0s/0s
14 name=“Poli Positivo - 2Mb” target=XXX.38.23.56/32 parent=none
burst-time=0s/0s
15 name=“CGE - 512k” target=XXX.38.23.249/32 parent=none packet-marks=“”
I also don’t understand why the option /interface bridge settings set use-ip-firewall=yes is not present on Winbox interface…
Thanks for your help man!
