I’m moving from v6 to v7 on some CCRs and the thing that really got me was the moving of OSPF static route redistribution type and cost settings out of the OSPF instance and into filter rules.
This page has some examples but doesn’t show setting OSPF cost or type:
https://help.mikrotik.com/docs/display/ROS/Moving+from+ROSv6+to+v7+with+examples
Thankfully I found what I needed several posts down on this thread
http://forum.mikrotik.com/t/help-needed-with-routing-filters-v7/151496/1
Yes I did find this page:
https://help.mikrotik.com/docs/display/ROS/Route+Selection+and+Filters
..but it does take some time to wade through and piece it all together, and then be not entirely sure you’ve got it right.. Considering that the migration script missed all my static route redistribution cost and type setting, I think MKT should really flesh out the “Moving from ROSv6 to v7 with examples” with a lot more filter examples. It really skimps on this! Since setting OSPF static route cost and type is really common, it would be very beneficial if MKT put that in as an example on the “Moving from ROSv6 to v7 with examples” page as I’m sure it would help a whole load of people.
