V6 v7 universal health report to local/global variable list
Please help! I always get stuck.
I know Jotne’s health report solution, which also works for Mikrotik routerOs v6 and V7.
:do {
New version
:foreach id in=[/system health find] do={
:local health “$[/system health get $id]”
:set ( “$health”->“script” ) “health”
:log info message=“$health”
} on-error={
Old version
:if (!([/system health get]~“(state=disabled|^$)”)) do={
:local health “$[/system health get]”
My problem is that I want to store the values ​​read by the script in variables.
That is, I want to use a script for both V6 and V7.
How can the output of the above commands be split up and stored in a single variable?
What I’m looking for the solution the most is version 7. Although I know how to ask for all possible values ​​one by one, but if, for example, the PSU1 FAN does not exist, the script stops with an error.
like:
set healthfan1speed “[/system health get value-name=fan1-speed]”;
When I run it like this in V7 routerOS, this is the output, correctly:
 :local voltage [/system/health get [find where name=voltage] value]
 :put $voltage
# :local cputemp [/system/health get [find where name=cpu-temperature] value]
 :put $cputemp
 :local temp [/system/health get [find where name=temperature] value]
 :put $temp
:log info "Value_1: $voltage"
:log info "Value_2: $cputemp"
:log info "Value_3 : $temp"
Output:
09:09:10 script,info Value_1: 23.9
09:09:10 script,info Value_2:
09:09:10 script,info Value_3 : 31
But if I remove the # ( :local cputemp…) , the script doesn’t run.
 :put $voltage
 :put $cputemp
 :put $temp
There is no cpu-temperature health information collection on the device, so it may stop due to an error. How can this error be avoided?
Thanks.
Hi!
An alternative script for universal status report:
https://forummikrotik.ru/viewtopic.php?p=91302#p91302
https://github.com/drpioneer/MikrotikHealth/blob/main/health.rsc
