V7.0.3 Routing
Hi all,
Just bought D53G-5HacD2HnD (Chateau series) LTE Router and I really love it, speed over LTE with mANT LTE antenna is more than great. Now trying to get GRE tunnel working on it, but it seems that there is some changes in routing rules, could anyone explain what I did wrong? Used this TUT https://help.mikrotik.com/docs/display/ROS/GRE
Anyone guys?
Do an /export hide-sensitive and post here (remember to clean out stuff you don’t want on internet.
Actually it`s default config, with custom dhcp and GRE tunnel
add admin-mac=2C:C8:1B:CE:03:87 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-CE038C wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    MikroTik-CE038D wireless-protocol=802.11
/interface gre
add allow-fast-path=no local-address=***.***.***.*** name=EimantasNamaiTEST \
    remote-address=***.***.***.***
add allow-fast-path=no local-address=***.***.***.*** name=Sandelis<->HeadOffice \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=static.tele2.lt ip-type=ipv4
/interface lte
set [ find ] allow-roaming=no apn-profiles=static.tele2.lt name=lte1
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.2.10-192.168.2.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
/interface lte settings
set external-antenna=both
add address=192.168.2.254/24 comment=defconf interface=bridge network=\
    192.168.2.0
add address=172.16.2.1/30 interface=Sandelis<->HeadOffice network=172.16.2.0
add address=172.16.1.2/30 interface=EimantasNamaiTEST network=172.16.1.0
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.254 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.2.254 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=172.16.2.2@main \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=yes distance=1 dst-address=192.168.1.0/24 gateway=172.16.1.1 \
    target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/routing rule
add action=lookup-only-in-table disabled=no src-address=172.16.1.0/30 table=\
    main
/system clock
set time-zone-name=Europe/Vilnius
/system routerboard settings
set cpu-frequency=auto
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=LA
Any clues?
Tested on beta, seems that the GRE interface is not running when keepalive is active.
Disabling keepalive on the GRE interface enables the routes.
Note that ROSv7 is still in beta; 7.0.3 is a one-time-build for Chateau but can still contain bugs.
But my config says:
/interface gre
add [b]allow-fast-path=no[/b] local-address=***.***.***.*** name=EimantasNamaiTEST \
add [b]allow-fast-path=no[/b] local-address=***.***.***.*** name=Sandelis<->HeadOffice \
But.. have you tried disabling keepalive?
The /interface gre lines should show this: !keepalive
You can set that via commandline, or in winbox you need to collapse the keepalive setting.
Oh, been late when written my reply, really, turned off keepalive and magic happened. Thank you guys!
Keepalive is fixed in 7.1rc1
This topic is from someone running the stock 7.0.3 on a D53G-5HacD2HnD (Chateau series) LTE Router.
Would you advise him to upgrade to 7.1rc1 ?
Yes, 7.1rc with the latest fixes is better than 7.0.3
Thank you very much, I`ll try to upgrade
