v7.0Beta4 userman does not show up
I installed 7b4 and the user-manager package.
It shows as installed in the log and the system–>package list (also installed the other packages LCD, Calea etc these work without problems).
There is no command in the CLI under tool and no response to calling via http.
Am i missing something?
this is on a RB2011UiAS
/user-manager set enabled=yes
http://xxx.xxx.xxx.xxx/um
but I not found how to call adim web interface…
CLI control for UserManager is moved from “/tools user-manager” to its own menu “/user-manager”. The Admin panel that was used in the previous UserManager version (“/userman”) is no longer active due to changes in UserManager behaviour in version 7.
There is a client-portal that is available at “/um” and can be used to process client payments and profile upgrades (for instance if a user wants higher bandwidth/data cap).
From ver. 7 must be all administrated from CLI without web interface as before?
Ok,
what is the default userman user/password..
how about a quick rundown on changes.. it looks like everything is done via CLI now?
There is not admin interface…???
You must first create one user for open /um web
/user-manager user add name=test password=test
Hopefully it will get nice and friendly UI in WinBox, like the rest of RouterOS.
Anybody set up usermanager5 for ROS auth success?
Is it now (or will it now become) a useful RADIUS server for other scenarios than HOTSPOT?
(e.g. port authentication, WPA2-EAP, etc)
Ok great!
