v7.10, 7.10.1 and more [stable] are released!
had that issue on VPLS links also in the past when the underlying connection went down but came back up again but only a disable/enable re-established VPLS links.
haven’t had a fix for that either than netwatch+script
:warning:Security Issue: Changing rights / disable / delete the users has no effect on already logged in users. [Tested on 6.48.7 and 7.10.2]
http://forum.mikrotik.com/t/security-issue-changing-rights-disable-delete-the-users-has-no-effect-on-already-logged-in-users/168574/1
I have an installation with CRS125 + CSS326 + 260 with a lot of vlans.
After installation of this Version a lot of problems with the css326 + 260.
After downgrade to Long Term 6 all is ok…why ?
@spippan I have no issues with the VPLS link reconnecting, my issue is that the wireless starts saying “SA Query timed out”
And sure enough, it just happened on the new AP. But it fixed after disabling the wireless card for around 3 minutes.
Sadly this level of inconsistent wireless availability and low realiability makes the wireless unuseable on the ax2 on the 7.10.x release.
I am eager to try it on 7.11 as soon as it is released on stable :slight_smile:
Wow, according to some, caveat - ‘opinion with bias’, version 7 has been stable for a long time. No definition of long provided → ?4 inches?
quote ( Bearded Viking Imposter! ):
“Since RouterOS v7 is stable for a long time, there is no use to keep separating discussions. Please use the forum sections according to feature, not version. If a topic you started is behind “locked”, sorry, try to continue the discussion in another section. There was no way to lock only new posts, without locking old ones.
As always, please report reproducable bugs to support@mikrotik.com regardless of the version. Forum is for discussions until you are sure it’s a bug. When you are sure, report to MikroTik directly, not in the forum. Forum, as it always was, is for user to user discussion and speculation. Not for reporting bugs to MikroTik.
Thank you.”
I encountered this problem several days ago.
After I downgraded to 7.92, the function “enable-ssl-certificate dns-name=01.abc.xyz,02.abc.xyz,03.abc.xyz” became normal.
RouterOS v7.11 has been released
http://forum.mikrotik.com/t/v7-11-2-stable-is-released/168778/1
