v7.10 hAP ax³ wifi key handshake timeout
Hello, I have updated the software version to the current version, I am still having problems connecting to wifi.
Log: wifi disconnected, key handshake timeout, signal strength…
MikroTik RouterOS 7.10 (c) 1999-2023       https://www.mikrotik.com/
[admin@MikroTik] /interface/wifiwave2> print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
 0 M BR default-name="wifi2" name="wifi_2.4ghz" mac-address=48:A9:8A:78:6D:46 arp-timeout=auto radio-mac=48:A9:8A:78:6D:46
        configuration.mode=ap .ssid="Promets"
        security.authentication-types=wpa2-psk,wpa3-psk .passphrase="*******"
        channel.frequency=2447 .band=2ghz-ax .width=20/40mhz
 1 M B  default-name="wifi1" name="wifi_5ghz" mac-address=48:A9:8A:78:6D:45 arp-timeout=auto radio-mac=48:A9:8A:78:6D:45
        configuration.mode=ap .ssid="Promet_5ghz"
        security.authentication-types=wpa2-psk,wpa3-psk .encryption="" .passphrase="*********"
        channel.frequency=5220 .band=5ghz-ax .width=20/40/80mhz
I am having a similar issue with an hAP ax3 with a similar configuration (shocking!). Hoping someone can provide some insight into this issue.
EDIT: Rebooted the hAP ax3 and it is working now. Let’s see how long this lasts.
I have the same problem
Quite a bit of AX issues have been fixed with 7.11 beta version.
Or downgrade to 7.8 stable, it seems most of the issues started with 7.9 version.
