For me the wifi performance is excellent, with hap ax3 I exceed with speedtest 790 Mbps
No buffering problem with smartphones
Hello. Hap ax2 working as CAP powered via POE repeatedly connects and disconnects from LAN/CAPSMAN (port flapping?)- interval 10-60s.
Downgraded to 7.10, no issue since, stable as before.
Hi, is here anyone who had situation wit this beta? Anyone could not join WiFi on this beta? My AX3 is ok at the moment but sometimes it takes me few days to get this error.
Thank you
Is only out since Thursday.
No problem for now, everything is working like it should, at least for me.
I tried iperf3 test, im geting 450-620 Mbps on ax2, i tested with ubiquiti u6 lite and im getting 378-470Mbps max.
Good to know that ax from Mikrotik can beat simple ax from ubiquity
Yea, but i can’t get 800 Mbps that @holvoetn mention.
What device do you use to test ?
My laptop with Intel wifi card can’t get it either. It can’t do wifi6.
But using usb tplink ax adapter, it does.
And again, can not stress it enough, do make sure the used channel is clear for your usage.
3 parts when testing.
Device A
Device B
Medium in between
Intel AX200, AP is ax2 and server is on container on ax3, channel is clear.
When you test, what’s the CPU usage on AX3 or AX2 ?
If one of the cores is at 100%, that’s your bottleneck.
EDIT: just checked when doing iperf from PC wired to AX3, 2.5Gb trunk to RB5009-container. CPU is around 49% on RB5009, below 20% on AX3, results (as expected) around 950-960Mbps.
Towards RB5009.
Which is way more powerful then AX3.
So I am going to guess you have a bottleneck on AX3 when running that container.
Pick the bones out of this hAP ax2 5500Ceee
Speedtest from rpi4 through router to pc (primitve but hey!)
Singlethread
iperf3 -c 192.168.0.135
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-10.00 sec 719 MBytes 603 Mbits/sec 271 sender
[ 5] 0.00-10.00 sec 717 MBytes 601 Mbits/sec receiver
iperf3 -c 192.168.0.135 -R
[ 5] 0.00-10.00 sec 418 MBytes 351 Mbits/sec sender
[ 5] 0.00-10.00 sec 416 MBytes 349 Mbits/sec receiver
Multithread
iperf3 -c 192.168.0.135 -P 10 -b 1000M
[SUM] 0.00-10.00 sec 961 MBytes 806 Mbits/sec 81 sender
[SUM] 0.00-10.01 sec 946 MBytes 793 Mbits/sec receiver
iperf3 -c 192.168.0.135 -P 10 -b 1000M -R
[SUM] 0.00-10.01 sec 710 MBytes 595 Mbits/sec sender
[SUM] 0.00-10.00 sec 707 MBytes 593 Mbits/sec receiverWiFi hAP ax2 CLI to PC btest.exe running server
tool/speed-test address=192.168.0.135
status: udp download
time-remaining: 19s
ping-min-avg-max: 1.78ms / 2.64ms / 5.14ms
jitter-min-avg-max: 3us / 409us / 2.81ms
loss: 0% (0/200)
tcp-download: 739Mbps local-cpu-load:66%
tcp-upload: 916Mbps local-cpu-load:41% remote-cpu-load:1%Ethernet/usb test pi to pc
forward singlethread also primitive usb setup/adapter
[ 5] 0.00-10.00 sec 1.07 GBytes 916 Mbits/sec sender
[ 5] 0.00-10.00 sec 1.06 GBytes 912 Mbits/sec receiverreverse singlethread
[ 5] 0.00-10.00 sec 1.06 GBytes 912 Mbits/sec receiverEdit: Forgive me I mixed up the last two tests, here they are in full
Server listening on 5201 (test #7)
Accepted connection from 192.168.0.8, port 45268
[ 5] local 192.168.0.135 port 5201 connected to 192.168.0.8 port 45270
[ 5] 0.00-1.00 sec 111 MBytes 931 Mbits/sec
[ 5] 1.00-2.00 sec 112 MBytes 941 Mbits/sec
[ 5] 2.00-3.00 sec 111 MBytes 933 Mbits/sec
[ 5] 3.00-4.00 sec 107 MBytes 899 Mbits/sec
[ 5] 4.00-5.00 sec 112 MBytes 941 Mbits/sec
[ 5] 5.00-6.00 sec 108 MBytes 909 Mbits/sec
[ 5] 6.00-7.00 sec 109 MBytes 913 Mbits/sec
[ 5] 7.00-8.00 sec 111 MBytes 933 Mbits/sec
[ 5] 8.00-9.00 sec 106 MBytes 890 Mbits/sec
[ 5] 9.00-10.00 sec 103 MBytes 866 Mbits/sec
[ 5] 0.00-10.00 sec 1.07 GBytes 916 Mbits/sec senderServer listening on 5201 (test #8)
Accepted connection from 192.168.0.8, port 45272
[ 5] local 192.168.0.135 port 5201 connected to 192.168.0.8 port 45274
[ 5] 0.00-1.00 sec 112 MBytes 939 Mbits/sec
[ 5] 1.00-2.00 sec 111 MBytes 928 Mbits/sec
[ 5] 2.00-3.00 sec 112 MBytes 940 Mbits/sec
[ 5] 3.00-4.00 sec 112 MBytes 939 Mbits/sec
[ 5] 5.00-6.00 sec 112 MBytes 941 Mbits/sec
[ 5] 6.00-7.00 sec 112 MBytes 941 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 940 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 939 Mbits/sec
[ 5] 9.00-10.00 sec 112 MBytes 940 Mbits/sec
[ 5] 10.00-10.00 sec 325 KBytes 874 Mbits/sec
[ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver
On ax2 I get max CPU usage on core 1, 51%, on ax3 same core, 33%
Push it harder.. 20 streams
iperf3 -c -P 20 -t 50
About 50% all cores ax2 for me
I use at least -P 5, usually -P 10.
I tried with -P 5 and -P 10, same results, on wired connection i get 948 Mbps no problem. Maybe its just intel wifi card because with ubiquiti AP i get slower speeds
When your computer is connected via wifi, what does it show as data rate in wifi settings ? If not 1200/1200, you will never get 800mbps.
Does it show wifi6 ?
CMD prompt
netsh wlan show interface
Description : Intel(R) Wi-Fi 6 AX200 160MHz
GUID :
Physical address :
Interface type : Primary
State : connected
SSID : Mikrotik
BSSID :
Network type : Infrastructure
Radio type : 802.11ax
Authentication : WPA3-Personal (H2E)
Cipher : CCMP
Connection mode : Auto Connect
Band : 5 GHz
Channel : 144
Receive rate (Mbps) : 1201
Transmit rate (Mbps) : 1201
Signal : 93%
Profile : Mikrotik
I had reduced speed at channel 144 you know this already.
This is on auto settings, i will try to change it manually to 5500 MHz (ch100)
