Hello Everyone,
I am trying to evaluate ISIS CHR version 7.14.1 and have 2 items to review.
Setup :
Each MikroTik contain one VRF and bridge interface attached to VRF. Between two mikrotiks direct link. Also lo interfaces attached to same VRF ( EVE-NG lab )
Items:
- I can’t advertise loopbacks /32 only subnets I tried level 1 and level 2.
LSP
[admin@BL-RT-1] /routing/isis/interface-template> ../lsp/print
Flags: I - inactive
0 instance=isis-ins-1 level=l1 lsp-id="30ce.cdef.0001.00-00" age=978 checksum=0x3A24
sequence=0x4 body=
areas: 49310
nlpid: IP
is-reach:
30ce.cdef.0001.01 20
ip-reach:
172.30.100.0/28 20
ip-reach:
172.30.100.0/28 1
is-reach-ext:
ip-reach-ext:
172.30.100.0/28 20
172.30.100.0/28 1
1 instance=isis-ins-1 level=l1 lsp-id="30ce.cdef.0001.01-00" age=978 checksum=0xAD2
sequence=0x2 body=
is-reach:
30ce.cdef.0001.00 0
30de.cdef.0002.00 0
is-reach-ext:
30ce.cdef.0001.00 0
30de.cdef.0002.00 0
2 instance=isis-ins-1 level=l1 lsp-id="30de.cdef.0002.00-00" age=1005 checksum=0x73DA
sequence=0x3 body=
areas: 49310
nlpid: IP
is-reach:
ip-reach:
172.30.100.0/28 20
ip-reach:
172.30.100.0/28 1
is-reach-ext:
ip-reach-ext:
172.30.100.0/28 20
172.30.100.0/28 1
3 instance=isis-ins-1 level=l2 lsp-id="30ce.cdef.0001.00-00" age=1122 checksum=0xAF81
sequence=0x3 body=
areas: 49310
nlpid: IP
is-reach:
ip-reach:
172.30.100.0/28 20
172.30.100.0/28 21
ip-reach:
172.30.100.0/28 1
is-reach-ext:
ip-reach-ext:
172.30.100.0/28 20
172.30.100.0/28 21
172.30.100.0/28 1
4 instance=isis-ins-1 level=l2 lsp-id="30ce.cdef.0001.01-00" age=1122 checksum=0xECD
sequence=0x1 body=
is-reach:
30ce.cdef.0001.00 0
30de.cdef.0002.00 0
is-reach-ext:
30ce.cdef.0001.00 0
30de.cdef.0002.00 0
5 instance=isis-ins-1 level=l2 lsp-id="30de.cdef.0002.00-00" age=1149 checksum=0xE838
sequence=0x2 body=
areas: 49310
nlpid: IP
is-reach:
ip-reach:
172.30.100.0/28 20
172.30.100.0/28 21
ip-reach:
172.30.100.0/28 1
is-reach-ext:
ip-reach-ext:
172.30.100.0/28 20
172.30.100.0/28 21
172.30.100.0/28 1
/ip/route/print
Flags: D - DYNAMIC; I - INACTIVE, A - ACTIVE; c - CONNECT, i - IS-IS, d - DHCP; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAd 0.0.0.0/0 10.41.100.1 1
DAc 10.41.100.0/24 MGMT-V313-eth4 0
DAc 172.25.100.5/32 lo 0
DIiH 172.30.100.0/28 172.30.100.4%D-L2-br0 115
DAc 172.30.100.0/28 D-L2-br0@C-L2-DCI 0
[admin@BL-RT-1] /routing/isis/interface-template> ../instance/print
Flags: X - disabled, I - inactive
0 name="isis-ins-1" vrf=C-L2-DCI afi=ip system-id="30ce.cdef.0001" areas=49.3100
l1.redistribute=connected
l2.redistribute=connected
- ISIS received routes is not set under VRF route table only main.
[admin@BL-RT-1] /routing/isis/interface-template> /ip/route/print detail
Flags: D - dynamic; X - disabled, I - inactive, A - active;
c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn;
H - hw-offloaded; + - ecmp
DAd dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=10.41.100.1
immediate-gw=10.41.100.1%MGMT-V313-eth4 distance=1 scope=30 target-scope=10
vrf-interface=MGMT-V313-eth4 suppress-hw-offload=no
DAc dst-address=10.41.100.0/24 routing-table=main gateway=MGMT-V313-eth4
immediate-gw=MGMT-V313-eth4 distance=0 scope=10 suppress-hw-offload=no
local-address=10.41.100.144%MGMT-V313-eth4
DAc dst-address=172.25.100.5/32 routing-table=main gateway=lo immediate-gw=lo distance=0
scope=10 suppress-hw-offload=no local-address=172.25.100.5%lo
[b] DIiH dst-address=172.30.100.0/28 routing-table=main gateway=172.30.100.4%D-L2-br0
distance=115 scope=20 target-scope=10 suppress-hw-offload=no[/b]
DAc dst-address=172.30.100.0/28 routing-table=C-L2-DCI gateway=D-L2-br0@C-L2-DCI
immediate-gw=D-L2-br0 distance=0 scope=10 suppress-hw-offload=no
local-address=172.30.100.5%D-L2-br0@C-L2-DCI
