That’s a fair question: do the SMB server parts of ROSE bloating the routeros package, actually work without ROSE being installed… Geez, I’d like to think so… But dunno.
*) leds - added “dark-mode” functionality for hAP ax3 and Chateau ax series devices;
this is joke?
this is joke?
Strange.
My AX3 really shuts down ALL leds when I apply that setting, including the big blue one (finally !!).
But I’m still not sure what the blue led is for ![]()
EDIT: have to try 7.14b10. I see that AX3 is still on 7.14b8.
EDIT2: pfieuw, same result. All off.
this is joke?
Aren’t all those fields supposed to be enabled before you shut them off?
What’s new in 7.14beta10 (2024-Feb-06 15:47):
!) rose-storage - moved SMB service in the RouterOS bundle;
!) smb - removed legacy SMB service (replaced with newer and faster ROSE SMB service);
*) arp - added ARP status;
*) console - improved stability when using autocomplete with “export”;
*) defconf - fixed configuration script on KNOT devices if “ppp-out” interface is removed;
*) defconf - fixed firewall rule for IPv6 UDP traceroute;
*) dhcpv6-client - updated error logging when multiple prefixes received on renew;
*) disk - added global disk “settings” menu (CLI only);
*) l3hw - fixed IPv6 host offloading in certain cases;
*) package - added “size” property;
*) poe-out - improved 802.3at classification and measurement accuracy;
*) poe-out - improved cable test for hAP ac3 and hAP ax3 devices;
*) ptp - added “aes67” and “smpte” profiles;
*) ptp - added configurable “domain” and “priority2” parameters;
*) ptp - added support for Management message forwarding in BC;
*) route - fixed gateways of locally imported vpnv4 routes;
*) route-filter - fixed AS path matchers when input and output chains are used;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on CCR2004-16G-2S+ in rare cases;
*) smb - added option to specify SMB service mode as “auto”;
*) supout - added PTP section;
*) system - expose “lo” and “vrf” interfaces;
unfortunately no BGP/VRF local route leaking updates…
On beta 8
*) bgp - allow to leak routes between local VRFs;
If you are looking for proper implementation through RD i don’t think it will happen today ![]()
this is joke?
I am pretty sure that’s the right answer. No joke.
unfortunately no BGP/VRF local route leaking updates...
Any chance of a Link for 7.14beta8 arm64 plus wifi-qcom I gotta roll back!
Edit: I got it…
its not working
It is working for me.
Create supout and contact support.
They should be able to shed some light on it ( oh no, wait, you don’t want light…sorry, couldnt resist)
You ALMOST got it. I think he wanted to shed some light FROM it…
Please bring IS-IS ipv6 ![]()
can you make photo in the dark with ax, please?
Before and after.
The dim blue light shows on the photo (slow shutter because of light conditions) but is not visible at all with naked eye.
Ports on the back are completely off.
Again, if it doesn’t work for you, contact support.
Are the ETH ports still flashing?
I’m trying to understand how this differs from simply scheduling:
/system leds settings set all-leds-off=immediate
Have you even tried?
Will this be addd for Hap ax2 as well ?
All my front leds stay on with this… /system leds settings set all-leds-off=immediate
I’d like to see this implemented for hap ax2 as well. Could get rid of that black tape…
Ofcourse not.
There is no changelog for IS-IS.
And still flaged as red here,
https://help.mikrotik.com/docs/display/ROS/Routing+Protocol+Overview
If its ready, at least tell us in changelog.
