clear, it is just added by default
Thx Amm0
also i’ve noticed that from time to time im not able to log on the the router , since i upgrade to v7.14, and reboot fixes it the issues
I’ve seen that too.
Ssh and romon will work though.
Mighty inconvenient !
Disable and enable winbox service helps, for a while.
Can confirm that, RB5009, ax3 same thing. They are shown in winbox but sometimes can’t connect to them without a reboot, after that works for a while.
Not necessarily, there are cases, where having multiple lo’s is completely valid usecase.
I guess for those usecases you can still use the existing workaround in RouterOS: a bridge without ports.
still is beta, as long as MT guys are aware of
I am with 7.14beta4 for 6 days now and there must be still any memory leak(-s). I have started with 150 MiB free memory and now I am bellow 100 Mib. Quite easy configuration with PPPoE xDSL, DHCP, DNS, WiFi, dualstack IPv6&4, BackToHome VPN and WireGuard but with QoS mangle marking and hierarchical Queue Tree. HW hAP ac^2 with (fortunately) 256 MiB memory.
@MikroTik staff. Yes, this is good news, this is a massive step forward in the industry (Yes, I am serious). But there’s a problem.
MikroTik RouterOS Linux queuing doesn’t support BQL:
- https://lwn.net/Articles/469652/
- https://www.bufferbloat.net/projects/bloat/wiki/BQL_enabled_drivers/
- http://forum.mikrotik.com/t/qos-hardware-offloading-qos-hw/166573/1
Artificial bufferbloat shows up in bufferbloat tests when we use fq_codel on MikroTik RouterOS on physical wired interfaces, the same problem doesn’t happen on Debian for example with BQL.
Solution for MikroTik:
Please add BQL support.
Once you add BQL support, we get performance boost (CPU usage will drop) + long-term viability of fq_codel for service provider networks and also enterprise.
Next step is industry adoption of fq_codel on ASICs, I don’t know if this is possible or not with Marvell ASICs though.
Regarding ECN, in my testing in production networks, leaving ECN marking enabled by default works better in the long run, assuming BQL is well-supported by the underlying platform. Overall, I would suggest leaving ECN enabled.
YES - please add BQL to MikroTik RouterOS.
pppoe server crash on x86 platform is still present.
ticket SUP-136050 updated with autosupout generated on crash of 7.14alpha155
Is 7.14aplpha155 newer than 7.14beta? If not the test should be run on 7.14beta.
If 7.14aplpha155 is newer than 7.14beta, then I do not understand Mikrotiks version naming, since alpha should come before beta.
Actually alpha and beta are built side by side, you can not tell which one is newer just by looking at the version number. The beta release are pushed to testing channel, alpha releases are for internal testing or are given to specific people for testing.
I am very curious as to observed bufferbloat at line (not shaped) rate with fq_codel on various mikrotik devices. I have generally assumed that at least some have BQL support already, but did find at least one that didn´t, and told mikrotik about the patch, as per your third link above. It is fairly straightforward to test for bloat with a lack of bql at line rate, just send data from two ports into an fq_codeled one with a bunch of iperfs or flent and measure the latency with ping. Anything greater than 1ms at 100mbit or 2ms at 1gbit line rates indicates an overlarge device ring that bql would otherwise be managing for you. flent´s rtt_fair_* tests will do this for you and generate a nice plot.
I generally assume that none of their wifi actually has any of the airtime-fairness patches? and would do badly on the rtt_fair test described here:
https://www.cs.kau.se/tohojo/airtime-fairness/
I had hoped that the principles in that wifi codebase would be being rigorously applied not just to wifi, but to multiple p2mp stacks by now, and far more folk publish results from that test suite.
I will repeat that getting BQL implemented in any given ethernet driver is about an afternoon´s work with the device in front of you. http://www.taht.net/~d/broadcom_aug9_2018.pdf and http://forum.mikrotik.com/t/bql-and-default-queue-lengths/158510/1 - you can see if your driver has it (if you have source) by grepping for netdev_sent_queue. You can monitor it with bqlmon, which is a nifty tool.
Some chips (like the mt76) have the ability to tie the shaper to BQL, and thus shape (egress-only), essentially in hardware.
Regarding airtimefairness patches:
The patch has been accepted into mainline Linux (along with Felix Fietkau’s follow-up fix for a power save-related crash bug) and was released as part of Linux 4.11. The code is also in the LEDE project firmware from version 17.01.
ROS uses Kernel 5.x IIRC. So these patches should be in ROS?
Not necessarily if you compile Kernel yourself, you have “options”… ![]()
In many cases people are still using the factory, out of tree, wifi device driver supplied by the manufacturer, and their UI tightly tied to those APIs. Some of the factory drivers have features that are needed, also, like txop reduction in the beacon. We tried to make all the wifi manufacturers aware of https://www.cs.kau.se/tohojo/airtime-fairness/ back in 2016 in the hope they would improve their factory drivers also. Codel and fq_codel were breakthroughs in packet theory, and few to this day understand them. A lot of time I just rely on competition for the vendors to upgrade…
It was fun, recently, to demo to ubnt´s CEO how much better we made one of their products: https://blog.cerowrt.org/post/fq-codel-unifi6/
Somewhere around my office are similar benchmarks for a couple mikrotiks (the hap ac-lite in particular), but the best I can do is just recommend that the main vendor pay attention, or their customers, reflash to openwrt, usually.
If mikrotik would like any help in at least getting BQL going, or our benchmark suite, or these newer wifi drivers, all they have to do is drop the make-wifi-fast team a line. We have an open mailing list, going back over a decade now, at lists.bufferbloat.net
I am very pleased overall with all the progress mikrotik updating routeros to version 7, and am willing to wait until they get it more right, and just kibitz as I do about adding 6 lines of great code here or there. In my world, linux kernel version 5.7 is totally obsolete and i am hoping most of all that they start a version 8 running linux 6.1 or later. Particularly our mt76 and mt79 drivers evolved a lot since even 6.1!
Offtopic here but: I tried OpenWRT on a Linksys WRT3200ACM with CAKE enabled. Connected my Mikrotik Chateau LTE12 on WAN-port (all ROS queues disabled). It did not perform any better and bufferbloat was still evident. Then I tried https://github.com/lynxthecat/cake-autorate and I did not know why, but with that cake-autorate enabled my LTE speeds dropped to like 5mbit down, 1mbit up. And i usually have varying 20-90mbit up and 10-25mbit up. Very disappointed by the OpenWRT defaults of CAKE and with cake-autorate addon even more. I really loved and used OpenWRT for many years, but my experience with the WRT3200ACM (and WRT1200 before) were really unstable and bogged (because I used a davidc502 custom builds) - compared to the stability of ROS and Chateau LTE12.
infabo, please make a new topic about bufferbloat and cake testing.
dtaht, thank you very much for your offer and continuous support on this forum. we will see what we can do and will let you know if we have any questions
MikroTik is probably the only network vendor on the planet that commercially uses the Linux kernel for the data plane, which means, they have good reason to keep up with the latest kernel tree/versions. But for some reason, they do not. Other vendors use Linux only on the control plane, data plane will be merchant silicon SDK or some custom code.
There’s always good reasons to use latest Kernel version for networking, one of the recent ones:
https://www.phoronix.com/news/Linux-6.8-Networking
