v7.16.2 [stable] is released!
powered by power supply or Poe?
PoE from a 4011.
Maybe device needs more power on load which 4011 can’t provide?
well, it was perfectly stable under 7.15.3, the only change i made recently was upgrading it to 7.16. but as i say i’ll do some more testing later today (when users went to sleep) and we’ll see.
Hi
We have updated all routers to 7.16 since Wednesday.
Now we have the problem that the routers hang up after a while and no longer allow connections. The only thing that helps is a restart.
Both CHR version and hardware such as RB5009UPr+S+.
Does anyone have the same problem?
i was able to reproduce the problem with iperf3: under wireless load (~500Mbps) the device would reboot every few minutes. downgrading to 7.15.3 fixed the problem.
reported as SUP-166456.
i submitted the supout for 7.15 and 7.16 to mikrotik support, its been a few days already and not heard anything back.
Right now its really unusuable when it keeps rebooting frequently not due to load or anything strenuous.
Are dns adlists still loaded to flash or already loaded to ram on this 7.16?
I understand that the name gives an idea, that something is wrong, but that is literally what it is. Any resistance detection device would show exactly the same. It can just be in that state forever without any risk of damage, overheating, etc.
There is no need for poe-out to be turned off, suggestion simply implied “hides status that I don’t like”.
Just because other vendors hide the state, does not mean they don’t measure the same. Hook up oscilloscope to any vendor PSE and you will see that detection is ran always, otherwise it is impossible for PSE to know → now turn on the power. For non-pd safety, resistance-detection is done with up to 10.1V and has a very small current-limit. Any PSE evaluation board would show you “short-circuit” against non-poe-devices in their resistance detection register, because as I mentioned, that is literally what physically is measured. What other vendors do is simply hide it, most likely checks that PoE-Out was not enabled, L2 link is on → no-pd capable device connected, or something like that
I agree that there is a room for improvement and we will be working on it. But all of it is just a “visual trick” and nothing else.
DNS-01 support for LE would be amazing. I’m not punching holes for port 80 from the world to internal gear but I already use DNS-01 to handle internal certificates for k8s. This is definitely the right path forward.
Removed. Not related to firmware.
Wifi signal strength is certainly affected (again) with 7.16. A lot of my home automation lights on 2.4ghz lost connectivity after the upgrade to 7.16 - after downgrade to 7.15.3 they are all connecting fine again. I recall when AX3 was launched all the complaints with weak wifi signal but Mikrotik in their usual denial said it was a configuration issue. Then around 7.13 they updated the driver and suddenly signal strength was much better. Up to 7.15.x signal strength has been fine but with 7.16 it seems this has changed once again. Crazy inconsistency with updates.
Updated device FW as well to 7.16 ?
Already 2 users with POE issues which were solved after performing FW upgrade as well.
yes. i don’t usually upgrade firmware but i noticed some firmware-related PoE issues with 7.16, so i upgraded firmware on both hAP ac2 and RB4011 to current 7.16. the problem still occurred.
Ok thanks for that info (and the other things in the reply)! I will keep the ports on “auto on”, I was only worried that it would be trying to put “passive PoE” on the port and detect the short circuit, possibly damaging something.
No, don’t have that problem. Routers (and memory usage) are stable.
These reports are not very useful when there is no information at all about how the routers are used.
Suspect areas include the DNS resolver. Remove your “adlist”, “doh” configuration, set a reasonable cache size (for the device memory) and see if it still occurs.
Some of these 3 changes (I would discard the DPD) is making after a while, several polycy stop working between a remote hexs and L009.
The polycy is “established” but traffic stops passing to the tunnel, with a Disable/enable of the Policy everything works again …
I have not suffered this in any 7.x.x. It is clearly a problem introduced in this version.
I just opened a support ticket, with 2 supout files, before and after enable/disable the policy manually.
Regards,
With my new Laptop and after upgrading my CAPax to 7.16, WIFI became unusable. It´s probably my new chipset being Intel 6E AX211. Signal is perfect, but lots of SA Query Timeouts.
I read the forum quite often, so I know I would probably need to go back to WPA2. But it´s 2024 and I don´t understand why I would need to do that. With other vendors, including my other setups built with TP Link Omadas, everything is working perfectly and I can just forget the installed APs apart from running updates sometimes. Currently using MT WIFI is an adventure to unfold, instead of a quiet ride, as it should be.
CRS210 Switch Menue broken via WebFIG?
It looks like one the ACL and FDBs menues work after the upgrade. The ones regarding VLAN don’t.
Also IGMP snooping only seems to be active on vlan 0, not on all vlan in use.
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Bridge_Hardware_Offloading Ok, that is a chip hardware limitation I guess.
Yesterday I updated my hAP ac3, then my ATL. Since then, I can’t connect to the ATL at all:
http://forum.mikrotik.com/t/trouble-cant-connect-to-atl-after-update/178987/3
I really hope someone can help.
This is a critical situation and quite strange for a stable release.
