usually, from time to time, connect to the remote router via wireguard vpn
looking for log file, new versions available...
aware that a new version is available, so I could upgrade from 7.18.2 (I think) to 7.19, great, normal procedure for years, never checked the change log.
/system/package/update/download
/system/package/update/install...
waiting for coming back for about two minutes, not switched off the wireguard client
no connection, vpn off and on again, no connection, returned after 10 minutes..., established wireguard tunnel
just started to check whether the devices behind the router could be connected, success.
ssh to the router, see above,
checked whether scp file download from router works (with a known filename), success.
no other actions performed up to now, ssh is the only once allowed by firewall (via wireguard), cannot access device in data center directly
no chance to see how healthy the router is
About the changelog: not quite sure which entry would give a hint regarding the observed behaviour
ROUTER is alive again ! - friend of mine was able to reboot the router with via web ui, without wireguard.
Unfortunatly we did not implement rsyslog remote log, router log is memory based only, so no helpful entries.
Guess:
I think, that I logged in via ssh while the router was not fully functional/up. Observed odd behaviour also on some of my linux devices, when tried to ssh login in the middle of reboot, got something of a shell which looked weird.
Thanks all for helping, leave with the feeling that there are some secrets in the mt devices
