Dear Mikrotik!
I reported this bug on v7.0beta8 on 10/06/20, you confirmed it on 18/06/20 and wrote
we look forward to fixing this on upcoming RouterOS versions, unfortunately
See SUP-5149.
v7.0beta5 - no issue
v7.0beta8 - the issue appears
v7.1beta1 - not fixed
v7.1beta2 - not fixed
Is it so huge bug?
I kindly ask you to pay attention to it.
add name=br protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-wan
/interface vlan
add interface=br name=vlan10-wan vlan-id=10
add bridge=br interface=wlan24
add bridge=br interface=wlan50
add bridge=br interface=ether2
add bridge=br interface=ether3
add bridge=br interface=ether4
add bridge=br interface=ether5
add bridge=br interface=wlan24.1
add bridge=br interface=wlan50.1
add bridge=br interface=ether1-wan pvid=10
/interface bridge vlan
add bridge=br tagged=ether2,br untagged=ether1-wan vlan-ids=10
/ip dhcp-client
add disabled=no interface=vlan10-wan use-peer-dns=no use-peer-ntp=no
supout.rif.zip (534 KB)
