rb750 gr3
system/health
temperature is missing
voltage is 0.5v
both, winbox & SNMP
rb750 gr3
system/health
voltage is 0.5v
both, winbox & SNMP
I took a bite and installed it on my RB750Gr3 here. (PS: no changelog shows up on “Check for Updates”.
One thing, IPv6 wasn’t functional. Checking routes, I had somehow TWO default routes, both of them had ECMP flag.
I had to disable “add default route” from DHCPv6 client in order to get things working.
But what adds the other default route? What’s wrong in this picture?
Is it set by the PPPoE Client? that one still has ‘add default route’ checked, but it didn’t add an IPv6 route before.
Each route has a flag showing which protocol added the route, from your screenshots default route is added by the VPN (PPPoe)
Holy sh*t, these are pleasant surprises.
Indeed, it is set by the PPPoE Client.
So for dual stack setups we have to disable the add-default-route from DHCPv6 client and let the PPPoE client add both routes.
Or disable add-default-route from PPPoE client and add the IPv4 route manually. Or set another distance for the DHCPv6 default route.
Or… some other workaround.
Because having them both with distance=1 does not work.
PS: I was wrong earlier, only one of them gets the ECMP flag.
And to the people wondering: yes, Cake is still broken and causes a kernel panic.
NV2 is still broken. No any association after upgrade
That’s unfortunate, thanks for checking. IPv6 connection tracking also seems to be still broken.
Edit: While pasting a multilined command (containing "") into the terminal, WinBox produces a lot of output, because a preview of all lines is shown for every character.
Other findings:
V7rc1! They grow up so fast…
Really looking forward to the stable version… ![]()
Does this version support IGMP-Proxy?
For VLAN filtering, does this mean I can set PVIDs on ports and have it still HW offloaded? Also, will STP/RSTP be supported for offloading as well?
Yes, you can set PVID and still have HW offload.
STP, RSTP and MSTP are supported as well.
Will routing filters ever get a traditional winbox gui, or are we stuck with manually writing “if ( [matchers] ) { [actions] } else { [actions] }” rules?
After upgrade on one HEX S which i use only for Wireguard i get spamm of this for all peers constantly in log.
wireguard1: =(peer): Handshake for peer did not complete after 5 seconds, retrying (try 16)
But everything works fine, i also tried closing the WG port because i was thinking it may be invalid attempts from net, but spam continues.
Any idea whats this about?
No, seems rc1 to be a step forward because Winbox seems now supporting routing/filter!
in 7.1beta7 it was not supported.
regards
Ros
#[SUP-44860]: v7.1beta5 x86 still crashes
ip route crash in winbox when it sort all the fullroute. Opened since last year.
sent to Maris the supout generated also on 7.brc1
regards
Ros
great mikrotik!! now i try to install it on the little rbm11
Looks like enabling VLAN offloading on the RB4011 stops inter-VLAN routing, even though there’s valid routes for each VLAN. Also, the CLI ? key doesn’t work.
does not work socks 5 + auth-method=password
someone please give me info regarding mpls on v7.1rc1, is it works nicely or something?
thx
