…jep…and the hap-ac3 is now fully bricked, as netinstall (v7.2.1) does not seem to work either.
According to this: https://help.mikrotik.com/docs/display/UM/hAP+ac3#heading-ButtonsandJumpers the LED should go off when entering netinstall mode, but it never does go off…it starts flashing green, but then returns to solid blue.
…anyone care to elborate on how to unbrick this unit?
Windows computer ? Make sure ALL network interfaces are disabled except the one you want to use for netinstall.
I had more success using Linux box lately when battling this bootloop fun … (almost first time right every time).
I fell into same pot hole on my audience. When trying to netinstall using 7.2.1 x64 windows, device never showed in the netinstall window. The funny thing is that wireshark did show TFTP traffic going on. So then I used netinstall 6.49.6 (the 32 bit windows) and device showed there. But couldn’t make it install 7.2.1 (*). So I fired netinstall 7.2.1 again and there was device. Installation of 7.2.1 went smoothly afterwards.
(*) When trying to select packages to install, originally 7.2.2 system and wifiwave2 packages were selected. If I clicked “unselect” or if I clicked the check in front of system package, netinstall binary crashed. It turns out one has to unselect other packages first (in my case wifiwave2 7.2.2), only then select different version of system package.
Then I did some more experimenting … I uninstalled wifiwave2 package, rebooted. Then uploaded system package version 7.2.2 and rebooted. Audience still working fine. Upgraded routerboot, rebooted .. audience still going strong. Uploaded wifiwave2 package, rebooted … bootloop again. Back to netinstall, downgrade to 7.2.1. Wifiwave2 configuration partially lost … which did not happen before on this device (I started with clean netinstall of 7.2rc4, then 7.2rc5, 7.2 and 7.2.1).
I have CCR1009-8G-1S-1S+ and Audience connected to it. Both had 7.2.1. I upgraded CCR to 7.2.2 (both packages and firmware). Everything looked OK, except that Audience was not able to connect to CCR, including I can’t connect to Audience with winbox.
I switched to the long term channel and downgraded to 7.1.5 on both devices.
What’s new in 7.3beta37 (2022-Apr-25 15:29):
*) system - fixed RouterOS bootup when wifiwave2 package is installed (introduced in v7.3beta34);
And the same bug was also introduced in 7.2.2 “stable”, which was released later than 7.3beta37…
Bugs introduced in v7.3beta34 also appear in 7.2.2 “stable”?
A “stable” version released after the beta version containing the fix does not contain the same fix?
A “stable” version is not booted at least once during MT internal testing on a box with wifiwave2?
Having developped SW myself for many years, I really wonder how MT manages to produce such blunders again and again.
Sorry MikroTik, but something with your SW dev and test processes is more than broken.
…thats the problem…it never does appear in netinstall…
In my experience, Netinstall often fails to detect devices after the ethernet link to the MT device goes down and up again while netinstall is running.
Either place a dumb switch between the PC and the MT box to netinstall, so the PC ethernet link stays up during reboot while entering Etherboot.
Or first put the MT box in Etherboot mode, wait for the link to come up and start Netinstall after the link is up.
With both approaches, devices show up in Netinstall almost immediatly. At least for me.
I have a software development background too. There is a lot to like about MikroTik. If we step back from the immediate issue (RoS v7 is public beta) we can see smart, helpful, and talented people following a broken process. This is a concern for management and I do wonder what is the incentive for them to change that process? What is happening makes them look juvenile and brand damaging.
Well, of course there is always some “freeze” moment where code is no longer being ported into a “stable” version, and it may be before the release of the last beta.
But in case of such a blocking problem I would expect either a delay of the stable version, or a warning “do not upgrade to this version when you use wifiwave2”.
Yeah, there is some room for improvement (diplomatically speaking) especially when it comes to stable releases. It’s definitely a matter for the management team.
