Hi All,
Please, could you suggest how to get back interface graphs embedded in RouterOS 6.47)?
I had these presenting usage, etc. and in effort to get better accounting as mentioned under http://forum.mikrotik.com/t/accounting-missing-url-404-telegraf-grafana-integration/157350/1 discovered that after upgrade to 7.2, graphs disappeared completely.
Please kindly advise on how to get it back. If you’d have some sort of integration for telegraf/grafana - that would be amazing.
Thanks.
If you’re pulling them over HTTPS, it’s a known bug. HTTP works.
I just checked to make sure that I’m using HTTP and it still doesn’t show.
Please stop spreading lies.
There’s no good cause to be poisonous about it. I’m just passing on a recent report from MikroTik.
Within that limitation, it works as expected here. Via HTTP against a CRS328 running 7.2.1, I get:
But via HTTPS, just as Normis claimed, I get:
Given your “no access” error, I’d guess you’ve got a problem in the “allow address” part of the configuration. Care to show your /export for this?
