No issues are observed on the Mikrotik hAP ax² side. It is currently operating normally and stably.
Thanks!!! So nothing to worry about! uff Next time I should read changes very carefully. Thanks!
Upgraded my RB4011 from 7.21.1 to 7.21.2 and immediately all routing tables stopped working. Found that for each VLAN, in IP>routes it displayed routing table “unknown” instead of “main”
Lots and lots of troubleshooting later, I decided to downgrade back to 7.21.1 and immediately everything was fine again
Looks like this is not true...
But! I have two ports now on CRS328 that show a note:
[eworm@himalia] > /interface/print where about
Flags: R - RUNNING; S - SLAVE
Columns: NAME, TYPE, ACTUAL-MTU, L2MTU, MAX-L2MTU, MAC-ADDRESS
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
;;; poe-out status: short_circuit
21 RS en22 ether 1500 1592 10218 CC:2D:E0:8E:15:C9
23 RS en24 ether 1500 1592 10218 CC:2D:E0:8E:15:CB
Chateau 5G R17 issue is indeed fixed ![]()
You can always check the default configuration by exporting the default configuration:
/system/default-configuration/print file=defconf
And then check whatever changes were mentioned in the change-log. This way you can also align your config to the new defaults wherever possible.
If netinstall has not set its own, or the branding has not changed,
the default configuration is indeed updated as a view, but is not applied.
If you specify interface, VRF is already implicitly defined.
If you specify just VRF(no IP address), it should use the preferred source mechanism to choose the IP address source.
And if RouterOS does not have that behavior, it is not compliant with the expect behavior defined by standards of VRF.
Thanks infabo. I wasn’t aware of this. Im Running CRS328 now for 4 weeks. The CRS125 hadn’t flash.
I can confirm lte on Chateau R17 is fixed.
Wondering how 7.21.1 was tested on R17 before release without noticing it completely breaks lte on a lte router, but let's not start this discussion again.
I have SUP-203801 still open with MLAG issues since November. I am currently stuck on 7.19.6, every patch/version since has been broken for me, with my CRS326’s hitting 100% CPU and becoming unusable the moment I upgrade.
Downgrading has been the only way i can return to stability
+1
I have a pile of CRS317 and I’m waiting to be able to use them
on any 7.21.x when you enable traffic flow -> ipv6 fastpath stops working (CCR2216)
ipv4 fastpath is unaffected, but ipv6 fastpath seems requires to have traffic flow disabled. I think it is a bug.
ticket opened about it. SUP-209908
Has anyone noticed another firewall rule that got changed in the default config?
/ip/firewall/filter
add chain=forward action=drop connection-nat-state=!dstnat in-interface-list=WAN comment="defconf: drop all from WAN not DSTNATed"
The rule no longer has the condition:connection-state=new
I don't use fastrack or ipv6, would it be safe to apply this fix?
After updating to ROS 7.21.2 from 7.20.7 (could be related to 7.21 container changes) it is not possible to update container from WinBox v3, it presents error message “Error in Shm Size -expected!“ even Shm value is set:
It seems that WinBox v3 doesn’t properly read Shm and Tmpfs values from container settings because they are marked red when container settings dialog is open:
Also issue that is present from prev. releases (not sure from which release, but I think it was working at some point) is Memory High containers config which is also not possible to update from WinBox v3:
Using latest WinBox - v3.43 running with Wine.
can you try from cli to eliminate winbox3 usage ?
Yes it is working from CLI, but I’m more used to use WinBox to update simple configs, like changing Start On Boot flag for container…
