V7.22.1 [stable] is released!
Hey Guys, I have a strange issue where I can’t add new containers in this release.
The Shm Size field is pre-filled with “64 MiB”, however when I go to add a new container, this field is red and won’t let you apply new changes.
This is running on a CHR cloud version.
Not sure what to change the Shm Size to as it doesn’t appear to accept anything different. :frowning:
Cheers
Dan
This issue should be resolved in Winbox 4.
Version 7.22.2 has been released:
I have hap ax3 and after upgrade I can't connect my iPhone 14 to router. And no logs with attempt connection. After some tries I still can connect my phone to router. For this I should disable encryption (wpa psk, wpa 2 psk, wpa 3 psk) on 2,5 MHz, 5Mhz. But wifi with no encryption looks no good for me. What I should do to resolve this issue
Did you find one of many threads about the same problem. E.g. this one? Mikrotik AX2 and strange MacOS issue - #3 by whatever
Has anyone already reported this issue to MikroTik support? It has been around for a while already.
See also here:
