V7.23beta [development] is released!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.23beta5 (2026-Arp-01 19:30):
  • app - added lorawan-stack, mikrodash, trip apps;
  • app - added restart command;
  • app - updated uptime-kuma image;
  • bridge - fixed missing dynamic "switch-cpu" VLAN entry in WiFi setup;
  • certificate - added "ISRG Root X1" and "DigiCert Global Root G2" to SMIPS built-in root certificate authorities store;
  • console - added comment in "/ip/dhcp-server/option/sets" and "/ipv6/dhcp-server/option/sets" menus;
  • console - added path parameter to export;
  • console - export mentions custom defconf script presence in header (additional fixes);
  • console - fixed output when oversized completion present;
  • console - rename "cpu-used-per-cpu" to "cpe-used-per-core" in "/system/resource/monitor";
  • console - show warning in print header when terminal is too narrow to show any columns;
  • console - treat non-existent command parameters as runtime errors;
  • container - allow setting memory-max global and per container (additional fixes);
  • dhcpv4-server - added "add-dns" and "add-dns-suffix" properties for creating local DNS entries;
  • discovery - added "add-dns-entries" and "dns-entry-suffix" properties for creating local DNS entries;
  • disk - improved device name tracking in "/system/resource/hardware" menu;
  • disk - use USB UASP interface for supported devices (additional fixes);
  • ethernet - improved system stability for RB3011, L009, NetMetal ax, hAP ax lite devices;
  • ethernet - improved system stability on devices with Alpine CPUs;
  • firewall - improved system stability;
  • health - hide health menu for RB951ui-2nD;
  • iot - improved LoRa Tx scheduling;
  • ip - fixed hanging connections for reverse-proxy;
  • ipv6,ra - improved service stability;
  • ipv6,ra - use received prefix when RA on-link flag is 0 (introduced in v7.22);
  • log - fixed crash when a rule references a non-existent action (introduced in v7.23beta2);
  • lte - improved system stability when modem configured in passthrough mode with VLANs for "Chateau 5G R16" and "Chateau 5G";
  • lte - keep MAC persistent across reboots for QMI modems;
  • ospf - fixed missing interface-template configuration which previously was converted by upgrading from RouterOS v6 (additional fixes);
  • ovpn - fixed OVPN push routes;
  • ping - resolve domain name to IPv6 if src-address is IPv6 address;
  • port - expose RG650E-EU diagnostics channel;
  • port - remove unused serial port on RB1100AHx4;
  • ptp - allow manual domain configuration for 802.1AS profile;
  • ptp - fixed crash during initialization on some devices;
  • ptp - set DSCP (EF) for default profile when using IPv4;
  • switch - use names instead of numbers in switch menu configuration export;
  • system - improved stability for internal RouterOS service communication;
  • upgrade - added the option to configure HTTP/HTTPS modes when connecting to MikroTik upgrade servers (additional fixes);
  • webfig - added postfix byte value support (e.g. "/ip/settings/ipv4-high-fragment-thresh");
  • wifi - improved authentication stability for WiFi 7 access points;
  • wifi-qcom-be,mediatek - correctly advertise RRM capabilities when 802.11k neighbor reports are enabled;
  • winbox - added “Remove” action under "System/Certificates/Requests" menu;
  • winbox - do not accept interface without specifying IP or MAC in "Ping To" field;
  • winbox - show "Directory URL" field for ACME certificates in Certificate view;
  • winbox - show accepted connections in tree view under "IP/Services" menu;
What's new in 7.23beta4 (2026-Mar-25 16:31):
  • app - added birdnet-go, cryptpad, diagrams-net, metube, nextcloud-whiteboard, paperless-ngx, wbo, zulip apps;
  • app - allow filtering by installed apps;
  • app - allow picking app category from drop-down;
  • app - automatically restart app when required hardware device is changed;
  • app - bundled ollama with openwebui;
  • app - fixed issue where XFS disks did not appear in the app disk drop-down;
  • app - make sure all layer .tar.gz files are deleted after extraction finishes;
  • bfd - fixed source address selection for IPv6 multihop sessions;
  • bgp - fixed stability issue when nonexistent output select-chain was specified;
  • bgp-vpn - fixed non-working import filter after reboot;
  • bridge - improved MAC synchronization for MLAG (additional fixes);
  • bth - fixed WireGuard client config IP address netmask;
  • chr - improved guest tool config for arm64 CHR;
  • console - removed the "reset" command from shared settings menus (IP/IPv6/Bridge/L3HW/Neighbor-Discovery/Connection-Tracking);
  • container - added support for noexec option to mounts;
  • container - added support for USB audio devices for containers;
  • container - do not allow starting container/shell with non-existing user or group;
  • container - draw graphs in container stats;
  • container - remove container backup directory if import fails;
  • container - show container size and container data size;
  • container - show default DNS servers;
  • dhcpv4-server - changed lease agent-circuit-id and agent-remote-id format to HEX;
  • discovery - added option to disable/enable LLDP MED;
  • discovery - added separate read-only menu "/ip/neighbor/lldp" for neighbors discovered by LLDP the (CLI only);
  • discovery - dynamically update advertised "interface-name";
  • discovery - fixed LLDP MAC/PHY TLV;
  • disk - added disk check and repair for ext4, btrfs and xfs file systems;
  • disk - use USB UASP interface for supported devices;
  • file - added copy, tail, head commands (CLI only) (additional fixes);
  • graphing - improved service stability when storing data;
  • interface - show warning when same MAC address is used on more than one virtual interface;
  • iot - improved LoRa stability;
  • ip - added SNI logging for reverse-proxy;
  • ip-settings - added ipv4-fragment-time and ipv4-high-fragment-thresh settings, use default values based on total device memory (additional fixes);
  • ippool6 - properly follow pool changes for already used prefixes;
  • log - added ssld error logging (additional fixes);
  • log - do not provide non-existent logging topics for configuration;
  • log - fixed "/system/logging/action/get" command (introduced in v7.22);
  • lte - added fast SIM switchover support using AT channel for MBIM modems without MBIM_CID_MS_UICC_RESET firmware support;
  • lte - configure IP address for AT modems even if no DNS is received from the network;
  • lte - do not reconfigure modem in passthrough mode if passthrough cannot be activated because of slave interface;
  • lte - fixed automatic modeswitch for "Chateau 5G R16" and "Chateau 5G";
  • lte - fixed broken network scan after being interrupted by reconfiguration;
  • lte - fixed LTE modem automatic modeswitch (introduced in v7.22);
  • lte - fixed missing automatic redial when cellular connectivity is lost for R11e-LTE;
  • lte - improved system stability;
  • lte - stop network scan on interruption for QMI modems;
  • lte - unify "modem-init" for all driver types;
  • ospf - allow adding interface configuration manually, bypassing interface-template;
  • ospf - change virtual link configuration to use OSPF interface directly;
  • ospf - fixed missing interface-template configuration which previously was converted by upgrading from RouterOS v6;
  • qos-hw - added ECN and PFC support on CRS8xx (additional fixes);
  • qos-hw - display queue0 limits for CPU port;
  • qos-hw - fixed "offline" tx-manager ability to queue at least one packet (introduced in v7.21);
  • qos-hw - fixed CPU traffic mapping to queues on CRS8xx switches;
  • qos-hw - prohibit setting CPU port with "offline" tx-manager;
  • route - fixed link-local interface check when resolving IPv6 nexthops;
  • route - improved service stability when removing routes;
  • routerboard - fixed applying settings via WinBox on devices with fixed CPU frequency;
  • routerboot - fixed Netinstall failure when using multiple partitions on AL73400, AL52400, AL32400 CPUs ("/system routerboard upgrade" required);
  • sftp - fixed path canonicalization request;
  • snmp - added missing BRIDGE-MIB OIDs (dot1dBaseNumPorts, dot1dBaseType, dot1dStpDesignatedRoot, dot1dStpRootCost, dot1dStpRootPort, dot1dStpHoldTime, dot1dStpBridgeMaxAge, dot1dStpBridgeHelloTime, dot1dStpBridgeForwardDelay, dot1dStpPortForwardTransitions, dot1dTpAgingTime);
  • snmp - added missing LLDP-MIB OIDs (lldpMessageTxInterval, lldpMessageTxHoldMultiplier, lldpLocManAddrTable);
  • snmp - fixed compliance of LLDP-MIB lldpRemManAddrTable;
  • snmp - fixed dot1dStpPortDesignatedPort OID;
  • snmp - fixed ifSpeed and ifHighSpeed OIDs for 802.3ad and balance-xor bonding interfaces;
  • snmp - fixed lldpLocSysDesc OID;
  • snmp - fixed return value for certain string OIDs (introduced in v7.23beta2);
  • snmp - use "/ip/neighbor/lldp" for lldpRemTable and lldpRemManAddrTable (fixes lldpRemTable showing neighbors discovered by MNCP or CDP);
  • ssh - improved host resolve error logging;
  • switch - improved FDB operations on QCA8337, Atheros8327;
  • switch - rework how IEEE reserved MAC addresses are handled on QCA8337, Atheros8327;
  • system - added FCC Part 15 Compliance label to "System/Regulatory" menu;
  • system - included full certificate chain to Windows executables;
  • system - keep HTTP/2 connection open if it is not closed by system or server;
  • system - make default identity based on board name;
  • veth - fixed link-local address not being configurable as a gateway;
  • wifi-mediatek - fixed HE capabilities IE on 2GHz band;
  • winbox - added "MLD Static" and "MLD Datapath" properties under the "WiFi/CAP" menu;
  • winbox - added "Multipath" property under the "Routing/BGP/Instance" menu;
  • winbox - added "Supported HW Caps" and "Multi Link Mode" configuration options under the "WiFi/Provisioning" menu;
  • winbox - allow setting "CAPsMAN address" for CAP as domain name;
  • winbox - do not set empty chain when adding/editing routing rule;
  • winbox - improved "External Antenna" property display;
  • winbox - properly display multiple bands for multi-link interface clients under registration table;
  • winbox - show "IPv6 Address" property by default under the "IP/Neighbors" menu;
  • wireguard - improved system stability;
What's new in 7.23beta2 (2026-Mar-13 11:52):
  • app - added docker-with-dockge, docker-with-komodo, docker-with-portainer, HA-otbr-matter, odoo, otbr, stalwart apps;
  • app - added possibility to set app command-line parameter from CLI;
  • app - allow apps on xfs file system;
  • app - allow overriding default stop signal;
  • app - allow parsing DNS in YAML;
  • app - allow passing stop signal from YAML and passing it to container as default;
  • app - allow updating name parameter from YAML for custom apps;
  • app - allow updating YAML for existing custom app, forces cleanup;
  • app - apps now check for port availability, apps will not start on "internal" if app masks existing service;
  • app - automatically pass any required devices to container, such as otbr;
  • app - disabled PiHole syncing NTP to host;
  • app - fixed potential crash when running cleanup on a lot of apps;
  • app - fixed saving custom apps;
  • app - fixed showing ui-url for apps;
  • app - fixed uptime-kuma and jupyter-notebook;
  • app - fixed YAML not exported for custom apps;
  • app - improved app networks and port behavior;
  • app - improved automatic hardware device passing to container;
  • app - improved YAML error message;
  • app - on file based devices, swap is enabled on the file itself instead of creating another one and enabling it on that;
  • app - stability fixes for the "/app" menu;
  • app - swap file is now created based on the mount-point it is attached to;
  • arm64,x86 - updated Broadcom bnxt Ethernet driver for 200G support;
  • bridge - added ability to set custom Option 82 with dhcp-agent-circuit-id, dhcp-agent-remote-id settings (replaces add-dhcp-option82 setting; configuration is automatically updated after upgrade);
  • bridge - added DHCPv6 snooping feature with ability to set custom Option 18 and Option 37;
  • bridge - improved MAC synchronization for MLAG;
  • bridge - recognize more DHCP message types when dhcp-snooping is enabled;
  • certificate - added option to configure built-in trust store for all services (CLI only);
  • certificate - use "default" for built-in trust store default value;
  • chr - improved virtio_net stability;
  • cloud - show error if cloud services are not supported on the device;
  • console - added syntax highlight for script properties in some menus (e.g. dhcp-client, dhcp-server, ppp/profile, interface/vrrp);
  • console - export mentions custom defconf script presence in header;
  • console - fixed "/log/print follow on-event" to work with "where" (introduced in v7.22);
  • console - removed redundant keepalive for the serial-terminal, ensure that the device no longer periodically outputs /0 while using "/system/serial-terminal";
  • console - show "/system/resource/hardware/usb-power-reset" only on x86;
  • container - added restart-policy=no/always/on-failure, stop-on-unhealthy, restart-count, restart-interval, restart-max-count properties;
  • container - allow disabling individual container environment variables without deleting them;
  • container - allow picking mount source directories with the file picker in WinBox;
  • container - allow setting memory-max global and per container;
  • container - allow user-defined mounts overriding /sys and /dev;
  • container - clean up layers of non-existing containers;
  • container - detect and show containers killed by out-of-memory killer;
  • container - fixed container entrypoint and shell override by user;
  • container - fixed container layer size calculation;
  • container - fixed container shell not working with multi-arg commands;
  • container - fixed losing container after reboot;
  • container - fixed repull if root-dir of container was in tmpfs;
  • container - fixed running "/container shell" with the correct user, if container user is set or overridden;
  • container - improved errors at container start;
  • container - improved running container instance memory usage;
  • container - layers are now accessible under "Layers" tab;
  • container - pass any container startup error message back to "run" and make it exit immediately;
  • container - removed "Layers" button;
  • container - show layer size calculation status;
  • crypto - fixed fallback flag loss in qcrypto;
  • crypto - improved safexcel driver with upstream changes and patches;
  • dhcpv4-server - do not raise an alert when receiving a packet originating from the same device;
  • dhcpv4-server - do not suggest bogus pools when using setup command (e.g. when address is /31 or /32);
  • dhcpv4-server - fixed an issue where renew packets without giaddr were sometimes not processed;
  • disk - added "/disk" smart-info;
  • disk - show disk io errors in "/disk" menu;
  • dns - added HTTP/2 support to DoH on ARM64 and x86/CHR devices;
  • fetch - fixed non-working idle-timeout in some cases;
  • file - added copy, tail, head commands (CLI only);
  • firewall - improved stability for SIP helper;
  • hardware - name serial devices after port names;
  • hardware - name storage hardware devices after slot name in "/disk" menu;
  • hardware - report the correct state of PCI devices in "/system/resource/hardware" menu;
  • iot - added LoRa Tx delay setting;
  • iot - added MQTT subscribe message real-time monitoring option;
  • iot - added Wiliot support;
  • iot - fixed LoRa LBT issues, which caused Tx packets not getting delivered;
  • iot - improved LoRa Tx handling;
  • ip-settings - added ipv4-fragment-time and ipv4-high-fragment-thresh settings, use default values based on total device memory;
  • ipip - disabled IPv6 link-local address generation;
  • ippool - fixed issue when changing pool with already used addresses;
  • ippool6 - allow variable length pool;
  • ipsec - added netlink-based SA and policy handling;
  • ipsec - fixed SA proto parameter conversion and policy "none" type handling;
  • ipv6 - added from-pool-policy address property that controls how address is acquired from the pool;
  • ipv6 - always ensure that prefix length matches the one given by the pool even if address was set to 0;
  • ipv6,ra - added option to ignore MTU and DNS servers;
  • ipv6,ra - added router-advertisement-route-distance setting;
  • ipv6,ra - allow receiving DNS servers over multiple interfaces;
  • ipv6,ra - clamp valid-lifetime to minimum of 2h on deprecation;
  • ipv6,ra - extend processed RA logging;
  • ipv6,ra - fixed advertised DNS parameter logging;
  • ipv6,ra - fixed changing default "all" interface configuration;
  • ipv6,ra - fixed DNS and pref64 property unset;
  • ipv6,ra - fixed sending only DNS or MTU when prefix is set to "none";
  • ipv6,ra - warn when interface is under the bridge;
  • l3hw - added HW offloaded VRF support on CRS8xx switches;
  • l3hw - added VRF assignment via switch ACL rules on CRS8xx switches (CLI only);
  • l3hw - fixed VXLAN packet matching by local IP;
  • l3hw - improved system stability (introduced in v7.21);
  • leds - added new PoE fault LED cases (bad fw, PoE card power cable disconnected, PoE card not inserted);
  • leds - allow multiple interface selection for interface-activity trigger;
  • log - added CC option for e-mail action;
  • log - added ssld error logging;
  • log - added TLS support;
  • lte - do not duplicate primary-band also in ca-band for QMI modems in 5G SA network;
  • lte - emit RS every 60s on LTE interface;
  • lte - filter packets by MAC in multi-apn setup for EC200A-EU modem;
  • lte - fixed RSSI signal monitor 3rd party modems where AT+CSQ responses are not parsed;
  • lte - fixed Tx stat reporting in LTE passthrough mode (introduced in v7.22);
  • lte - fixed user set MTU not applied to LTE interface;
  • lte - improved system stability for devices with QMI modems;
  • lte - improvements for passthrough mode in IPv6 only setup;
  • lte - read subscriber number also for QMI modems;
  • lte - removed LTE external-antenna scan;
  • lte - set SMS send timeout to 180s;
  • lte - show external-antenna as "none" before actual scan is done instead of empty value;
  • lte - show MTU as "auto" also on interface level if "auto" used;
  • lte - SIMCom modems, skip error state when modem sends improperly formatted CREG response/URC;
  • macsec - added aes-gcm-xpn-128 cipher support;
  • ospf - fixed nssa bit check;
  • ospf - fixed routes not being installed on ABRs;
  • pimsm - do not ignore priority when selecting RP from BSR;
  • pimsm - fixed possible BSR loop;
  • pimsm - improved stability;
  • ping - show time in microseconds for flood-ping;
  • poe-out - firmware update for 802.3at capable boards (the update will cause a brief power interruption to poe-out interfaces);
  • port - added support for "tcp-client" and "udp" modes for "remote-access";
  • pppoe - do not reset pppoe-client interface when adding a comment;
  • ptp - added support for CRS812, CRS804;
  • qos-hw - added automap setting to QoS Profiles (enabled by default);
  • qos-hw - added ECN and PFC support on CRS8xx;
  • qos-hw - added new default "auto" value to mirror-buffers, multicast-buffers, shared-buffers QoS Settings (old defaults are shown in export after upgrade);
  • qos-hw - added queueX-byte-max stats to port usage on CRS8xx;
  • qos-hw - introduced lossless-traffic-class and lossless-buffers settings;
  • qos-hw - removed shared-pool-index setting;
  • quickset - fixed configuration of multi-link APs;
  • smb - do not start /ip smb server on container interfaces;
  • sniffer - added IP ECN field;
  • sniffer - fixed missing VLAN tag in the TZSP packets;
  • snmp - enforce minimum password length;
  • snmp - fixed connection tracking counter OID;
  • snmp - fixed dot1dStpPortDesignatedRoot and added dot1dStpPortDesignatedBridge OID;
  • snmp - implemented LTE firmware upgrade option;
  • ssh - do not advertise password login method when it is disabled;
  • ssh - make login process asynchronous;
  • switch - disable EEE on RB5009 and CCR2004-16G-2S+ devices;
  • switch - updated switch-marvell.npk driver;
  • system - fixed total memory reporting on hAP be3 Media;
  • tr069 - fixed modem extended revision reporting;
  • upgrade - added the option to configure HTTP/HTTPS modes when connecting to MikroTik upgrade servers;
  • upgrade - changed status message for scheduled installs;
  • upgrade - check for available packages when opening System/Packages in GUI;
  • upgrade - use HTTPS by default when connecting to MikroTik upgrade servers;
  • usb - added ax88179_178a driver;
  • usb - improved USB Ethernet adapter recognition;
  • usb - show USB device reported maximum power;
  • vxlan - improved system stability for TILE devices;
  • webfig - added support for filter in tables;
  • wifi - fixed bridge VLAN configuration for multi-link interfaces;
  • wifi - fixed EAP authentication for multi-link clients;
  • wifi - improved link-specific parameter application after reboot for multi-link interfaces;
  • wifi - improved stability during association;
  • wifi-mediatek - fixed multicast-enhance functionality;
  • wifi-qcom-be - fixed forwarding of 4-address data from station to station;
  • wifi-qcom-be - fixed incorrect channel info for punctured channels;
  • winbox - added comment for DHCPv6 relay;
  • winbox - added group numbers for DH and PFS groups for IPsec;
  • winbox - fixed Remote AS setting under the Routing/BGP/Connections menu;
  • winbox - fixed Src/Dst Address Type under the IP/Firewall/NAT menu;
  • winbox - improved Routing/PIM SM menu;
  • winbox - move bridge IGMP Snooping checkbox to IGMP tab;
  • winbox - rename DHCPv6 server binding "Peer Address" to "Client Address";
  • winbox - show "External Antenna Selected" field only when "auto" selected;
  • winbox - updated socksify icon for firewall NAT rules;
  • www - added partial content (HTTP 206) support;
  • www - improved system stability;
  • zerotier - upgraded to version 1.16.0;
To upgrade, click Check For Updates under System/Packages menu and select the development Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
    sweet!! :grinning_face:
Would love to see this come to the CCR2216 as well.
Great..., getting closer and closer to 7.23.5...
Receiving lots of these in log:
2026-03-16 13:28:43 ssld,error ssl: close notify received, cert store:
What is that about?
Nice.
Is implemented also on other devices on future, or there is no hope?
can somebody confirm if that’s including the NVME health which isn’t standard smart?
I’ve been hoping for them to add extra rose features… but if it’s stable. I guess it’s stable
it's nice to finally have file copy function. Is there a chance to have recursive copy and archive mode (copy only newer) in the future?
*) ipv6,ra - added router-advertisement-route-distance setting;
Yes!
Looks like this is caused by sending e-mail (/tool/e-mail/send ...).
Version 7.23 beta2 still has random routing stuck issues. Routes aren't visible in Winbox's IP/Route or CLI's /routing/route print. Supout and video evidence have been submitted under ticket SUP-209164
Whenever i send email i get error:
Emails send just fine regardless, is this some kind of bug or im supposed to do something about this?
anyone managed to configure dns4eu successfully on this version ?
Yep…
set allow-remote-requests=yes servers=86.54.11.100,86.54.11.200,2a13:1001::86:54:11:100,2a13:1001::86:54:11:200
use-doh-server=https://unfiltered.joindns4.eu/dns-query
So far it just works :slight_smile:
/system/package/update> check-for-updates
channel: development
mode: https
check-certificate: yes
ip-verson: auto
installed-version: 7.23beta2
status: ERROR: IPv4: ssl: crl not found for: "CN=mikrotik.com" (6)
IPv6: ssl: crl not found for: "CN=mikrotik.com" (6)
Will the container management apps like Portainer , Dockage, and Komodo allow installation of containers?
There are some containers that I cannot install using the container module. Having the ability to install them via a management app would be great. Karakeep and MeTube are two examples.
Can you set this per interface?
Ditto for the CRS520
Sadly, there is no split-up of the wifi-qcom-ac package. :cry: Waiting for 7.24.
/ipv6 address
add address=::1 from-pool=digi-pd interface=vlan188
/ipv6/address/print
13   G 2a02:xxxx:yyy:zz00::1/64          digi-pd    vlan188     main  yes
00 !! thank you!
