v7.3 and v7.3.1 [stable] is released!
What with the APR-Ping? When ARP-Ping will be working in ROSv7?
Could you share configuration (support/export etc.) with MikroTik support (support@mikrotik.com)?
…but had been there in 7.2.1
The same here, have to stay on 7.2.1 (7.2.3 or 7.3 - the same issue). Not only this, currently when upgraded from 7.2.1 to 7.3 I lost again some parts of configuration (at least all simple queues now), but even though I fix that by restoring saved configuration from 7.2.1, the routing issue still persist. Downgrade to 7.2.1 solve everything again. I have a support ticket SUP-81294 on this since 4.5.2022 but still no relevant solution/help from Mikrotik support :frowning:
Upgraded RB3011 from 7.2.3 to 7.3
reboot loop and router unusable
after 50 loops, it booted, the part of the bgp peers is removed… it didnt like keepalive and hold timers.
What is the config of your router?
What version was installed prior upgrade?
it was 7.2.3 , now 7.3
I managed to downgrade, and everything works
[quote=TimmZahn post_id=937874 time=1654612859 user_id=200086]
RB5009UG is still reporting the error “cpu not running at default frequency” after upgrading to v7.3.
[/quote]
So it will until you change it to “auto”.
Upgraded CCR1009-8G-1S-1S+PC without problems. Running nat, few vlans, ipsec, ipip/gre tunnels, ospf, wireguard. So far everything works fine. Also successfully upgraded RB2011-UiAS-2HnD.
JF.
Wireless management protection has stopped working
Yes, I always do after the update
Update successfull on
RB4011, hAP ac3, hAP ac2 (x2) and mAP 2nD, from 7.2.1 to 7.3.
no problems.
BR.
On such a device (with enough flash), always partition the router with 2 partitions and copy the active to inactive partition before upgrading.
Then, when it bootloops at least you have easy (automatic) recovery.
Can you give more information how VLAN tagging works on 7.3 (versus 7.2/7.1/7.0)? I migrated from ROS6 to 7.0 and since ever all my VLAN worked…
Also did not see any doc saying VLAN config method changed suddenly.
What are conditions to use this feature? I have AES passed to CHR and no HW flag in OVPN server clients. Is there any documentation to this?
Thank you
Set your chr vm cpu setting to host
I have set it, as I write. CHR sees Intel CPU (same as host).
Same here with RB3011 after upgrade to v7.3. I noticed if I disable PPPoE client (to connect to Internet) the router stops rebooting.
Log:
jun/07/2022 15:29:54 system,error,critical kernel failure in previous boot
Upgraded multiple devices inc CCR1009 / CRS317 / RB4011 / RB3011 / wAP AC all OK.
However, I encountered an issue when upgrading my RB5009 from 7.2.3 to 7.3: it has a bonded WAN interface (Ether 2 and 3) connected to a Virgin Media HUB 4 (in modem mode). The bonded WAN interface is configured as a DHCP client and normally gets a 192.168.100.x IP address from the hub with a number of short DHCP lease times, which eventually gets replaced with the public IPv4 address once the cable modem is fully initialised.
However, after upgrading to ROS 7.3 (& firmware 7.3), it gets the initial 192.168.100.x IP addresses via short DHCP leases from the HUB4, but never obtains the final public IPv4 address, even when clicking on the RENEW button in the DHCP client config window.
Support ticket has been raised with Mikrotik.
One day this will be fixed…
