Routing marks now have higher priority.
One way to make rules work.
Separate the route tables (routing marks) the rules check vs the route tables the rules specify as a lookup.
In ip route table only have Routing table entries with Rvia-alt (I put in R to indicate goes in routing table)
Do not have entries with via-alt in ip Route Table.
No, I’m not, I’m just coming from 7.2.3. I could reproduce the same issue in RB4011 and mAP, so definitely not ARM related. And RIP is not the problem, it acts later, once client has obtained and IP, to create routing table. With or without RIP, DHCP Client should obtain an IP from VLAN 3.
HATS OFF for finally posting a warning in the topic for cases of severe breakage. It would be even better when it was shown also on the router itself (i.e. put in the changes list).
RB4011: When having a bridge with VLAN-filtering (and hw accel), containing ports that have a numbered VLAN set to “untagged”, it appears that output going to such a port also “floods” to other untagged ports in the same VLAN, as if it is a HUB instead of a SWITCH. When the second port is on the other hardware switch the leakage is about 100%, when it is on the same switch it is much less than that.
So, when you have had some interval with 20Mbps traffic to port 8 (untagged port on a VLAN), you see the same 20Mbps on port 4 (untagged port in the same VLAN), and like 0.5Mbps on port 7. This is shown in the traffic counters for the interface, and in the graphing. Torch does not show the actual traffic going to the port.
Thanks for the clue, i try but still some ip not working, i decided too add ip address in firewall address, this work for some other is not, my goal is like this my ISP have a few CDN like netflix,GGC,facebook,akamai for this CDN i need to route to my ISP other than that routing go too wireguard warp Cloudflare VPN, that why i add mangle in ip firewall address list nice addres, mangle rule is like this
that mangle have conflicting to some ip so thats why i adding to routing rules for some ip to route to my isp not VPN, on ROS 7.2.1 it works but on ROS 7.3 doesnt work like you say it “Routing marks now have higher priority”, this is my config i hope you can give me some advice dioey.rsc (393 KB)
Succesfully upgraded 7.3 to CCR2004, but I have question about BGP route filtering.
I using input.accept-* filter. exactly input.accept.NLRI where i have some prefixes in address list. Prefiltering works good but .. in routing table i have still /32 ipv4 routes as FILTERED and can not deny storing it in memory. Is there trick how to prefilter ipv4 /32 routes? Other higher prefixes is prefiltered perfectly.
Presumingly these /32 routes are part of a subnet that is accepted in the input.accept-nlri address list? You can only filter addresses outside that address list, not smaller (e.g. single) addresses inside the listed networks.
Unfortunately I tried the upgrade before the warning was released. Had to reset, downgrade then I restored from the backup I made before the upgrade.
Waiting now for V7.3.1
at all. i was also expecting a route with DA flags there, just as with DHCP.
hopefully this gets fixed soon.
also, it would be nice to have a bit more control over accepting RA messages. say being able to set an interface (list) from where RA messages are accepted under /ipv6 settings
maybe even the possibility to start a script upon successful SLAAC or an expiring RA, just like with DHCP client.
Still the same Problems with DualWan Config, on 7.2.1 the Config is running smoothly, upgrade to 7.2.3,
Router not accessible through IP only MAC, upgrade to 7.3 is the same behaviour.
If i contact Support, they recommend to call a Consultant.
I probably know what it is, and it’s not you, it’s RouterOS. I now tested it and it happened between 7.2.1 and 7.2.2. Previously if there were multiple routing tables, local destinations (addresses assigned to router) always had priority and used main routing table, but it doesn’t happen anymore. Simplified (incomplete, but shows relevant parts) example:
If 192.168.88.20 connects to 192.168.88.1, in 7.2.1 and older the log will show packets in input. In 7.2.2 and newer they go in forward. It could be intentional, but since I don’t see anything like that in changelog, it’s probably bug. And annoying one, because it can significantly break some configs.
Edit: Well, it’s not strictly about 7.3, but it’s still very much broken/changed there, so it’s interesting for anyone with such config, because upgrade can easily lock you out.
