Yes that’s correct. I am just looking to have eBGP routes advertised to iBGP peers. I updated my original post to eliminate the ambiguity.
Edge Router BGP and filter config:
/routing bgp template
set default address-families=ip as=65534 disabled=no nexthop-choice=\
force-self output.network=bgp-networks router-id=10.200.1.1 \
routing-table=main use-bfd=yes vrf=main
add address-families=ip as=65534 disabled=no input.filter=DROPALL name=\
EXTERNAL-v4 output.filter-chain=DROPALL .network=BGP-v4-OUTPUT \
router-id=<sanitized> routing-table=main use-bfd=no vrf=main
/routing bgp connection
add address-families=ip as=65534 disabled=no input.filter=\
BGP-HURRICANE_ELECTRIC_V4_IN local.role=ebgp-customer name=\
WAN_HURRICANE-ELECTRIC output.filter-chain=BGP-HURRICANE_ELECTRIC_V4_OUT \
.network=V4_PUBLIC remote.address=184.105.63.33/32 .as=6939 \
router-id=<sanitized> routing-table=main templates=EXTERNAL-v4 use-bfd=\
no vrf=main
add address-families=ip as=65534 connect=yes disabled=no input.filter=\
BGP-CORER1_V4_IN listen=yes local.address=10.200.1.1 .role=\
ibgp-rr-client multihop=yes name=CORER1.DC01_V4 nexthop-choice=\
force-self output.filter-chain=BGP-CORER1_V4_OUT \
remote.address=10.200.1.3/32 .as=65534 router-id=10.200.1.1 \
routing-table=main templates=default use-bfd=no vrf=main
/routing filter rule
add chain=BGP-HURRICANE_ELECTRIC_V4_IN comment=\
"Drop all variations of our prefixes" disabled=no rule=\
"if (dst in BGP_OUR_PREFIXES) {\r\
\nreject\r\
\n}"
add chain=BGP-HURRICANE_ELECTRIC_V4_IN comment="Drop bogon routes in" disabled=\
no rule="if (dst in BOGON) {\r\
\nreject\r\
\n}"
add chain=BGP-HURRICANE_ELECTRIC_V4_IN comment="Accept all other routers" \
disabled=no rule=accept
add chain=BGP-HURRICANE_ELECTRIC_V4_OUT comment=\
"Only Advertise routes in BGP_V4_PUBLIC Firewall Filter" disabled=\
no rule="if (dst in BGP_V4_PUBLIC) {accept}"
add chain=BGP-CORER1.DC01_V4_IN disabled=no rule=accept
add chain=BGP-CORER1.DC01_V4_OUT disabled=no rule=accept
Core Configuration:
set default address-families=ip as=65534 disabled=no nexthop-choice=force-self output.network=bgp-networks router-id=10.200.1.3 routing-table=main use-bfd=no vrf=main
add address-families=ip as=65534 connect=yes disabled=no input.filter=BGP-EDGER1.DC01_V4_IN listen=yes local.address=10.200.1.3 .role=ibgp-rr name=EDGER1.DC01_V4 nexthop-choice=force-self output.filter-chain=BGP-EDGER1.DC01_V4_OUT .network=BGP-LOCAL-NETS remote.address=10.200.1.1/32 .as=65534 router-id=\
10.200.1.3 routing-table=main templates=default use-bfd=no vrf=main
add chain=BGP-EDGER1.DC01_V4_IN disabled=no rule=accept
add chain=BGP-EDGER1.DC01_V4_OUT disabled=no rule=accept
Im not going to dump the table, as the edge is taking full routes however here is OSPF and an eBGP route(google):
ip route/print where dst-address=8.8.8.0/24
Flags: D - DYNAMIC; I, A - ACTIVE; b, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAb 8.8.8.0/24 184.105.63.33 20
/ip route/ print where ospf=yes
Flags: D - DYNAMIC; A - ACTIVE; o, y - COPY; + - ECMP
DAo 10.200.1.3/32 10.10.10.6%E1V0102-TRANSIT-CORE01.DC01 110
ip route print where connect=yes
Flags: D - DYNAMIC; A - ACTIVE; c, y - COPY
DAc 10.10.10.4/30 E1V0102-TRANSIT-CORE01.DC01 0
DAc 10.200.1.1/32 loopback 0
DAc 10.217.0.0/24 ether2 0
DAc 184.105.63.32/29 E1V0002-WAN-HURRICANE-ELECTRIC 0
Core / iBGP neighbor
iip route print
Flags: D - DYNAMIC; A - ACTIVE; c, s, o, d, y - COPY; + - ECMP
# DST-ADDRESS GATEWAY DISTANCE
DAc 10.10.10.4/30 E1V0102-TRANSIT-EDGER1.DC01 0
DAo 10.200.1.1/32 10.10.10.5%E1V0102-TRANSIT-EDGER1.DC01 110
DAc 10.200.1.3/32 loopback 0
As you can see, no routes are being advertised to the iBGP neighbor, I did confirm that the session is established on both ends. If I enable redistribution, it does push all of the routes as expected. I think there is some misconfiguration I made, but don’t see where specifically.
Thanks!
