Solution (for the moment)
I found a working - but not very good solution:
The trick is to define the adress-lists ONLY when the user has a functionl Connection - (i test by “connection-rate=500k-200M”)
add action=add-src-to-address-list address-list=Liste1 address-list-timeout=
14h chain=prerouting connection-mark=no-mark connection-rate=500k-200M
random=15 src-address=192.168.0.0/16 src-address-list=!Gesamt
Hope that helps others
# sep/13/2022 10:22:01 by RouterOS 7.5
# software id = 00X4-I7Y2
# model = CCR1009-8G-1S-1S+
# serial number = 5A1804B95DCC
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes \
protocol=tcp tcp-flags=syn
add action=change-mss chain=forward in-interface=all-ppp new-mss=1410 \
passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=1411-65535
add action=change-mss chain=forward new-mss=1410 out-interface=all-ppp \
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
MNET_VDSL300_1 log-prefix=Test new-connection-mark=MNET1 passthrough=no
VDSL175_1566_Telekom log-prefix=Test new-connection-mark=TKOM \
passthrough=no
MNET_VDSL300_2 log-prefix=Test new-connection-mark=MNET2 passthrough=no
add action=mark-routing chain=output connection-mark=TKOM new-routing-mark=\
TKOMrm passthrough=yes
add action=mark-routing chain=output connection-mark=MNET1 new-routing-mark=\
ToMNetVDSL1 passthrough=yes
add action=mark-routing chain=output connection-mark=MNET2 new-routing-mark=\
ToMNetVDSL2 passthrough=yes
add action=accept chain=prerouting connection-mark=no-mark dst-address=\
192.168.0.0/16
10.0.0.0/8
add action=jump chain=prerouting connection-mark=no-mark disabled=yes \
jump-target=ttt src-address=192.168.0.0/16 src-address-list=!Gesamt
add action=add-src-to-address-list address-list=Liste1 address-list-timeout=\
14h chain=prerouting connection-mark=no-mark connection-rate=500k-200M \
add action=add-src-to-address-list address-list=Gesamt address-list-timeout=\
14h chain=prerouting connection-mark=no-mark src-address=192.168.0.0/16 \
src-address-list=Liste1
add action=add-src-to-address-list address-list=Liste2 address-list-timeout=\
random=21 src-address=192.168.0.0/16 src-address-list=!Gesamt
src-address-list=Liste2
add action=add-src-to-address-list address-list=Liste3 address-list-timeout=\
random=23 src-address=192.168.0.0/16 src-address-list=!Gesamt
src-address-list=Liste3
add action=add-src-to-address-list address-list=Liste4 address-list-timeout=\
random=25 src-address=192.168.0.0/16 src-address-list=!Gesamt
src-address-list=Liste4
add action=add-src-to-address-list address-list=Liste5 address-list-timeout=\
random=6 src-address=192.168.0.0/16 src-address-list=!Gesamt
src-address-list=Liste5
add action=mark-routing chain=prerouting new-routing-mark=ToMNetVDSL1 \
passthrough=yes src-address=192.168.0.0/16 src-address-list=Liste1
add action=mark-routing chain=prerouting new-routing-mark=ToMNetVDSL2 \
passthrough=yes src-address=192.168.0.0/16 src-address-list=Liste2
add action=mark-routing chain=prerouting new-routing-mark=ToKabeld \
passthrough=yes src-address=192.168.0.0/16 src-address-list=Liste3
add action=mark-routing chain=prerouting new-routing-mark=ToEntertain \
passthrough=yes src-address=192.168.0.0/16 src-address-list=Liste4
add action=mark-routing chain=prerouting new-routing-mark=TKOMrm passthrough=\
yes src-address=192.168.0.0/16 src-address-list=Liste5
passthrough=yes src-address=10.0.0.0/8 src-address-list=ListePrivat
add action=mark-routing chain=prerouting connection-mark=no-mark disabled=yes \
new-routing-mark=TKOMrm passthrough=yes src-address=192.168.157.0/24
add action=mark-routing chain=prerouting connection-mark=MNET disabled=yes \
new-routing-mark=ToMNetVDSL passthrough=yes
add action=mark-routing chain=prerouting disabled=yes hotspot=!auth \
new-routing-mark=main passthrough=no
my COMPLETE Setup
# sep/13/2022 10:25:41 by RouterOS 7.5
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=XX frequency=\
2412 name=2GHz1
2437 name=2GHz6
2462 name=2GHz11
add band=5ghz-onlyac control-channel-width=20mhz name=5GHz reselect-interval=\
5h skip-dfs-channels=no
/interface pptp-client
add connect-to=88.217.185.150 disabled=no mrru=1600 name=C118 user=ema
add connect-to=217.7.253.232 disabled=no name=WW32_to user=emaneu
/interface pptp-server
add name=IN_PPTP user=""
add fast-forward=no name=BRG10_200
add add-dhcp-option82=yes dhcp-snooping=yes fast-forward=no name=BRG_FENDT
add add-dhcp-option82=yes dhcp-snooping=yes fast-forward=no name=BRG_Student
add add-dhcp-option82=yes dhcp-snooping=yes name=Test
set [ find default-name=ether1 ] l2mtu=1588 name=ETH01_Zuleitung speed=\
100Mbps
set [ find default-name=ether2 ] l2mtu=1588 name=ETH02_Zyxel_neu speed=\
100Mbps
set [ find default-name=ether3 ] l2mtu=1588 name=ETH03_Videoueberwachung \
speed=100Mbps
set [ find default-name=ether4 ] disabled=yes l2mtu=1588 name=\
ETH04_100MBit_toMNET_VDSL1 speed=100Mbps
set [ find default-name=ether5 ] disabled=yes l2mtu=1590 name=\
ETH05_100MBit_toMNET_VDSL2 speed=100Mbps
set [ find default-name=ether6 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full l2mtu=1590 \
name=ETH06_2500MBit_toTK_2020/05_Phys speed=100Mbps
set [ find default-name=ether7 ] advertise=\
10M-full,100M-full,1000M-half,1000M-full full-duplex=no l2mtu=1590 name=\
ETH07_VDSL300_1 speed=100Mbps
set [ find default-name=ether8 ] advertise=\
name=ETH08_VDSL300_2 speed=100Mbps
set [ find default-name=sfp1 ] advertise=10M-full,100M-full,1000M-full l2mtu=\
1590
set [ find default-name=sfp-sfpplus1 ] advertise=\
10M-full,100M-full,1000M-full l2mtu=1590 name=sfpplus-to-mainswitch
/interface sstp-server
add name=IN_STP user=""
/interface eoip
add allow-fast-path=no arp=proxy-arp disabled=yes local-address=10.0.1.1 \
mac-address=02:55:F2:89:68:95 name=eoip-WW32 remote-address=192.168.1.1 \
tunnel-id=0
/interface vlan
add interface=ETH06_2500MBit_toTK_2020/05_Phys name=\
"E6V7_Modem_Telekom 175_2020/05" vlan-id=7
add interface=ETH01_Zuleitung name=VLAN1V1 vlan-id=1
add interface=ETH01_Zuleitung name=VLAN1V2_Fendt vlan-id=2
add interface=ETH01_Zuleitung name=VLAN1V4_Student2 vlan-id=4
add interface=ETH01_Zuleitung name=VLAN1V5_Student3 vlan-id=5
add interface=ETH01_Zuleitung name=VLAN1V99 vlan-id=99
add interface=sfpplus-to-mainswitch name=VLAN1_SFP_Student vlan-id=1
add interface=ETH02_Zyxel_neu name=VLAN2V1_StudentMain vlan-id=1
add interface=ETH02_Zyxel_neu name=VLAN2V2_Fendt_Main vlan-id=2
add interface=ETH02_Zyxel_neu name=VLAN2V99_Test vlan-id=99
add interface=sfpplus-to-mainswitch name=VLAN2_FendtSFP vlan-id=2
add interface=ETH07_VDSL300_1 name=VLAN_40_7 vlan-id=40
add interface=ETH08_VDSL300_2 name=VLAN_40_8 vlan-id=40
add interface=sfpplus-to-mainswitch name=vlan99_Service_SFP vlan-id=99
/caps-man datapath
add bridge=BRG_FENDT client-to-client-forwarding=yes local-forwarding=no \
name=LocalFendt
add bridge=BRG_Student client-to-client-forwarding=yes local-forwarding=no \
name=VLAN222
add bridge=BRG10_200 name=Bridge
/interface pppoe-client
add add-default-route=yes default-route-distance=4 disabled=no interface=\
VLAN_40_7 name=MNET_VDSL300_1 use-peer-dns=yes user=\
XXXXXXXXXXXXXXX
add add-default-route=yes default-route-distance=3 disabled=no interface=\
VLAN_40_8 name=MNET_VDSL300_2 user=XXXXXXXXXXX
/caps-man rates
add basic=12Mbps ht-basic-mcs="" ht-supported-mcs="" name=rate1 supported=\
12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs="" \
vht-supported-mcs=""
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip name=\
fendtprivat
student
add authentication-types="" encryption="" name=free
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip name=Bridge
/caps-man configuration
add channel.band=2ghz-onlyn .control-channel-width=20mhz .extension-channel=\
XX .reselect-interval=6h40m .tx-power=0 country=germany datapath=\
LocalFendt datapath.bridge=BRG_FENDT .local-forwarding=no max-sta-count=\
40 mode=ap name=CFG_FENDT rates=rate1 security=fendtprivat ssid=\
FENDT_2017CAP
add datapath=VLAN222 datapath.bridge=BRG_Student name=Student_1 security=\
student ssid=STUDENT_SLOW
add datapath=VLAN222 datapath.bridge=BRG_Student name=StudentFree security=\
free ssid=STUDENT_SLOW_FREE
add channel=5GHz channel.band=5ghz-a/n .reselect-interval=12h10m country=\
germany datapath=LocalFendt datapath.bridge=BRG_FENDT .local-forwarding=\
no max-sta-count=30 mode=ap name=CFG_Fendt5GHz security=fendtprivat ssid=\
FENDT_2017CAP5
add datapath=VLAN222 datapath.bridge=BRG_Student name=Student5free security=\
free ssid=STUDENT_CAP5_FREE
add datapath=VLAN222 datapath.bridge=BRG_Student name=Student_51 security=\
student ssid=STUDENT_CAP5
add channel=5GHz channel.reselect-interval=12h40m country=germany datapath=\
90 mode=ap name=CFG_Fendt_AC security=fendtprivat ssid=FENDT_2017CAP5AC
add datapath=VLAN222 datapath.bridge=BRG_Student name=Student5AC_Free \
security=free ssid=STUDENT_CAP5AC_FREE
add datapath=VLAN222 datapath.bridge=BRG_Student name=Student_5AC security=\
student ssid=STUDENT_CAP5AC
add datapath=Bridge datapath.bridge=BRG10_200 name=BridgeHof security=\
fendtprivat ssid=BRG_HOF
add channel=5GHz channel.band=5ghz-onlyac .extension-channel=XX \
.reselect-interval=20h40m .skip-dfs-channels=yes country=germany \
datapath=LocalFendt datapath.bridge=BRG_FENDT .local-forwarding=no \
distance=2 hw-retries=0 max-sta-count=40 mode=ap name=BRG rates=rate1 \
security=fendtprivat ssid=BRG_FENDT
add exclude=dynamic name=discover
add name=wan
/interface lte apn
set [ find default=yes ] supplicant-identity=EMA18_2015
/ip dhcp-server option
add code=66 name=boot value="'10.8.0.10'"
/ip dhcp-server option sets
add name=set1 options=boot
/ip hotspot profile
set [ find default=yes ] radius-interim-update=20m use-radius=yes
add dns-name=hotspot.info hotspot-address=192.168.178.1 http-cookie-lifetime=\
5d login-by=cookie,http-chap,http-pap,mac-cookie name=WLAN_VLAN222 \
radius-interim-update=20m radius-location-id=WLANEMA rate-limit=\
"30k/50k 60k/300k 10k/10k 20/20 8" use-radius=yes
add hotspot-address=192.168.178.1 login-by=cookie,http-chap,https,http-pap \
name=hsprof1
/ip hotspot user profile
set [ find default=yes ] idle-timeout=2h keepalive-timeout=2h rate-limit=\
"402k/12M 600k/25M 160k/3M 40/40 8 140k/800k" session-timeout=10h \
shared-users=4
add idle-timeout=2h keepalive-timeout=2h name=HSP_Kabel_V1 rate-limit=\
shared-users=4
add idle-timeout=2h keepalive-timeout=2h name=HSP_KabelV4 rate-limit=\
shared-users=4
add idle-timeout=2h keepalive-timeout=2h name=HSP_KavelV5 rate-limit=\
shared-users=4
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=10_204 ranges=10.0.204.100-10.0.204.200
add name=STUDENTPPoE ranges=192.168.136.10-192.168.136.254
add name=Fendt ranges=10.0.1.100-10.0.1.254
add name=WLAN_2 ranges=192.168.179.2-192.168.179.254
add name=WLAN_Komplett next-pool=WLAN_2 ranges=192.168.178.2-192.168.178.240
add name=Pool_VLan5 ranges=192.168.139.10-192.168.139.254
add name=Pool_VLan4 ranges=192.168.137.10-192.168.137.254
add name=Pool2_Vlan1 ranges=192.168.133.10-192.168.133.254
add name=pool1 ranges=10.1.1.2-10.1.1.250
add address-pool=WLAN_Komplett always-broadcast=yes interface=BRG_Student \
lease-time=4h name=Global_wlan
add address-pool=Fendt authoritative=after-10sec-delay interface=BRG_FENDT \
lease-time=1w3d name=Fendt
/ip hotspot
add address-pool=WLAN_Komplett disabled=no interface=BRG_Student name=\
hotspot1 profile=WLAN_VLAN222
add name=Pool_VLAN1 next-pool=Pool2_Vlan1 ranges=\
192.168.138.10-192.168.138.254
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add change-tcp-mss=yes name=DSL_PPPoE
add change-tcp-mss=yes name=TelekomVDSLProfil
add bridge=BRG10_200 name=PROF_10_200
add change-tcp-mss=yes dns-server=192.168.136.1,8.8.8.8 local-address=\
192.168.136.1 name=Profil_PPoE_STUDENT remote-address=STUDENTPPoE \
session-timeout=22h use-encryption=yes
add dns-server=192.168.138.1,8.8.8.8 local-address=192.168.138.1 name=\
HOTSPOTIN only-one=no rate-limit=\
"399k/12M 600k/25M 160k/3M 40/40 8 140k/800k" remote-address=Pool_VLAN1
add bridge=BRG10_200 change-tcp-mss=yes name=UNVERSCHL-10-200 \
use-compression=no use-encryption=no use-mpls=yes
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=192.168.138.1 name=\
test remote-address=Pool_VLAN1 use-encryption=yes
add connect-to=176.10.119.57 disabled=no name=Schweiz profile=default user=\
emanuel
add add-default-route=yes default-route-distance=2 interface=\
"E6V7_Modem_Telekom 175_2020/05" keepalive-timeout=60 max-mru=1480 \
max-mtu=1480 mrru=1600 name=ALTBussines profile=TelekomVDSLProfil user=\
feste-ip2/XXXXXXXXX@XXXXXXXX.de
add add-default-route=yes disabled=no interface=\
max-mtu=1480 mrru=1600 name=VDSL175_1566_Telekom profile=\
TelekomVDSLProfil user=XXXXXXXXXXXXX@t-online.de
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=no instance=default-v2 name=backbone-v2
/routing table
add disabled=no fib name=ToMNetVDSL1
add fib name=ToKabeld
add fib name=ToEntertain
add fib name=ToMNetVDSL2
add fib name=TKOMrm
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
set 1 disk-file-name=""
set 3 remote=192.168.1.20
/caps-man aaa
set interim-update=20h
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=/pub \
upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
BRG name-format=prefix-identity name-prefix=BRG5AC_ radio-mac=\
D4:CA:6D:C6:18:4B slave-configurations=Student5AC_Free,Student_5AC
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
CFG_FENDT name-format=prefix-identity name-prefix=2GHZ radio-mac=\
00:0C:42:66:30:16 slave-configurations=Student_1,StudentFree
CFG_Fendt_AC name-format=prefix-identity name-prefix=5AC_ \
slave-configurations=Student_5AC,Student5AC_Free
add action=create-dynamic-enabled hw-supported-modes=an master-configuration=\
CFG_Fendt5GHz name-format=prefix-identity name-prefix=5GHZ \
slave-configurations=Student_51,Student5free
CFG_FENDT name-format=prefix-identity name-prefix=2GHZ \
add action=create-dynamic-enabled master-configuration=CFG_FENDT name-format=\
prefix-identity name-prefix=XXx slave-configurations=\
add bridge=BRG_FENDT disabled=yes ingress-filtering=no interface=\
add bridge=BRG_FENDT ingress-filtering=no interface=VLAN1V2_Fendt trusted=yes
add bridge=BRG_FENDT ingress-filtering=no interface=VLAN2V2_Fendt_Main \
trusted=yes
add bridge=Test ingress-filtering=no interface=VLAN2V99_Test trusted=yes
add bridge=Test ingress-filtering=no interface=VLAN1V99 trusted=yes
add bridge=BRG_Student ingress-filtering=no interface=VLAN2V1_StudentMain \
trusted=yes
add bridge=BRG_Student ingress-filtering=no interface=VLAN1V1 trusted=yes
add bridge=BRG_FENDT ingress-filtering=no interface=VLAN2_FendtSFP trusted=\
yes
add bridge=BRG_Student ingress-filtering=no interface=VLAN1_SFP_Student \
trusted=yes
sfpplus-to-mainswitch trusted=yes
set enabled=yes generic-timeout=2h icmp-timeout=13s udp-stream-timeout=6m \
udp-timeout=30s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=1024
add interface=sfpplus-to-mainswitch list=discover
add interface=sfp1 list=discover
add interface=ETH01_Zuleitung list=discover
add interface=ETH02_Zyxel_neu list=discover
add interface=ETH03_Videoueberwachung list=discover
add interface=ETH04_100MBit_toMNET_VDSL1 list=discover
add interface=ETH05_100MBit_toMNET_VDSL2 list=discover
add interface=ETH06_2500MBit_toTK_2020/05_Phys list=discover
add interface=ETH07_VDSL300_1 list=discover
add interface=ETH08_VDSL300_2 list=discover
add interface=BRG10_200 list=discover
add interface=BRG_FENDT list=discover
add interface=BRG_Student list=discover
add interface=IN_STP list=discover
add interface=IN_PPTP list=discover
add interface="E6V7_Modem_Telekom 175_2020/05" list=discover
add interface=*12 list=discover
add interface=*13 list=discover
add interface=VLAN1V1 list=discover
add interface=*15 list=discover
add interface=*1A list=discover
add interface=VDSL175_1566_Telekom list=discover
add interface=*1C list=discover
add interface=*1D list=discover
add interface=WW32_to list=discover
add interface=Schweiz list=discover
add interface=C118 list=discover
add interface=ALTBussines list=discover
/interface ovpn-server server
set auth=sha1,md5 certificate=CAPsMAN-CA-9A2E04FDC6DC default-profile=\
default-encryption
/interface pppoe-server server
add authentication=pap,chap default-profile=Profil_PPoE_STUDENT disabled=no \
interface=BRG_Student max-mru=1480 max-mtu=1480 service-name=PPPoE_V1
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=pap,chap default-profile=PROF_10_200 enabled=yes max-mru=\
1460 max-mtu=1460
/interface sstp-server server
set default-profile=PROF_10_200 enabled=yes
add address=10.0.1.1/24 interface=BRG_FENDT network=10.0.1.0
add address=192.168.178.1/24 interface=BRG_Student network=192.168.178.0
add address=192.168.179.1/24 interface=BRG_Student network=192.168.179.0
add address=192.168.138.1/24 interface=VLAN1V1 network=192.168.138.0
add address=192.168.136.1/24 disabled=yes interface=BRG_Student network=\
192.168.136.0
add address=192.168.137.1/24 interface=VLAN1V4_Student2 network=192.168.137.0
add address=192.168.139.1/24 interface=VLAN1V5_Student3 network=192.168.139.0
add address=192.168.133.1/24 interface=VLAN1V1 network=192.168.133.0
add address=192.168.99.1/24 interface=Test network=192.168.99.0
add address=192.168.1.9/24 disabled=yes interface=ETH01_Zuleitung network=\
192.168.1.0
add address=192.168.99.91/24 interface=vlan99_Service_SFP network=\
192.168.99.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=yes interface=ETH01_Zuleitung
add default-route-distance=2 disabled=yes interface=ETH07_VDSL300_1
add default-route-distance=10 disabled=yes interface=\
add default-route-distance=88 disabled=yes interface=\
/ip dhcp-server alert
add disabled=no interface=BRG_FENDT
add disabled=no interface=BRG_Student
/ip dhcp-server lease
add address=10.0.1.53 client-id=1:0:b:82:48:cf:59 mac-address=\
00:0B:82:48:CF:59 server=Fendt
add address=10.0.1.44 client-id=1:d4:ca:6d:25:f2:7c mac-address=\
D4:CA:6D:25:F2:7C server=Fendt
add address=10.0.1.50 client-id=1:d4:ca:6d:c6:18:4a mac-address=\
D4:CA:6D:C6:18:4A server=Fendt
add address=10.0.1.45 client-id=1:6c:3b:6b:7e:0:bc mac-address=\
6C:3B:6B:7E:00:BC server=Fendt
add address=10.0.1.47 client-id=1:e4:8d:8c:72:b4:58 mac-address=\
E4:8D:8C:72:B4:58 server=Fendt
add address=10.0.1.46 client-id=1:64:d1:54:4f:11:b5 mac-address=\
64:D1:54:4F:11:B5 server=Fendt
add address=10.0.1.62 client-id=1:6c:3b:6b:87:87:80 mac-address=\
6C:3B:6B:87:87:80 server=Fendt
add address=10.0.1.104 client-id=1:74:ac:b9:d8:52:5d mac-address=\
74:AC:B9:D8:52:5D server=Fendt
add address=10.0.1.105 client-id=1:b4:fb:e4:9f:dc:2c mac-address=\
B4:FB:E4:9F:DC:2C server=Fendt
add address=10.0.1.102 client-id=1:18:e8:29:8:40:c9 mac-address=\
18:E8:29:08:40:C9 server=Fendt
add address=10.0.1.103 client-id=1:e0:63:da:1:26:ac mac-address=\
E0:63:DA:01:26:AC server=Fendt
add address=10.0.1.113 client-id=1:70:b3:d5:dc:84:f2 mac-address=\
70:B3:D5:DC:84:F2 server=Fendt
add address=10.0.1.122 client-id=1:b8:69:f4:2:9c:28 mac-address=\
B8:69:F4:02:9C:28 server=Fendt
add address=10.0.1.131 client-id=1:b4:fb:e4:9f:d9:2c mac-address=\
B4:FB:E4:9F:D9:2C server=Fendt
add address=10.0.1.116 client-id=1:e0:63:da:1:28:63 mac-address=\
E0:63:DA:01:28:63 server=Fendt
add address=10.0.1.117 client-id=1:c:11:5:11:1e:cc mac-address=\
0C:11:05:11:1E:CC server=Fendt
add address=10.0.1.118 client-id=1:c:11:5:f:a0:a7 mac-address=\
0C:11:05:0F:A0:A7 server=Fendt
add address=10.0.1.141 client-id=1:64:d1:54:4f:10:1d mac-address=\
64:D1:54:4F:10:1D server=Fendt
add address=10.0.1.110 client-id=1:e8:37:7a:9f:9b:7c mac-address=\
E8:37:7A:9F:9B:7C server=Fendt
add address=10.0.1.139 mac-address=3C:61:05:F0:5A:CD server=Fendt
add address=10.0.1.142 mac-address=34:AB:95:1C:0F:5E server=Fendt
add address=10.0.1.25 client-id=1:b8:ec:a3:ab:dc:f8 mac-address=\
B8:EC:A3:AB:DC:F8 server=Fendt
add address=10.0.1.150 client-id=1:70:b3:d5:dc:84:f5 mac-address=\
70:B3:D5:DC:84:F5 server=Fendt
add address=10.0.1.0/24 caps-manager=10.0.1.1 dhcp-option=boot \
dhcp-option-set=set1 dns-server=10.0.1.1,8.8.8.8 gateway=10.0.1.1 \
ntp-server=10.0.1.1
add address=10.0.204.0/24 dns-server=10.0.204.1 gateway=10.0.204.1 netmask=24
add address=192.168.137.0/24 caps-manager=192.168.137.1 comment=\
"Kabel und Mikrotik WLAN" dhcp-option=boot dhcp-option-set=set1 \
dns-server=192.168.137.1 gateway=192.168.137.1 ntp-server=192.168.137.1
add address=192.168.138.0/24 caps-manager=192.168.138.1 dhcp-option=boot \
dhcp-option-set=set1 dns-server=192.168.138.1 gateway=192.168.138.1 \
ntp-server=192.168.138.1
add address=192.168.139.0/24 caps-manager=192.168.139.1 dhcp-option=boot \
dhcp-option-set=set1 dns-server=192.168.139.1 gateway=192.168.139.1 \
ntp-server=192.168.139.1
add address=192.168.178.0/24 caps-manager=192.168.178.1 comment="UNIFI WLAN" \
dhcp-option=boot dhcp-option-set=set1 dns-server=\
192.168.178.1,8.8.8.8,8.8.4.4 gateway=192.168.178.1
add address=192.168.179.0/24 caps-manager=192.168.179.1 dhcp-option=boot \
dhcp-option-set=set1 dns-server=192.168.179.1,8.8.8.8,8.8.4.4 gateway=\
192.168.179.1
set allow-remote-requests=yes max-udp-packet-size=512 servers=8.8.8.8
/ip dns static
add address=10.8.0.105 name=unifi ttl=1h
add address=192.168.178.1 name=hotspot
add address=10.0.1.1 name=router
add address=10.8.0.2 name=immo-fendt.de
add address=10.8.0.2 name=android.studentenwohnheime-muc.de
add address=10.8.0.10 name=pbx.local
add address=10.8.0.2 name=data.bbasic ttl=1h
add address=10.8.0.2 name=sql.bbasic ttl=1h
add address=10.8.0.10 name=telefon.bbasic ttl=1h
add address=192.168.178.1 name=hotspot.info
/ip firewall address-list
add address=10.0.1.0/24 list=ListePrivat
add address=10.0.0.0/8 list=DNSOK
add address=192.168.0.0/16 list=DNSOK
add address=8.8.8.8 list=DNSOK
add address=10.7.1.120 list=DNS
add address=192.168.0.0/16 list=SIP
add address=10.0.0.0/8 list=SIP
add address=217.10.79.9 list=SIP
add address=80.237.128.10 list=DNS
add address=10.0.0.0/8 list=Intern
add address=192.168.1.0/24 list=Intern
add address=217.10.68.0/24 list=SIP
add address=proxy.live.sipgate.de list=SIP
add address=sipgate.de list=SIP
add address=217.7.253.232 list=SIP
add address=217.7.253.232 list=DNS
add address=sipconnect.sipgate.de list=SIP
add address=217.7.253.232 list=Intern
add address=192.168.0.0/16 list=Intern
add action=accept chain=forward dst-address=10.0.0.0/8 src-address=10.0.0.0/8
add action=accept chain=input dst-address=10.0.0.0/8 src-address=10.0.0.0/8
add action=accept chain=forward dst-address=192.168.0.0/16 src-address=\
10.0.0.0/8
add action=accept chain=input dst-address=192.168.0.0/16 src-address=\
10.0.0.0/8
add action=tarpit chain=input disabled=yes dst-port=80,21 protocol=tcp \
src-address-list=!Intern
add action=accept chain=input dst-port=53 protocol=udp src-address-list=DNSOK
add action=accept chain=input dst-port=53 protocol=tcp src-address-list=DNSOK
add action=reject chain=input dst-port=53 protocol=udp reject-with=\
icmp-admin-prohibited src-address-list=!DNSOK
add action=reject chain=input dst-port=53 protocol=tcp reject-with=\
add action=accept chain=input disabled=yes dst-address=192.168.0.0/16 \
add action=accept chain=output disabled=yes dst-address=192.168.0.0/16 \
add action=accept chain=forward src-address=10.0.0.0/8
add action=accept chain=input src-address=10.0.0.0/8
add action=accept chain=output src-address=10.0.0.0/8
add action=accept chain=output dst-address=10.0.0.0/8
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
192.168.0.0/16
add action=accept chain=forward dst-address=10.0.0.0/8 src-address=\
192.168.0.0/16
add action=accept chain=input dst-address=10.0.0.0/8 src-address=\
192.168.0.0/16
add action=drop chain=input dst-port=161-162 protocol=udp src-address-list=\
!Intern
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
address-list-timeout=1w3d chain=input connection-state="" dst-port=22 \
protocol=tcp src-address-list=!Intern
add action=add-src-to-address-list address-list=ssh_stage3 \
address-list-timeout=15m chain=input connection-state=new dst-port=22 \
protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
protocol=tcp
add action=drop chain=input dst-port=53 protocol=tcp src-address-list=!DNSOK
add action=drop chain=input dst-port=53 protocol=udp src-address-list=!DNSOK
/ip firewall mangle
passthrough=no
192.168.0.0/16
10.0.0.0/8
add action=masquerade chain=srcnat disabled=yes dst-address=10.0.1.1 \
protocol=tcp
add action=dst-nat chain=dstnat disabled=yes dst-address=10.0.1.1 dst-port=\
888 protocol=tcp src-address=192.168.1.41 to-addresses=192.168.99.3 \
to-ports=23
add action=dst-nat chain=dstnat dst-port=53 protocol=udp to-addresses=\
10.0.1.1
add action=accept chain=srcnat dst-address=10.0.0.0/8 src-address=10.0.0.0/8
add action=accept chain=srcnat dst-address=192.168.0.0/16 src-address=\
10.0.0.0/8
add action=accept chain=srcnat dst-address=10.0.0.0/8 src-address=\
192.168.0.0/16
"place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=accept chain=srcnat dst-address=10.0.3.0/24 src-address=\
10.0.200.0/24
add action=masquerade chain=srcnat src-address=192.168.136.0/24
add action=masquerade chain=srcnat src-address=192.168.133.0/24
add action=masquerade chain=srcnat src-address=192.168.138.0/24
add action=masquerade chain=srcnat src-address=192.168.137.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=192.168.178.0/24 to-addresses=0.0.0.0
add action=masquerade chain=srcnat src-address=192.168.179.0/24 to-addresses=\
0.0.0.0
add action=dst-nat chain=dstnat disabled=yes dst-address=10.0.1.1 dst-port=81 \
protocol=tcp src-address=192.168.1.41 to-addresses=192.168.99.4 to-ports=\
80
add action=masquerade chain=srcnat out-interface=MNET_VDSL300_1
add action=masquerade chain=srcnat out-interface=VDSL175_1566_Telekom
add action=masquerade chain=srcnat out-interface=MNET_VDSL300_2
/ip firewall service-port
set pptp ports=1723
/ip hotspot user
add name=admin
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
add dst-host=support.bbasic.de dst-port=7615
add dst-host=www.studentenwohnheime-muc.de
add dst-host=studentenwohnheime-muc.de
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=8.8.8.8
add action=accept disabled=no dst-address=192.168.138.0/24
add action=accept disabled=no dst-address=192.168.179.0/24
add action=accept disabled=no dst-address=192.168.137.0/24
add action=accept disabled=no dst-address=192.168.139.0/24
add action=accept disabled=no dst-address=192.168.136.0/24 !dst-port \
!protocol !src-address
add action=accept disabled=no dst-address=192.168.133.0/24 !dst-port \
add action=accept disabled=no dst-address=10.7.1.10 !dst-port !protocol \
!src-address
add disabled=no distance=4 dst-address=192.168.0.0/16 gateway=Schweiz
add check-gateway=ping disabled=yes distance=6 dst-address=10.0.0.0/8 \
gateway=192.168.1.1 scope=10 target-scope=11
add check-gateway=ping disabled=no distance=5 dst-address=10.0.0.0/8 gateway=\
10.0.202.1 scope=10 target-scope=11
add check-gateway=ping disabled=no distance=5 dst-address=192.168.1.0/24 \
gateway=10.0.202.1 scope=10 target-scope=11
add disabled=no dst-address=10.0.1.0/24 gateway=BRG_FENDT
add disabled=no distance=2 dst-address=10.0.2.0/24 gateway=Schweiz
add disabled=no distance=2 dst-address=10.0.6.0/24 gateway=Schweiz
add disabled=no distance=2 dst-address=10.0.9.0/24 gateway=Schweiz
add disabled=no distance=4 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_2 \
pref-src=0.0.0.0 routing-table=TKOMrm scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=3 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_1 \
pref-src=0.0.0.0 routing-table=ToMNetVDSL2 scope=30 suppress-hw-offload=\
no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_2 \
no target-scope=10
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_2 \
pref-src=0.0.0.0 routing-table=ToMNetVDSL1 scope=30 suppress-hw-offload=\
no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=VDSL175_1566_Telekom \
target-scope=10
target-scope=10
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_1 \
pref-src=0.0.0.0 routing-table=ToEntertain scope=30 suppress-hw-offload=\
no target-scope=10
add disabled=no distance=4 dst-address=0.0.0.0/0 gateway=VDSL175_1566_Telekom \
no target-scope=10
routing-table=ToKabeld suppress-hw-offload=no
pref-src=0.0.0.0 routing-table=ToKabeld scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_1 \
no target-scope=10
add disabled=no distance=6 dst-address=0.0.0.0/0 gateway=VDSL175_1566_Telekom \
no target-scope=10
add disabled=no dst-address=10.0.0.0/8 gateway=Schweiz routing-table=main \
add disabled=no distance=1 dst-address=10.8.0.0/16 gateway=WW32_to \
routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=10.5.0.0/16 gateway=C118 \
add disabled=no distance=2 dst-address=10.5.0.0/16 gateway=Schweiz pref-src=\
0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=\
10
add disabled=no distance=4 dst-address=10.5.0.0/16 gateway=WW32_to pref-src=\
10
add disabled=no distance=1 dst-address=10.7.0.0/16 gateway=Schweiz \
add disabled=no distance=5 dst-address=10.7.0.0/16 gateway=WW32_to pref-src=\
10
add disabled=no distance=5 dst-address=10.8.0.0/16 gateway=Schweiz \
add disabled=no distance=6 dst-address=10.8.0.0/16 gateway=C118 pref-src=\
10
add disabled=no distance=3 dst-address=0.0.0.0/0 gateway=MNET_VDSL300_2 \
no target-scope=10
add disabled=no distance=1 dst-address=192.168.178.0/24 gateway=BRG_Student \
routing-table=ToMNetVDSL1 scope=10 suppress-hw-offload=no
pref-src=0.0.0.0 routing-table=ToMNetVDSL2 scope=10 suppress-hw-offload=\
no target-scope=10
pref-src=0.0.0.0 routing-table=TKOMrm scope=10 suppress-hw-offload=no \
target-scope=10
pref-src=0.0.0.0 routing-table=ToMNetVDSL scope=10 suppress-hw-offload=no \
target-scope=10
/ip service
set telnet disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp aaa
set interim-update=1m use-circuit-id-in-nas-port-id=yes use-radius=yes
/ppp secret
add local-address=10.0.200.1 name=C118 profile=PROF_10_200 remote-address=\
10.0.200.3
add disabled=yes local-address=10.0.200.1 name=haag profile=PROF_10_200 \
remote-address=10.0.200.6 routes=10.0.11.0/24
add local-address=10.0.200.1 name=Gabel profile=PROF_10_200 remote-address=\
10.0.200.7 routes=10.0.2.0/24
add local-address=10.0.200.1 name=WW32 profile=PROF_10_200 remote-address=\
10.0.200.10 routes=192.168.1.0/24
add disabled=yes local-address=10.0.200.1 name=g91_rb2011_1 profile=\
PROF_10_200 remote-address=10.0.200.5 routes=10.0.2.0/24
add local-address=10.0.200.1 name=ufrb2011 profile=PROF_10_200 \
remote-address=10.0.200.8 routes=10.0.3.0/24
add disabled=yes local-address=10.0.200.1 name=pftp_tutzing profile=\
PROF_10_200 remote-address=10.0.200.9 routes=192.168.82.0/24
add disabled=yes local-address=10.0.200.1 name=paehl profile=PROF_10_200 \
remote-address=10.0.200.11 routes=192.168.9.0/24
add local-address=10.0.200.1 name=C127 profile=PROF_10_200 remote-address=\
10.0.200.13 routes=10.0.6.0/24
add disabled=yes local-address=10.0.200.1 name=GautingServer profile=\
PROF_10_200 remote-address=10.0.200.15
add disabled=yes local-address=10.0.200.1 name=contabo1 profile=PROF_10_200 \
remote-address=10.0.200.16
add local-address=10.0.200.1 name=dresden profile=PROF_10_200 remote-address=\
10.0.200.17
add local-address=10.0.200.1 name=pontre profile=PROF_10_200 remote-address=\
10.0.200.18
add local-address=10.0.200.1 name=Margot profile=PROF_10_200 remote-address=\
10.0.200.15 routes=10.0.9.0/24
/radius
add address=10.8.0.2 realm=STUDENT service=ppp,hotspot,wireless src-address=\
10.0.1.1 timeout=1s500ms
add address=10.8.0.82 realm=STUDENT service=ppp,hotspot,wireless src-address=\
add address=10.8.0.30 realm=STUDENT service=ppp,hotspot,wireless src-address=\
add address=10.0.9.98 realm=STUDENT service=ppp,hotspot,wireless src-address=\
/radius incoming
set accept=yes
/routing ospf interface-template
add area=backbone-v2 auth-id=1 auth-key="" cost=10 disabled=no interfaces=\
BRG_FENDT networks=10.0.1.0/24 priority=1
/routing rule
add action=lookup disabled=no routing-mark=TKOMrm table=TKOMrm
add action=lookup disabled=no dst-address=0.0.0.0/0 routing-mark=ToMNetVDSL1 \
table=ToMNetVDSL1
add action=lookup disabled=no dst-address=0.0.0.0/0 routing-mark=ToMNetVDSL2 \
table=ToMNetVDSL2
add action=lookup disabled=no routing-mark=ToEntertain table=ToEntertain
add action=lookup disabled=no routing-mark=ToMNetVDSL table=ToMNetVDSL
add action=lookup disabled=no routing-mark=ToKabeld table=ToKabeld
add action=lookup-only-in-table disabled=no dst-address=192.168.0.0/16 table=\
main
/snmp
set enabled=yes location=EMA_Keller_Schaltschrank
/system clock
/system identity
set name=EManuel
/system leds
set 0 interface=sfpplus-to-mainswitch
set 1 interface=sfpplus-to-mainswitch
set 2 interface=sfp1
/system logging
add topics=hotspot
add disabled=yes topics=firewall
add disabled=yes topics=caps
add disabled=yes topics=ppp
add disabled=yes topics=bridge
add action=remote topics=error
add action=remote topics=warning
add action=remote topics=critical
/system ntp client
set enabled=yes
/system ntp client servers
add address=162.159.200.1
add address=84.16.73.33
/system scheduler
add interval=1w name=sched_backup on-event=backup policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
feb/17/2012 start-time=19:13:49
add disabled=yes interval=2h name=UpdateIPs on-event=\
"/system script run updateIP" policy=\
feb/17/2012 start-time=19:19:00
add disabled=yes interval=1d name=Reboot on-event=reboot policy=\
oct/01/2012 start-time=04:42:42
add interval=30m name=a on-event=ip policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-time=startup
/system script
add dont-require-permissions=no name=backup owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/export\
\_file=([/system identity get name] . \"-\" . \\\
\n[:pick [/system clock get date] 7 11] . [:pick [/system clock get date] \
0 3] . [:pick [/system clock get date] 4 6]); \\\
\n/tool e-mail send to=\"backup@XXXXX.de\" subject=([/system identi\
ty get name] . \" Backup \" . \\\
\n[/system clock get date]) file=([/system identity get name] . \"-\" . [:\
pick [/system clock get date] 7 11] . \\\
\n[:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4\
\_6] . \".rsc\"); :delay 10; \\\
\n/file rem [/file find name=([/system identity get name] . \"-\" . [:pick\
\_[/system clock get date] 7 11] . \\\
\_6] . \".rsc\")]; \\\
\n:log info (\"System Backup emailed at \" . [/sys cl get time] . \" \" . \
[/sys cl get date])"
add dont-require-permissions=no name=updateIP owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":local \
edinterface \"MNET_VDSL2\"\r\
\n\r\
\n:local edip [ /ip address get [/ip address find interface=\$edinterface \
] address ]\r\
\n:global previousIP\r\
\n\r\
\n\r\
\n# strip off netmask correctly (MRz)\r\
\n :for i from=( [:len \$edip] - 1) to=0 do={ \r\
\n :if ( [:pick \$edip \$i] = \"/\") do={ \r\
\n\t :set edip [:pick \$edip 0 \$i];\r\
\n } \r\
\n }\r\
\n\r\
\n\r\
\n# print some debug info\r\
\n#:log info (\"dyndns-update: IP \$edinterface = \$edip\")\r\
\n\r\
\n# get the current IP address from the internet (in case of double-nat)\r\
\n\r\
\n /tool fetch url=\"http://www.studentenwohnheime-muc.de/regip.php\?id=51\
&ip=\$edip\" mode=http dst-path=\"ip1\"\r\
\n\r\
\n\r\
\n"
add dont-require-permissions=no name=reboot owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive source=\
"/system reboot"
add dont-require-permissions=no name=ip owner=admin policy=\
reboot,read,write,policy,test,password,sniff,sensitive source="{/tool fetc\
h url=(\"http://www.boss-ip.com/Core/Update.ashx\\\?key=85454d8bb84998fa&a\
ction=upload&sncode=77E954CDDEB69048B3BB40650034EBBF&dynamic=static\")}"
/system watchdog
set ping-start-after-boot=7h5m watch-address=10.8.0.1
/tool bandwidth-server
set authenticate=no
/tool e-mail
set address=smartmail.XXXXXX.de from=<ema@XXXXXX.de> user=\
oliver@XXXXXXXX.de
/tool romon
set enabled=yes
/tool romon port
add
