V7.5 VPNv4 Route Reflector Problem
Hello wonderful community…
I have been testing out v7.5. I tried to implement a L3VPN setup. Either I am doing something wrong or Mikrotik has not developed yet the code correctly.
I noticed when I enable the ibgp-rr role on the RR router tx-messages and rx-messages go crazy, it’s like bgp looping some how.
If someone could take a look at my exports and tell If it is a mikrotik bug, or if I am mistaken.
Thank you in advance…
The setup is:
BGP-1–ether1------ether1–BGP-RR–ether2--------ether2–BGP-2
Route Reflector:
[admin@BGP_RR] > export
# sep/16/2022 13:50:35 by RouterOS 7.5
# software id =
add name=Loopback protocol-mode=none
set [ find default-name=ether1 ] name=ether1_to_BGP1
set [ find default-name=ether2 ] name=ether2_to_BGP2
/port
set 0 name=serial0
/routing ospf instance
add disabled=no name=ospf-instance-1
/routing ospf area
add disabled=no instance=ospf-instance-1 name=ospf-area-1
/routing bgp template
set default address-families=vpnv4 as=65600 disabled=no routing-table=main
add address=3.3.3.3 interface=Loopback network=3.3.3.3
add address=172.1.3.2/30 interface=ether1_to_BGP1 network=172.1.3.0
add address=172.2.3.2/30 interface=ether2_to_BGP2 network=172.2.3.0
/ip dhcp-client
add interface=ether1_to_BGP1
/mpls ldp
add disabled=no lsr-id=3.3.3.3 transport-addresses=3.3.3.3
/mpls ldp interface
add disabled=no interface=ether1_to_BGP1 transport-addresses=""
add disabled=no interface=ether2_to_BGP2 transport-addresses=""
/routing bgp connection
add disabled=no local.address=3.3.3.3 .role=ibgp-rr name=bgp1 remote.address=\
    1.1.1.1/32 .as=65600 routing-table=main templates=default
add disabled=no local.address=3.3.3.3 .role=ibgp-rr name=bgp2 remote.address=\
    2.2.2.2/32 .as=65600 routing-table=main templates=default
/routing ospf interface-template
add area=ospf-area-1 disabled=no interfaces=Loopback networks=3.3.3.3/32 \
    passive
add area=ospf-area-1 disabled=no interfaces=ether1_to_BGP1,ether2_to_BGP2 \
    networks=172.1.3.0/30,172.2.3.0/30 type=ptp
/system identity
set name=BGP_RR
BGP_1:
[admin@BGP1] > export
# sep/16/2022 13:50:16 by RouterOS 7.5
# software id =
set [ find default-name=ether1 ] name=ether1_to_RR
set [ find default-name=ether3 ] name=ether3_CUST_A
/ip vrf
add interfaces=ether3_CUST_A name=cust_a
/port
set 0 name=serial0
/routing ospf area
add address=1.1.1.1 interface=Loopback network=1.1.1.1
add address=172.1.3.1/30 interface=ether1_to_RR network=172.1.3.0
add address=192.168.1.1/24 interface=ether3_CUST_A network=192.168.1.0
/ip dhcp-client
add interface=ether1_to_RR
/mpls ldp
add disabled=no lsr-id=1.1.1.1 transport-addresses=1.1.1.1
/mpls ldp interface
add disabled=no interface=ether1_to_RR transport-addresses=""
add disabled=no local.address=1.1.1.1 .role=ibgp-rr-client name=bgp1 \
    remote.address=3.3.3.3/32 .as=65600 routing-table=main templates=default
/routing bgp vpn
add disabled=no export-route-targets=1.1.1.1:1 import-route-targets=1.1.1.1:1 \
    label-allocation-policy=per-vrf redistribute=connected route-distinguisher=\
    1.1.1.1:1 vrf=cust_a
add area=ospf-area-1 disabled=no interfaces=Loopback networks=1.1.1.1/32 \
    passive
add area=ospf-area-1 disabled=no interfaces=ether1_to_RR networks=172.1.3.0/30 \
    type=ptp
/system identity
set name=BGP1
BGP_2
[admin@BGP_2] > export
# sep/16/2022 13:49:33 by RouterOS 7.5
# software id =
set [ find default-name=ether2 ] name=ether2_to_RR
set [ find default-name=ether3 ] name=ether3_CustA
/ip vrf
add interfaces=ether3_CustA name=cust_a
/port
set 0 name=serial0
/routing ospf area
add address=2.2.2.2 interface=Loopback network=2.2.2.2
add address=172.2.3.1/30 interface=ether2_to_RR network=172.2.3.0
add address=192.168.2.1/24 interface=ether3_CustA network=192.168.2.0
/ip dhcp-client
/mpls ldp
add disabled=no lsr-id=2.2.2.2 transport-addresses=2.2.2.2
/mpls ldp interface
add disabled=no interface=ether2_to_RR transport-addresses=""
add address-families=vpnv4 as=65600 disabled=no local.address=2.2.2.2 .role=\
    ibgp-rr-client name=bgp1 remote.address=3.3.3.3/32 .as=65600 routing-table=\
    main
/routing bgp vpn
add area=ospf-area-1 disabled=no interfaces=Loopback networks=2.2.2.2/32 \
    passive
add area=ospf-area-1 disabled=no interfaces=ether2_to_RR networks=172.2.3.0/30 \
    type=ptp
/system identity
set name=BGP_2
You are not alone, this example is working properly in v6 https://wiki.mikrotik.com/wiki/Manual:Layer-3_MPLS_VPN_example in v7 the prefix advertise by the CE via igp (ospf) flapping on the PE side with a route flag of daY i test this on the most recent v7.6beta8
Route Reflector it does work on v7, to make i work u need to play with routing/filter/
from MT wiki:
Also note that next-hop is not changed on route reflection, except when it’s set in the filter.
And about VPNv4 is totaly broken on v7
@nichky
if vpn4 is broken in v7 that’s explain why it doesn’t work because same topology and config is working on v6.
[admin@PE2] > export
# sep/26/2022 02:14:35 by RouterOS 7.6beta8
# software id =
add name=lo0
add name=vrf1
/interface lte apn
/ip vrf
add interfaces=vrf1 name=vrf1
/port
set 0 name=serial0
set default disabled=no output.network=bgp-networks router-id=10.127.0.3
add disabled=no name=default-v2 redistribute=bgp routing-table=vrf1 vrf=vrf1
/routing ospf area
add disabled=no instance=default-v2 name=backbone-v2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=ether1 list=vrf1
/interface ovpn-server server
set auth=sha1,md5
add address=10.127.0.3 interface=lo0 network=10.127.0.3
add address=192.168.11.2/24 interface=ether3 network=192.168.11.0
add address=192.168.21.1/24 interface=ether1 network=192.168.21.0
/ip dhcp-client
set servers=8.8.8.8
add disabled=no dst-address=10.127.0.1/32 gateway=192.168.11.1
add disabled=no dst-address=10.127.0.2/32 gateway=192.168.11.1
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.11.1
/mpls ldp
add disabled=no lsr-id=10.127.0.3 transport-addresses=10.127.0.3
/mpls ldp interface
add disabled=no interface=ether3 transport-addresses=10.127.0.3
add address-families=vpnv4 as=65530 cisco-vpls-nlri-len-fmt=auto-bits connect=yes disabled=no listen=yes local.address=10.127.0.3 .role=ibgp-rr-client multihop=yes name=peer1 output.network=bgp-networks remote.address=10.127.0.2/32 .as=65530 .port=\
    179 router-id=10.127.0.3 routing-table=main templates=default
/routing bgp vpn
add disabled=no export-route-targets=192.168.10.2:111 import-route-targets=192.168.10.2:111 redistribute=connected,ospf route-distinguisher=192.168.10.2:111 vrf=vrf1
add area=backbone-v2 disabled=no interfaces=ether1 networks=192.168.21.0/24 priority=1
/system identity
set name=PE2
/system logging
add topics=bgp
/system package update
set channel=testing
/tool romon
set enabled=yes
[admin@PE2] > /routing/bgp/session/
[admin@PE2] /routing/bgp/session> print
Flags: E - established
 0 E name="peer1-1"
     remote.address=10.127.0.2 .as=65530 .id=10.127.0.2 .capabilities=mp,rr,gr,as4 .afi=vpnv4 .messages=505427 .bytes=34444261 .eor=""
     local.role=ibgp-rr-client .address=10.127.0.3 .as=65530 .id=10.127.0.3 .capabilities=mp,rr,gr,as4 .afi=vpnv4 .messages=60593 .bytes=4495673 .eor=""
     output.procid=21 .network=bgp-networks
     input.procid=21 ibgp
     multihop=yes hold-time=3m keepalive-time=1m uptime=28m36s80ms last-started=sep/26/2022 01:46:20
[admin@PE2] /routing/bgp/session> /ip route print
Flags: D - DYNAMIC; A - ACTIVE; c, s, o, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#     DST-ADDRESS      GATEWAY                   DISTANCE
0  As 0.0.0.0/0        192.168.11.1                     1
1  As 10.127.0.1/32    192.168.11.1                     1
2  As 10.127.0.2/32    192.168.11.1                     1
  DAc 10.127.0.3/32    lo0                              0
  DAc 192.168.11.0/24  ether3                           0
  DAc 192.168.21.0/24  ether1@vrf1                      0
  DAo 192.168.22.0/24  192.168.21.2%ether1@vrf1       110
  DAy 192.168.20.0/24  10.127.0.2                       0
DAy 192.168.20.0/24 10.127.0.2 This is the prefix being advertise on the CE via OSPF and it’s flapping every now on then in my PE2 side
Could you please elaborate what should be added in routing/filter/ in order to make it work?
I don’t need to change next-hop in this kind of vpnv4 setup.
this one of the e.g.
/routing filter rule
add chain=IN-iBGP-R3 disabled=no rule=“if (dst==192.168.50.0/24) {set gw 10.0.5.6; accept}”
with nexthop-choice=force-self
on v7 that works pretty much same as statically adding route on (ip/route)
I’m not too sure what is your goal, but u can make this work only on the main table not in the VRF. ( i hope that this will be fixed soon)
I have same problem with similar topology. Under ROS 6.49.7 all VPNs are working, after upgrade to 7.6 or 7.7.beta network is unstable and routes flaping.
i think vpnv4 is still broken, i am facing the following issue
R1<----->{MP_BGP(VPNV4)}<----->R2
routes are learned between different vpn instance via the MP-BGP( which is established over main)
When i try to reach from an vrf1 of R2 to vrf1 of R1, this work as expected
but when i try to reach a switch which is directly connected to R1 on vrf1 is not reachable though the same ip on the R1 is reachable
this issue is resolved by disabling ipv4 fast path..
But without fastpath throughput will be severely affected
Has there been any further update to this problem?
I just ran into this today, after upgrading one of my BGP route reflectors to 7.12.1…
Needless to say, that was undone pretty quickly!
Thanks.
VPNv4 works perfectly fine.
show us your config, and the issues
Right. Sorry, might have confused things a little here. My issue is with BGP-VPLS… Although at first look, seems related to the BGP route reflector issue previously.
More details…
We have a full Mikrotik environment, configured with MPLS etc. All is working fine in ROS 6.49.x… In fact, everything has recently been upgraded to being ROS 7.12.1, with the exception of the BGP route reflectors. Whenever we attempt to do this, the BPG signaled VPLS sessions start to flap, and re-establish themselves every few seconds.
BGP relevant parts are:
6.49.x:-
/routing bgp instance
set default disabled=yes
add as=65064 name=vpls router-id=100.127.69.10
/routing bgp peer
add address-families=l2vpn instance=vpls name=IPL-GS.L5.R1.11-FW01
remote-address=100.127.66.15 remote-as=65064 route-reflect=yes ttl=default update-source=br.loop1
7.12.1:-
set default disabled=yes output.network=bgp-networks
add as=65064 disabled=no name=vpls output.network=bgp-networks router-id=100.127.69.10
add address-families=l2vpn cisco-vpls-nlri-len-fmt=auto-bits connect=yes
listen=yes local.address=br.loop1 .role=ibgp-rr name=IPL-GS.L5.R1.11-FW01
remote.address=100.127.66.15 .as=65064 .port=179 templates=vpls
Non BGP-VPLS sessions establish fine, and are stable…
BGP sessions show up as “established”, but the sessions “cycle” as can be seen by the bridge port, showing the vplsXXXX changing quickly (seconds)…
Any assistance would be appreciated.
Thanks.
Have you reported the problem to support? I have seen several users with this problem.
@Wazza
i think we need more details of your config as lot of missing.
Follow @kargchris’ just update to the latest version and corect the follow:
/routing bgp vpn
    label-allocation-policy=per-vrf redistribute=connected,[b]bgp[/b] route-distinguisher=\
@Wazza has problems with BGP signaled VPLS, not VPNv4.
@Wazza
your complaint is about the name of the vpls?
Wherever it goes up/down the name is changing?
