SUP-108056
Clean netinstalled 7.8 from chr-7.8.vdi not print /ip/ipsec/installed-sa/print, only after reboot.
supout.rif from r1 and r2 in attachment SUP-108056
Thank you very much. Just an update. Using CRS317, ip address configured on a vlan (vlan belongs to a bridge with L3 HW enabled), currently after turning off IGMP Snooping for the bridge, ospfv3 works fine. The problem is whether IGMP Snooping is blocking some packets of ipv6
Just FYI
On hap ac3 on 7.7 with a single usb flash drive mounted on /usb and adguard container running from usb drive, after the upgrade to 7.8 I’ve got
usb drive is now mounted on /usb1-part1
trying to change back to /usb results in an incorrect partition size error…
existing docker containers fails to start becaus of root path is now not existing (and cannot be changed, apparently)
pulling an image from dockerhub results in error 401 (known issue from other posts)
recreated the container after updating the mount points and uploading the container tar file, but it does not start and no logs whatsoever except for the image import success notice…
I’ve deleted the container and used a raspberry pi to run it
When upgrade fails, it’s usually something in logs about the cause of it. So after you try to upgrade and it fails, immediately after reboot check logs to see the reason.
I’ve this problem since v7.7 → https://forum.mikrotik.com/viewtopic.php?t=192427&start=300#p982228.
No follow up or update from Mikrotik staff. I guess either i don’t know what i’m doing or they don’t …
Anyway, I just reboot the box a few times more until it is happy to have the usb name matches with what i put in the Adguard container configuration. Not perfect but this is the way it is now …
The change that others are complaining about now, was made exactly to prevent the problem that you had!
Instead of “scanning the devices at boot and assigning them numbered names” like disk1 usb1 etc, now disks get fixed “slot” names that you can assign yourself.
I encounter the same with another gpon sfp module (FS GPON-ONU-34-20BI), the module is not detected anymore (Module present in GUI is unchecked), reverting back to v7.7 solve the issue.
I would like to add 3 other issues:
CPU usage is definitivly higher on v7.8: going from more or less 22% at 350 mhz on v7.7 to 30% at 1400 mhz on v7.8 (in basic router operation with ipv4 and ipv6, no containers, no ospf, no vpn, but capsman) for arround 500 Mbs download speed.
IPV6, firewall connection tab is reporting no connections (in web-gui, working fine in winbox) but this existing since at least v7.3.
On RB5009 activating bridge filter rules still disable ipv4 fasttrack… (sadly for now switch filter rules are not supported for new-vlan-priority)
Updated my hAP AC2 from 7.7 to 7.8, still having the problem that FastTracking stops working after few hours until you reboot the router (with a performance drop Speedtest over PPPoE from 930Mbps to 350Mbps).
I have updated the support case I’ve opened for the issue on 7.7.
Everything else seems ok, I’ve only noticed that the USB drive on which I schedule backus has been renamed from disk2 to usb1-part1.
