Question, where i find not that many information about, also not in this forum.
What is the recommend setting for the input.affinity and output.affinity
If i read the following link correctly: https://help.mikrotik.com/docs/display/ROS/ROSv7+Basic+Routing+Examples
I should say for a CCR1072 with a lot of cores use:
input.affinity=alone
output.affinity=alone
Correct?
But wat about a CCR2004 with only 4 cores? do i also use alone or do i use main?
