v7: no BGP advertisement after reboot, strange address-list issue
Hello!
Short story: BGP advertisement works only after creating new address-list. Just adding a member to existing address-list doesn't help, removing an address-list doesn't help too, must create new!!!
Long story: Had to change a router, so decided to test v7. Simple BGP setup. Seems to work ... until reboot. After reboot - no way to advertise own networks. Default route - OK, foreign networks - OK. Own networks - NO. Doesn't matter what I do with BGP configuration - no way. It was my first touch to v7, so I decided I'm missing something. After hours of staring at a simple BGP session here are the results:
R1 - AS65502, 100.70.67.178, RouterOS 7.1.1, network 192.0.2.0/24
R2 - AS65501, 100.70.67.42, RouterOS 6.49.2
R1 config
[etg@rtr1] > system/reset-configuration no-defaults=yes skip-backup=yes keep-users=yes
[etg@rtr1] > export
# jan/02/1970 00:16:27 by RouterOS 7.1.1
# model = RB4011iGS+
/interface vlan
add interface=ether6 name=vlan_routing vlan-id=3567
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default as=65502
add address=100.70.67.178/24 interface=vlan_routing network=100.70.67.0
/ip firewall address-list
add address=192.0.2.0/24 list=bgp_nets
add blackhole distance=255 dst-address=192.0.2.0/24
/routing bgp connection
add connect=yes disabled=no listen=yes local.role=ebgp-customer name=tik output.default-originate=never .network=bgp_nets remote.address=100.70.67.42 .as=65501 templates=default
/system identity
set name=rtr1
[etg@rtr1] > routing/bgp/session/print
Flags: E - established
 0 E remote.address=100.70.67.42 .as=65501 .id=100.70.67.42 .refused-cap-opt=no .capabilities=mp,rr,as4 .messages=8 .bytes=180 .eor=""
     local.role=ebgp-customer .address=100.70.67.178 .as=65502 .id=100.70.67.178 .capabilities=mp,rr,gr,as4 .messages=8 .bytes=181 .eor=""
     output.procid=20 .network=bgp_nets
     input.procid=20 ebgp
     hold-time=3m keepalive-time=1m uptime=6m32s420ms
R2
[admin@tik] > routing bgp export
# dec/31/2021 00:07:45 by RouterOS 6.49.2
# model = 450G
/routing bgp instance
set default as=65501 router-id=100.70.67.42
/routing bgp network
add network=192.168.192.0/24
/routing bgp peer
add name=rtr1 remote-address=100.70.67.178 remote-as=65502
[admin@tik] > routing bgp peer print status
Flags: X - disabled, E - established
 0 E name="rtr1" instance=default remote-address=100.70.67.178 remote-as=65502 tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no hold-time=3m ttl=255 in-filter="" out-filter="" address-families=ip default-originate=never remove-private-as=no
     as-override=no passive=no use-bfd=no remote-id=100.70.67.178 local-address=100.70.67.42 uptime=4m19s prefix-count=1 updates-sent=1 updates-received=1 withdrawn-sent=0 withdrawn-received=0 remote-hold-time=3m used-hold-time=3m used-keepalive-time=1m
     refresh-capability=yes as4-capability=yes state=established
[admin@tik] > ip route print where bgp
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0  Db  192.0.2.0/24                       100.70.67.178            20
after R1 reboot - no advertisement anymore
R1
[etg@rtr1] > export
# jan/02/1970 00:28:01 by RouterOS 7.1.1
/interface vlan
/port
set 0 name=serial0
set 1 name=serial1
/system identity
set name=rtr1
 0 E remote.address=100.70.67.42 .as=65501 .id=100.70.67.42 .refused-cap-opt=no .capabilities=mp,rr,as4 .messages=3 .bytes=85 .eor=""
     local.role=ebgp-customer .address=100.70.67.178 .as=65502 .id=100.70.67.178 .capabilities=mp,rr,gr,as4 .messages=2 .bytes=38 .eor=""
     hold-time=3m keepalive-time=1m uptime=1m50s800ms
R2
     as-override=no passive=no use-bfd=no remote-id=100.70.67.178 local-address=100.70.67.42 uptime=7s prefix-count=0 updates-sent=1 updates-received=0 withdrawn-sent=0 withdrawn-received=0 remote-hold-time=3m used-hold-time=3m used-keepalive-time=1m
[admin@tik] >
Solution
R1
[etg@rtr1] > ip/firewall/address-list/print
Columns: LIST, ADDRESS, CREATION-TIME
# LIST      ADDRESS       CREATION-TIME
0 bgp_nets  192.0.2.0/24  jan/02/1970 00:13:06
[etg@rtr1] > ip/firewall/address-list/add list=somelist
and now on R2
     as-override=no passive=no use-bfd=no remote-id=100.70.67.178 local-address=100.70.67.42 uptime=4m11s prefix-count=1 updates-sent=1 updates-received=1 withdrawn-sent=0 withdrawn-received=0 remote-hold-time=3m used-hold-time=3m used-keepalive-time=1m
Just adding a member to existing address-list doesn't help, removing an address-list doesn't help too, must create new one.
The problem is the same if R2 is pc router running quagga.
Аs a matter of fact, among 20 or 30 reboots, there was a single case when advertisement worked, but only one. Since with my router it happens always, but there in the forum is no such topic, am I the only one facing this problem?
P.S. Upgrade to RouterOS 7.2rc1 doesn't help. (Even worse - OSPF stopped too. All neighbors seen, LSDB seems to be OK, but none of the routes installed, after downgrade OSPF recovered. Something changed in OSPF?)
P.P.S. Adding an address-list via script doesn't work, doesn't matter if it is executed automatically at startup or manually on CLI/WebFig
Same issue here.
Hi, I have just tried it on my lab with v7.1.1 and I confirm the problem .. However, if I deactivate and reactivate the network on the address list, it is announced. Did you send an email reporting the problem to support@mikrotik.com?
I just notified Mikrotik support too
Update: I confirm the behavior with more than one route announced. If you announce only one, just deactivate / reactivate
If you announce 2 I have the same behavior as you
I faced the problem when trying to advertise 5 networks. Later, as in example above, I use only one network, but don’t remember if I have tried to deactivate and reactivate the network on the address list.
I opened a ticket 5 days ago (2022-01-02), but still no answer - “Status: Waiting for support”.
News???
Same behavior with 5 prefixes. Reboot does fix the problem however, but it is not what you want.
Still no answer from support.
I have the same problem, add random address to address list will trigger bgp advertisement.
Fantastic…
New routing engine, so I expect more problems than just this one. I really think they are working on it in a higher speed than the release of Ros7. So I bear with them and for the moment use Ros6.
After upgrading one of our CHR from v6.48.6 to v7.1.1 we have same issue “no BGP advertisement” but it advertise 5 IP we have in “static routes”, but what ever we do we cant get it to advertise our 2 /22 IP net’s from the “address list”
we have tryed made new address list, reboot router etc. nothing work for us, any suggestion?
We only upgraded one of our 2 CHR to v7.x to get support for direct passthrou af Mellanox 40/100G Nic card, since we got alot of packaget lost in v6.48.6 when using wmvare vmxnet3 nic drivers.
There must be corresponding route in the routing table for networks to be advertised.
YES i got it working.
I was missing my ovn prefixes/ip net from my “address list” in the routing table,
so i added my prefixes/IP net with “Blockhole” roule with distance 254, to the routing table, and then it begin to announce my prefixes/IP net
Until this bug is fixed, I run this with scheduler on startup on all my 7.x routers running bgp with bgp-networks address-list:
:delay 10
/ip/firewall/address-list/disable [find where comment="bgp-networks"]
:delay 2
/ip/firewall/address-list/enable [find where comment="bgp-networks"]
Works for me
I have to say it’s strange that Mikrotik released such a big update during Christmas time, but then a whole month has passed in 2022 and 7.2rc3 is mostly cosmetic improvements or smaller issues getting attention while major operational-related issues such this are still broken after many revisions since they were identified as bugs
Executing a script after boot was the first thing I tried, and without success. But my script doesn’t have a second delay, maybe this is the key.
I have a question to everyone with this problem - does it exist with all hardware? What hardware you use? I have tested only RB4011iGS+RM.
I have just confirmed this with last stable version.
Devices tested: RB960PGS, CCR1072
Version: routeros 7.1.1
If router is rebooted bgp stops sending advertisement
If default-originate is set to “if-installed” the default route advertise is not affected
Solved by disable/enable all bgp-prefix address lists at once, or, after modifying any “routing/filters/rules”.
By now the best solution is a script for enable/disable address lists at when router reboots, (delay needed).
And yes, I do have the prefix as blakhole ip/route entry.
Some pics:
Other side router before and after disable/enable address-lists
Router config
Hello!
We have managed to reproduce the topic issue locally in our labs and look forward to fixing it on upcoming RouterOS versions, unfortunately, I cannot provide an ETA now.
Yes, I have same issue. And my solution is disable/enable the first bgp-rule in ‘/routing/filter/rules’.
Fixed in 7.2rc5
