v7 PCC Load balancing on PPPoE WAN
How do I modify the first two mangle rules? I have two PPPoE WAN addresses.
https://help.mikrotik.com/docs/display/ROS/Firewall+Marking#FirewallMarking-Example3(PCC)
Did you work this out? I have a problem with one incoming pppoe connection load balanced against an Ethernet connection.
