v7 PPPoE Client freezes when modem resyncs
Since I moved installations that run on PPPoE via the ISP modem I have an issue where once the modem drops the pppoe connection (like loosing sync) the mikrotik keeps the interface alive and never reconnects unless I disable/enable the interface or remove cable and plug it back.
I didn’t have that issue on v6.
Has anyone else come across and solved it?
I read here and there using a script to check if it has internet and if not disable/enable… although if it can be solved with an option it would be better
