Hello there. Thank you for your work on v7. I tried it on a VM and It looks like a promising version, with the fresh kernel and all. I have two questions:
Are upstream kernel patches to 4.14 going to be incorporated into the v7 kernel? I can see that upstream it is already at v4.14.148.
Do you plan to publish v7 on the “development” upgrade channel and if yes, about when?
Thank you again!
N.
