I am curious as to how to make it so when you have IGRP routes flap that you don’t flap EGRP BGP routes. SO I get that if you have more specific routes than a larger range than a /24 you can use a blackhole route and it wont flap however you have to filter out the more specific routes from announcing on BGP unless that is desired. But in the case of having /24 networks that are not part of a larger range you cannot use blackhole routes correct as the other routes are not more specific. How would that be worked around?
Would I just need to set the blackhole route distance to higher than the IGRP /24 route or set to 255?
Not sure I’m following completely but the blackhole routes are usually distance=254 so they aren’t actually used for anything, it just puts them in the routing table to nail them up. You can do a lot with routing filters too.
I jokingly flagged this thread as solved but wanted to update it in case Mikrotik support wants to look for bugs in here.
There is a nasty flapping bug when BGP peering with a Juniper router (certainly could be on my specific config but I will not be using 7.x again until iBGP full mesh works) AND more importantly there does not seem to be a way at all to do full mesh iBGP with all routes.
Hey jd603,
Just checking in
I am curious if this issue has been resolved with any of the beta versions or any Stable-ish release of 7.2.x
I have not tested yet, it will probably be a couple months before I attempt 7.x again but I will get to it. Have you tested anything?
Hey jd603,
Just checking in
Bump.
The good news is the flap bug from my first attempt at moving to v7 is gone. The bad news is, me along with several others are still having issues with this one… I have tried every config option and variant to get v7 to announce all its eBGP learned routes to its iBGP peers. Nothing works. This is a basic necessity for running BGP on a LAN with more than one router. Is there an actual example of this working correctly anywhere? Config example perhaps?
I have a similar setup. 2 Mikrotik Routers connecting to external BGP peer.
One is on v6, one on v7. Connection between the routers with iBGP to exchange eBGP Routes.
v7 is learning from the v6 router but not the other way around.
v7 is not dristibuting its eBGP Routes to its iBGP peers. I was trying around until I found this post and learned that it seems to be a bug.
How is that even possible? We are on RouterOS 7.6.
I wanted to give v7 a try ![]()
Bump.
Curious as to what your current peering config looks like?
Hey there.
Just a totally basic config:
v7 router config:
0 name=“peer7”
remote.address=x.x.x.6 .port=179 .as=30xxx
local.address=x.x.x.5 .port=179 .role=ibgp
connect=yes listen=yes routing-table=main router-id=x.x.x.45 templates=ibgp as=30xxx address-families=ip
output.filter-chain=allowall
input.filter=allowall
I tried without filter, with allowall filters, doesn’t seem to matter.
[jd@MikroTik] /routing/bgp/template> print
Flags: * - default; X - disabled, I - inactive
0 * name=“default” routing-table=main router-id=x.x.x.45 as=30xxx
output.network=bgp-networks
1 name=“ibgp” routing-table=main router-id=x.x.x.45 as=30xxx
The templates do use a loopback address - i could try changing the router-id for iBGP? only thing i haven’t tried, in the past this worked and did not matter though.
This is the allowall routing filter rule i used but i tried different variations in case too:
2 chain=allowall rule=“accept;”
v6 router config:
0 E name=“peer1” instance=default remote-address=x.x.x.5 remote-as=30xxx tcp-md5-key=“” nexthop-choice=default
multihop=no route-reflect=no hold-time=3m ttl=255 in-filter=ibgp_in_1 out-filter=“” address-families=ip
update-source=x.x.x.6 default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no
I initially did not have an inbound filter set, but i tried to create one to force nexthop when i enable ibgp-rr on the v7 router, it didn’t seem to work (i also dont think ibgp-rr is the right setting for simply sharing all iBGP routes in the classic full mesh scenario anyway but it did seem to work when I tried it with IPv6.
Let me know what else you need. I have tried a bunch of combinations of things and closest I got was setting role ibgp-rr on the v7 router , but then all the routes sent to the v6 router have the same gateway as the other routes on the v6 router and then some type of routing loop happens and eBGP route announcements start flapping on the v7 router so I need to undo.
Ran in to this same issue, damn. Seems like it’s just one setting that’s different from v6 but I can’t find it. Hahaha. The performance is phenomenal it seems from testing in production, but these quirks are a bit annoying.
V6 propagates eBGP routes through iBGP, but doesn’t happen in reverse. Sad day.
So I started working on this because I’ve had some clients describe the same behavior of not all iBGP routes being learned.
At first I thought it might be a bug, but now that I look closer at it in the lab, I think what may be happening is the normal BGP behavior of only announcing active routes to its peer. Here is the lab I set up. with full IPV4 tables (sort of…they are older copies of the DFZ from a VM I have and only ~500k routes)
If i’m looking at this correctly, each edge router is learning the full table from its upstream into /routing/route and then learning the best routes from its neighbor.
That said, not ruling out the possibility of a bug and working through matching up active routes vs non-active routes and the route count to see if there is any discrepancy. Also, these peerings are all ROSv7 to ROSv7. Will add a CCR1036 on 6.48.6 and see if the behavior changes
edge-01
add name=lo-ipv4
add name=lo-ipv6
/interface bonding
add mode=802.3ad name=bonding1 slaves=sfp-sfpplus1,sfp-sfpplus2 transmit-hash-policy=layer-3-and-4
/interface vlan
add interface=bonding1 name=vlan901-isp1-hooli vlan-id=901
add interface=bonding1 name=vlan3000-ptmp-edge-routers vlan-id=3000
add interface=bonding1 name=vlan3100-ptp-core vlan-id=3100
/interface lte apn
set [ find default=yes ] ip-type=ipv4
/ip vrf
add interfaces=ether15 name=vrf-mgmt
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
add address-families=ip as=1016 name=as1016-v4 router-id=100.127.1.1
add address-families=ipv6 as=1016 name=as1016-v6 router-id=100.127.1.1
/routing id
add id=100.127.1.1 name=rid-main select-dynamic-id=only-vrf select-from-vrf=main
/routing ospf instance
add disabled=no name=ospf-instance-v2-ipv4 router-id=rid-main routing-table=main
add disabled=no name=ospf-instance-v3-ipv6 router-id=rid-main routing-table=main version=3
/routing ospf area
add disabled=no instance=ospf-instance-v2-ipv4 name=ospf-area-0-ipv4
add disabled=no instance=ospf-instance-v3-ipv6 name=ospf-area-0-ipv6
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=100.126.1.1/29 interface=vlan3100-ptp-core network=100.126.1.0
add address=100.127.1.1 interface=lo-ipv4 network=100.127.1.1
add address=203.0.113.2/29 interface=vlan901-isp1-hooli network=203.0.113.0
add address=100.126.12.1/29 interface=vlan3000-ptmp-edge-routers network=100.126.12.0
/ip dhcp-client
add interface=ether15
add disabled=yes interface=ether1
/ip firewall address-list
add address=198.18.0.0/22 list=add-list-as1016-ipv4-internal
/ip service
set ssh vrf=vrf-mgmt
set winbox vrf=vrf-mgmt
/ipv6 address
add address=200:1ce:a1a:3100::1 advertise=no interface=vlan3100-ptp-core
add address=200:1ce:127::1/128 advertise=no interface=lo-ipv6
add address=3ffe:1001:1002::2 advertise=no interface=vlan901-isp1-hooli
add address=200:1ce:a1a:3000::1 advertise=no interface=vlan3000-ptmp-edge-routers
/ipv6 dhcp-client
add interface=ether1 request=address
/ipv6 firewall address-list
add address=200:1ce:127::1/128 list=add-list-as1016-ipv6-internal
/routing bgp connection
add disabled=no input.affinity=afi local.address=100.127.1.1 .role=ibgp-rr-client name=peer-ipv4-rtr-core-01 nexthop-choice=force-self \
output.default-originate=always .filter-chain=as1016-ipv4-internal-permit-default .network=add-list-as1016-ipv4-internal remote.address=\
100.127.1.3 .as=1016 templates=as1016-v4
add input.affinity=afi local.address=200:1ce:127::1 .role=ibgp-rr-client name=peer-ipv6-rtr-core-01 nexthop-choice=force-self \
output.default-originate=always .filter-chain=as1016-ipv6-internal-permit-default .network=add-list-as1016-ipv6-internal remote.address=\
200:1ce:127::3 .as=1016 templates=as1016-v6
add add-path-out=all address-families=ip as=1016 disabled=yes hold-time=30m keepalive-time=1m local.role=ebgp-peer name=isp1-hooli remote.address=\
203.0.113.1/32 .as=65101 router-id=100.127.1.1 routing-table=main templates=as1016-v4
add address-families=ip as=1016 disabled=no input.affinity=afi local.address=100.126.12.1 .role=ibgp name=peer-ipv4-rtr-edge-02 nexthop-choice=default \
output.default-originate=always remote.address=100.126.12.2/32 .as=1016 router-id=100.127.1.1 routing-table=main templates=as1016-v4
add address-families=ipv6 as=1016 disabled=no input.affinity=afi local.address=200:1ce:a1a:3000::1 .role=ibgp name=peer-ipv6-rtr-edge-02 \
nexthop-choice=default output.default-originate=always remote.address=200:1ce:a1a:3000::2/128 .as=1016 router-id=100.127.1.1 routing-table=main \
templates=as1016-v6
/routing filter community-large-list
add communities=1016:1016:4 list=bgp-community-large-1016-1016-4
add communities=1016:1016:6 list=bgp-community-large-1016-1016-6
/routing filter community-list
add communities=1016:0 list=bgp-community-1016-0
/routing filter rule
add chain=as1016-ipv4-internal-permit-default rule=\
"if (dst in 198.18.0.0/22 && dst-len > 22) { set bgp-large-communities bgp-community-large-1016-1016-4; accept; }"
add chain=as1016-ipv4-internal-permit-default rule="if (dst== 0.0.0.0/0) { accept; }"
add chain=as1016-ipv4-internal-permit-default rule="if (dst in 0.0.0.0/0) { reject;}"
add chain=as1016-ipv6-internal-permit-default rule=\
"if (dst in 200:1ce::/32 && dst-len > 32) { set bgp-large-communities bgp-community-large-1016-1016-6; accept; }"
add chain=as1016-ipv6-internal-permit-default rule="if (dst==::/0) { accept; }"
add chain=as1016-ipv6-internal-permit-default rule="if (dst in ::/0) { reject;}"
/routing ospf interface-template
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan3100-ptp-core type=ptp
add area=ospf-area-0-ipv4 disabled=no interfaces=lo-ipv4
add area=ospf-area-0-ipv6 disabled=no interfaces=vlan3100-ptp-core type=ptp
add area=ospf-area-0-ipv6 disabled=no interfaces=lo-ipv6 networks=200:1ce:127::1/128 passive
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan901-isp1-hooli passive
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan3000-ptmp-edge-routers
/system identity
set name=rtr-edge-01.v7.ipa.dev
/system package update
set channel=testing
/system resource irq rps
set ether1 disabled=no
/tool bandwidth-server
set authenticate=no
/tool romon
set enabled=yes
edge-02
add name=lo-ipv4
add name=lo-ipv6
set [ find default-name=ether15 ] name=ether15-mgmt
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1-crs326-02
set [ find default-name=sfp-sfpplus2 ] name=sfp-sfpplus2-crs326-02
/interface bonding
add mode=802.3ad name=bonding1-crs326-02 slaves=sfp-sfpplus1-crs326-02,sfp-sfpplus2-crs326-02 transmit-hash-policy=layer-3-and-4
/interface vlan
add interface=bonding1-crs326-02 name=vlan902-isp2-initech vlan-id=902
add interface=bonding1-crs326-02 name=vlan3000-ptmp-edge-routers vlan-id=3000
add interface=bonding1-crs326-02 name=vlan3200-ptp-core vlan-id=3200
/interface lte apn
/port
set 0 name=serial0
set 1 name=serial1
add address-families=ip as=1016 name=as1016-v4 router-id=100.127.1.2
add address-families=ipv6 as=1016 name=as1016-v6 router-id=100.127.1.2
/routing id
add id=100.127.1.2 name=rid-main
add id=100.127.1.2 name=rid-main select-dynamic-id=only-vrf select-from-vrf=main
add disabled=no name=ospf-instance-v3-ipv6 router-id=rid-main version=3
/routing ospf area
/ip settings
/ipv6 settings
set auth=sha1,md5
add address=100.126.1.9/29 interface=vlan3200-ptp-core network=100.126.1.8
add address=100.127.1.2 interface=lo-ipv4 network=100.127.1.2
add address=198.51.100.2/29 interface=vlan902-isp2-initech network=198.51.100.0
add address=100.126.12.2/29 interface=vlan3000-ptmp-edge-routers network=100.126.12.0
/ip dhcp-client
add interface=ether15-mgmt
/ipv6 address
add address=200:1ce:127::2/128 advertise=no interface=lo-ipv6
add address=200:1ce:a1a:3200::2 advertise=no interface=vlan3200-ptp-core
add address=200:1ce:a1a:3000::2 advertise=no interface=vlan3000-ptmp-edge-routers
add address=200:1ce:1001::/48 list=add-list-as1016-ipv6-services
add address=200:1ce:1002::/48 list=add-list-as1016-ipv6-services
add address=200:1ce:1003::/48 list=add-list-as1016-ipv6-services
/ipv6 nd
set [ find default=yes ] ra-lifetime=none
/ipv6 nd prefix default
set preferred-lifetime=4h valid-lifetime=4h
add local.address=100.127.1.2 .role=ibgp-rr-client name=peer-ipv4-rtr-core-01 output.filter-chain=as1016-ipv4-services-no-default \
.keep-sent-attributes=yes .network=add-list-as1016-ipv4-services remote.address=100.127.1.3 .as=1016 templates=as1016-v4
add address-families=ipv6 as=1016 disabled=no local.address=200:1ce:127::2 .role=ibgp-rr-client name=peer-ipv6-rtr-core-01 \
output.keep-sent-attributes=yes .network=add-list-as1016-ipv6-services remote.address=200:1ce:127::3/128 .as=1016 router-id=100.127.1.2 \
routing-table=main templates=as1016-v6
add add-path-out=all address-families=ip as=1016 disabled=no keepalive-time=1m local.role=ebgp-peer name=isp2-initech remote.address=198.51.100.1/32 \
.as=65102 router-id=100.127.1.2 routing-table=main templates=as1016-v4
add address-families=ip as=1016 disabled=no input.affinity=afi local.address=100.126.12.2 .role=ibgp name=peer-ipv4-rtr-edge-01 nexthop-choice=default \
output.default-originate=always remote.address=100.126.12.1/32 .as=1016 router-id=100.127.1.2 routing-table=main templates=as1016-v4
add address-families=ipv6 as=1016 disabled=no local.address=200:1ce:a1a:3000::2 .role=ibgp name=peer-ipv6-rtr-edge-01 output.keep-sent-attributes=yes \
.network=add-list-as1016-ipv6-services remote.address=200:1ce:a1a:3000::1/128 .as=1016 router-id=100.127.1.2 routing-table=main templates=\
as1016-v6
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan3200-ptp-core type=ptp
add area=ospf-area-0-ipv6 disabled=no interfaces=lo-ipv6 networks=200:1ce:127::2/128 passive
add area=ospf-area-0-ipv6 disabled=no interfaces=vlan3200-ptp-core type=ptp
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan902-isp2-initech passive
/system clock
set time-zone-name=America/New_York
/system identity
set name=rtr-edge-02.v7.ipa.dev
set channel=testing
set authenticate=no
/tool romon
set enabled=yes
/tool sniffer
set file-limit=10000KiB
core-01
add frame-types=admit-only-vlan-tagged name=bridge-main vlan-filtering=yes
add name=lo-ipv4
add name=lo-ipv6
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no name=sfp-sfpplus1-crs326-01 speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no name=sfp-sfpplus2-crs326-01 speed=10Gbps
/interface vlan
add interface=bridge-main name=vlan3100-ptp-edge-01 vlan-id=3100
add interface=bridge-main name=vlan3200-ptp-edge-02 vlan-id=3200
/interface bonding
add mode=802.3ad name=bonding1-crs326-01 slaves=sfp-sfpplus1-crs326-01,sfp-sfpplus2-crs326-01 transmit-hash-policy=layer-3-and-4
/disk
set disk1 parent=nvme1 partition-offset=512 partition-size="512 110 190 080" slot=disk1
/ip vrf
add interfaces=ether13 name=vrf-mgmt
/port
set 0 name=serial0
add address-families=ip as=1016 cluster-id=100.127.1.3 name=as1016-v4-rr router-id=100.127.1.3
add address-families=ipv6 as=1016 cluster-id=100.127.1.3 name=as1016-v6-rr router-id=100.127.1.3
/routing id
add id=100.127.1.3 name=rid-main select-dynamic-id=only-vrf select-from-vrf=main
/routing ospf area
add bridge=bridge-main interface=bonding1-crs326-01
/interface ethernet switch l3hw-settings
set fasttrack-hw=no icmp-reply-on-error=no
/ip settings
/ipv6 settings
/interface bridge vlan
add bridge=bridge-main tagged=bonding1-crs326-01,bridge-main vlan-ids=3100
add bridge=bridge-main tagged=bonding1-crs326-01,bridge-main vlan-ids=3200
add address=100.126.1.2/29 interface=vlan3100-ptp-edge-01 network=100.126.1.0
add address=100.126.1.10/29 interface=vlan3200-ptp-edge-02 network=100.126.1.8
add address=100.127.1.3 interface=lo-ipv4 network=100.127.1.3
/ip dhcp-client
add interface=ether13
/ip service
/ipv6 address
add address=200:1ce:a1a:3100::3 advertise=no interface=vlan3100-ptp-edge-01
add address=200:1ce:127::3/128 advertise=no interface=lo-ipv6
add address=200:1ce:a1a:3200::3 advertise=no interface=vlan3200-ptp-edge-02
add address-families=ip as=1016 cluster-id=100.127.1.3 disabled=no local.address=100.127.1.3 .role=ibgp-rr name=peer-ipv4-rtr-edge-01 remote.address=\
100.127.1.1/32 .as=1016 router-id=100.127.1.3 routing-table=main templates=as1016-v4-rr
add address-families=ip as=1016 cluster-id=100.127.1.3 disabled=no local.address=100.127.1.3 .role=ibgp-rr name=peer-ipv4-rtr-edge-02 \
output.default-originate=if-installed remote.address=100.127.1.2/32 .as=1016 router-id=100.127.1.3 routing-table=main templates=as1016-v4-rr
add address-families=ipv6 as=1016 cluster-id=100.127.1.3 disabled=no local.address=200:1ce:127::3 .role=ibgp-rr name=peer-ipv6-rtr-edge-01 \
remote.address=200:1ce:127::1/128 .as=1016 router-id=100.127.1.3 routing-table=main templates=as1016-v6-rr
add address-families=ipv6 as=1016 cluster-id=100.127.1.3 disabled=no local.address=200:1ce:127::3 .role=ibgp-rr name=peer-ipv6-rtr-edge-02 \
output.default-originate=if-installed remote.address=200:1ce:127::2/128 .as=1016 router-id=100.127.1.3 routing-table=main templates=as1016-v6-rr
add area=ospf-area-0-ipv6 disabled=no interfaces=lo-ipv6 networks=200:1ce:127::3/128 passive
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan3100-ptp-edge-01 type=ptp
add area=ospf-area-0-ipv4 disabled=no interfaces=vlan3200-ptp-edge-02 type=ptp
add area=ospf-area-0-ipv6 disabled=no interfaces=vlan3100-ptp-edge-01 type=ptp
add area=ospf-area-0-ipv6 disabled=no interfaces=vlan3200-ptp-edge-02 type=ptp
/system clock
/system identity
set name=rtr-core-01.v7.ipa.dev
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
set channel=testing
/tool romon
set enabled=yes
The routes are not being sent at all. So.. for example, if the routes learned from eBGP on router 1 are active on both routers and the eBGP session is lost, the inactive eBGP routes on router 2 would need to become active in the local routing table after the failed routes learned from router 1 get removed, they would then be sent to router 1 and once those are processed and loaded they will become active and pass traffic. I think that is what you are trying to say but what that does it delay the process or changing to another route. The other available routes should be propagated to all iBGP neighbors so they are ready to change to on loss of the other route(s). I’m pretty sure that is how it usually works?
I will try changing localpref of the routes on the v7 router to see if your theory is correct at least.
I also see *) bgp - do not reflect route back to sender; on 7.7rc3 - perhaps this was what was breaking so much when i enabled ibgp-rr? The thing is, why would I need to set ibgp-rr when i intend to have full mesh iBGP anyway. With other vendors I never needed to set that and I was under the impression that was for when you don’t have all your iBGP directly connected in a full mesh set up.
BGP is advertising only active best route and does not accept advertisements if best route is receiving router. So in triangle setups like illustrated above you will never get a full copy of all the BGP feeds on all the iBGP routers.
The routes are not being sent at all. So.. for example, if the routes learned from eBGP on router 1 are active on both routers and the eBGP session is lost, the inactive eBGP routes from router 2 would need to become active in the local routing table after the failed routes get removed, they would then be sent to router 1 and once those are processed and loaded they will become active and pass traffic.
A few things here
You don’t need route reflect at all in this scenario for border-to-border peerings. If you look in the config I’m using, the role types are ebgp for upstreams and ibgp for border to border. I am using the rr-client role towards the core since it is the RR for the ASN in this lab.
When i drop the upstream for edge-01 (Hooli) the routes immediately converge over the ptp link (100.126.12.0/29 - vlan3000-ptmp-edge-routers) towards edge-02 which has the only remaining upstream. This is the correct behavior
Here is a sample of routes before ISP1 drops - the next hop varies based on the BGP best path algorithm - which is expected and normal
[zuul@rtr-edge-01.v7.ipa.dev] > routing/route/print
Flags: X - disabled, F - filtered, U - unreachable, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, a - ldp-address, l - ldp-mapping, y - copy;
H - hw-offloaded; + - ecmp, B - blackhole
DST-ADDRESS GATEWAY AFI DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
Ab 0.0.0.0/0 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
UbH 0.0.0.0/0 10.255.44.1 ip4 200 40 30
Ab 1.0.0.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.0.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.4.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.4.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.5.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.5.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.6.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.6.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.7.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.7.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.38.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.38.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.64.0/18 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.64.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.128.0/17 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.128.0/17 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.128.0/18 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.128.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.128.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.128.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.128.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.128.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.129.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.129.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.131.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.131.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.139.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.139.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.142.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.142.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.160.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.160.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.160.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.160.0/21 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.192.0/18 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.192.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.192.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.192.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.192.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.192.0/21 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.0.208.0/22 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.0.208.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.212.0/23 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.212.0/23 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.214.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.214.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.224.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.224.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.240.0/20 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.0.240.0/20 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.1.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.1.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.8.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.8.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.32.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.32.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.64.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.64.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.114.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.114.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.115.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.115.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.116.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.116.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.117.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.117.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.118.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.118.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.119.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.119.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.120.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.120.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.121.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.121.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.122.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.122.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.123.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.123.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.124.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.124.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.125.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.125.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.126.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.126.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.127.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.127.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.1.128.0/17 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.128.0/17 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.128.0/18 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.128.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.128.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.128.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.128.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.136.0/22 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.136.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.1.141.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.141.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.1.142.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.142.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.144.0/20 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.160.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.160.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.160.0/20 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.160.0/20 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
b 1.1.181.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.181.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.184.0/22 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.184.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.190.0/23 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.190.0/23 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.192.0/18 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.192.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.192.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.192.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.192.0/20 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.208.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.216.0/22 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.216.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.222.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.222.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.224.0/19 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.224.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.232.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
Ab 1.1.240.0/21 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.240.0/21 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.248.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.248.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.249.0/24 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.249.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.254.0/23 203.0.113.1 ip4 20 40 10 203.0.113.1%vlan901-isp1-hooli
b 1.1.254.0/23 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
And here it is after (notice the gateway is only towards edge-02 now)
c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, a - ldp-address, l - ldp-mapping, y - copy; H - hw-offloaded; + - ecmp, B - blackhole
Ab 1.0.0.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.7.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.38.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.64.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.128.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.128.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.128.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.129.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.142.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.160.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.192.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.192.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.192.0/21 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.212.0/23 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.214.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.224.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.0.240.0/20 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.1.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.8.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.32.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.64.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.114.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.115.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.116.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.117.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.118.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.119.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.120.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.121.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.122.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.123.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.124.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.125.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.126.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.127.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.128.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.128.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.136.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.160.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.160.0/20 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.184.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.190.0/23 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.192.0/18 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.192.0/19 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.216.0/22 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.222.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.240.0/21 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.248.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.249.0/24 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Ab 1.1.254.0/23 198.51.100.1 ip4 200 40 30 100.126.12.2%vlan3000-ptmp-edge-routers
Unfortunately, no. I just tested on IPv6 BGP, i disabled the eBGP peer on the rosv6 router and no routes were added from the v7 router. No routes are being sent to the v6 router by v7 despite a filter to allow all and a basic configuration. There is clearly some type of issue. The only other thing I can see is this router was upgraded from ros v6, maybe it is just broken because of that upgrade process and I need to do a fresh install? Is that possible and worth my time? What is the process?
I think you mentioned earlier you were doing loopback peerings. This won’t work with IPv6 between ROSv6 and ROSv7 because routing recursion to resolve the next hop of the loopback doesn’t work in ROSv6 (although it does with IPv4)
If you try the same config between ROSv7 peers, does it work?
I’ll add IPv6 to my test topology and confirm as well.
No I am using static interface IP addresses. I tested on IPv6 but nothing I do will send routes to the v6 router on ip4 or 6.
the v6 router shows “updates-received=0” for the ibgp peers.
Not sure when I can test with another v7 router but will let you know if I do.
Is there a working config for routeros v7 i could look at for just iBGP full mesh with one or two eBGP peers and routes sharing between? This way if I mirror that config and if it doesn’t work, I suspect something broken on the upgraded v7 router and can reinstall.
Update, I tested with a ROSv6 box using a CCR1036-8G-2S+ in place of the CCR2004 for edge-01 and got the same results. This is on IPv4 as I still need to fix my IPv6 route gen for full tables - so that will be my next test. But for ROSv6 to ROSv7 peerings on iBGP v4 afi, it appears to be working properly.
Here are the results which match the v7 to v7 peerings.
This is the edge-01 config on ROSv6.48.6 long term
add name=lo-ipv4
add name=lo-ipv6
/interface bonding
/interface vlan
/routing bgp instance
set default as=1016 router-id=100.127.1.1
set [ find default=yes ] router-id=100.127.1.1
/ip dhcp-client
add disabled=no interface=ether8
/ipv6 address
/routing bgp network
add network=198.18.0.0/22
/routing bgp peer
add default-originate=always name=peer-ipv4-rtr-core-01 out-filter=as1016-ipv4-internal-permit-default remote-address=100.127.1.3 remote-as=1016
add default-originate=always name=peer-ipv4-rtr-edge-02 remote-address=100.126.12.2 remote-as=1016
add default-originate=always name=isp1-hooli out-filter=as1016-ipv4-internal-permit-default remote-address=203.0.113.1 remote-as=65101
/routing filter
add action=accept chain=as1016-ipv4-internal-permit-default prefix=198.18.0.0/22 prefix-length=23-32 set-bgp-communities=1016:4
add action=accept chain=as1016-ipv4-internal-permit-default prefix=0.0.0.0/0 set-bgp-communities=""
add action=discard chain=as1016-ipv4-internal-permit-default set-bgp-communities=""
add interface=vlan901-isp1-hooli network-type=broadcast passive=yes
add interface=vlan3000-ptmp-edge-routers network-type=point-to-point
add interface=vlan3100-ptp-core network-type=point-to-point
/routing ospf network
add area=backbone network=100.126.1.0/29
add area=backbone network=100.126.12.0/29
add area=backbone network=100.127.1.1/32
add area=backbone network=203.0.113.0/29
/system clock
set time-zone-name=America/Chicago
/system identity
set name=rtr-edge-01.rosv6.ipa.dev
/tool romon
set enabled=yes
The problem with your design is it isn’t using the standard ibgp full mesh, it’s using ibgp-rr route reflector - this should not be required with my design and it isn’t on any other vendors router that I know of. Once 7.7 is out of RC i will retry configuring as ibgp-rr even though it’s not normal for a two router ibgp config.
Can you disable ibgp-rr and just use ibgp and get the same result of ALL ebgp routes being shared to ibgp neighbors?
Happy new year!
