Valens QoS Presentation - Priority
In the above slide I see that priority is only applied if limit-at is reached/specified. Is this really true? I find MOST examples in the forums and wiki where limit-at is not specified, yet they are prioritizing packets.
How true is the slide above? Can someone reword it to be more specific? Does it mean limit-at AND max-limit have to be specified, or just max-limit? Does it mean inner queues completely ignore any priority specified on them? I see conflicting examples everywhere and so I’m not really sure what to believe anymore.
I see this in the HTB wiki manual:
Make a note that priority only works:
for leaf queues - priority in inner queue have no meaning.
if max-limit is specified (not 0)
So does this mean if a inner queue has a max-limit, but its leaf queues do not, then priority will be ignored?
great concern. I join the question!!!. Currently I have my quality of service with certain limitations not specified.
regards
Valens is right:
In another words, at first limit-at (CIR) of the all queues will be satisfied, only then child queues will try to borrow the necessary data rate from their parents in order to reach their max-limit (MIR).
Note: CIR will be assigned to the corresponding queue no matter what. (even if max-limit of the parent is exceeded)
We already know that limit-at (CIR) to all queues will be given out no matter what.
Priority is responsible for distribution of remaining parent queues traffic to child queues so that they are able to reach max-limit
Queue with higher priority will reach its max-limit before the queue with lower priority. 8 is the lowest priority, 1 is the highest.
**Make a note that priority only works:
  • for leaf queues - priority in inner queue have no meaning.
  • if max-limit is specified (not 0)**
This comes from the manual:
http://wiki.mikrotik.com/wiki/HTB
Also a suggestion to look at Example3 and Example4
I think I understand. So priority on inner queues is completely useless.
http://wiki.mikrotik.com/wiki/DSCP_based_QoS_with_HTB
In the above setup it shows lots of inner queues with leafs underneath each. Does this mean that those dont do anything?
Thx,
Sam
Yes it’s useless. By the way, you are referring to an article that’s not created by MikroTik, but by one of the users - Allen Eising (he is here on the forum)
setting priority for inner queue in this case is good for sorting, for good clarity …
understood. the sorting idea is good idea… nice to clarify that its not doing anything other than making it look pretty.
Sam
