value Port-limit from radius ignored
Hi all,
I have problem with server pppoe and radius.
User authentication via radius works properly with limitation of Banda.
The problem in reply is specified radius of the port-limit not to authenticate multiple users with the same username.
But is ignored, how can we do?
Hi
Port-Limit will not work for PPP users.
You have to enable such option on RADIUS server, that will disallow duplicate
sessions.
FreeRADIUS server supports feature that is called ‘Simultaneous-Use’. You need
to enable this.
Regards Karapet Aznavuryan
Yuppers. Port-Limit is a check item, not a reply item. i.e. it’s checked on the radius server (from accounting data which needs to be kept current), and not on the router.
same problem using windows server 2003 and IAS.
enabling log (go to system logging and create e memory log that filter radius/debug.
it receive port limit from radius but ROS does not apply it
ciao
Max
