VAP not responding to probe requests
I am having an issue right now with some small wireless cameras (2.4ghz only, g/n) I just bought where, when they try to connect to the SSID I provide it, it will probe and there is no response from my virtual AP using RBcAPGi-5acD2nD-US.
I used wireless sniffer to watch the broadcast for probe-request and did not see a probe-response from any MAC address my VAP is on, or any frequency I use.
I did however, find that when I connect these cameras to the SSID on the Master interface ‘wlan1’ it will send a probe-response to the camera and connection is successful.
I don’t think this is a camera problem since I can connect it successfully to my ASUS AC WAP that is also setup as a virtual AP, and an older RB951-2n using master interface.
I even went as far as copying the exact settings from the RB951-2n to the RBcAPGi-5acD2nD-US wlan1 (2.4ghz interface) and the cameras still can’t connect to the VAP.
Here is the config for the VAP and its master:
[admin@AP1] > interface wireless print
0 R name=“Security” mtu=1500 l2mtu=1600 mac-address=BA:69:F4:86:B9:78
arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge
ssid=“cameras” vlan-mode=no-tag vlan-id=15 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=cameras
1 R name=“wlan1” mtu=1500 l2mtu=1600 mac-address=B8:69:F4:86:B9:76 arp=enabled
interface-type=IPQ4019 mode=ap-bridge ssid=“internal” frequency=2437
band=2ghz-onlyn channel-width=20/40mhz-eC secondary-channel=“”
scan-list=default wireless-protocol=any vlan-mode=no-tag vlan-id=5
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=internal compression=no
Let me know if I can sniff or provide anymore information.
Thanks!
Here is a full config export for those interfaces
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=no ampdu-priorities=0 amsdu-limit=
8192 amsdu-threshold=8192 antenna-gain=2 area=“” arp=enabled arp-timeout=auto band=2ghz-onlyn
basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-eC compression=no
country=“united states3” default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0
default-forwarding=yes disable-running-check=no disabled=no disconnect-timeout=3s distance=indoors
frame-lifetime=0 frequency=2437 frequency-mode=regulatory-domain frequency-offset=0 guard-interval=any
hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=“mcs-0,mcs-1,mcs-
2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,m
cs-19,mcs-20,mcs-21,mcs-22,mcs-23” hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 installation=indoor interworking-profile=disabled keepalive-frames=
enabled l2mtu=1600 mac-address=B8:69:F4:86:B9:76 max-station-count=2007 mode=ap-bridge mtu=1500
multicast-buffering=disabled multicast-helper=full name=wlan1 nv2-cell-radius=30 nv2-downlink-ratio=50
nv2-mode=dynamic-downlink nv2-preshared-key=“” nv2-qos=default nv2-queue-count=2 nv2-security=disabled
nv2-sync-secret=“” on-fail-retry-time=100ms preamble-mode=both radio-name=B869F486B976 rate-selection=
advanced rate-set=default rx-chains=0,1 scan-list=default secondary-channel=“” security-profile=internal ssid=
internal station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
tdma-period-size=2 tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled vlan-id=5 vlan-mode=
no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=
disabled wireless-protocol=any wmm-support=disabled wps-mode=disabled
add area=“” arp=enabled arp-timeout=auto bridge-mode=enabled default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=yes disable-running-check=no disabled=no hide-ssid=no
interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 mac-address=BA:69:F4:86:B9:78
master-interface=wlan1 max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=disabled
multicast-helper=full name=cameras security-profile=cameras ssid=cameras station-bridge-clone-mac=
00:00:00:00:00:00 station-roaming=enabled update-stats-interval=disabled vlan-id=15 vlan-mode=no-tag
wds-cost-range=0 wds-default-bridge=none wds-default-cost=0 wds-ignore-ssid=no wds-mode=disabled
