VAP on vlan bypassing bridge
I recently purchased two MikroTik routers for a SOHO setup;
Router A: RB2011UAS-2HnD-IN (main router)
Router B: RB751U-2HnD (configured as AP)
On router A I created the following:
ether1 — ISP modem
vap-private — bridge-rtr-private — VLAN0040 — Ether2 (tagged)
vap-public — bridge-rtr-public — VLAN0010 — Ether2 (tagged)
ether3 (untagged) — bridge-rtr-business — VLAN0020 — Ether2 (tagged)
ether4 (untagged) — bridge-rtr-hotspot — VLAN0030 — Ether2 (tagged)
On router B I created the following:
ether2 (untagged) — bridge-ap-private — VLAN0040 — Ether1 (tagged)
ether3 (untagged) — bridge-ap-public — VLAN0010 — Ether1 (tagged)
vap-business — bridge-ap-business — VLAN0020 — Ether1 (tagged)
vap-hotspot — bridge-ap-hotspot — VLAN0030 — Ether1 (tagged)
So Ether2 on router A and Ether1 on router B are trunk ports.
IP addresses are assigned to the bridges at Router A, the appropriate DHCP scopes have been set up, all is working nicely.
On router B I removed all firewall/masquerading rules, so Router A is doing all the routing, this is als working; inter vlan communication is blocked and people are able to access the internet.
For management sake, I assigned a static DHCP IP to router B in the private segment.
Bridges on router A are root bridges.
This is where the fun begins;
I don’t see the traffic coming from the vap’s to the bridges on router B; instead I see the traffic being passed directly to the vlan, the bridge sees nothing.[b/]
The only traffic I see is on bridge-ap-private, where the administrative interface resides.
I do see the traffic on the bridge of Router A.
Her is a compact export of router B, with all the irrelevant settings removed:
add l2mtu=1596 name=BRIDGE-AP-PRIV protocol-mode=rstp
add l2mtu=1596 name=BRIDGE-AP-BUSI protocol-mode=rstp
add l2mtu=1596 name=BRIDGE-AP-HSPT protocol-mode=rstp
add l2mtu=1596 name=BRIDGE-AP-PUBL protocol-mode=rstp
set 0 name=ether1-trunk speed=1Gbps
set 1 name=ether2-priv speed=1Gbps
set 2 name=ether3-busi speed=1Gbps
set 3 name=ether4-publ speed=1Gbps
set 4 name=ether5-hspt speed=1Gbps
/interface vlan
add interface=ether1-trunk l2mtu=1596 name=VLAN0010-BUSI vlan-id=10
add interface=ether1-trunk l2mtu=1596 name=VLAN0020-PUBL vlan-id=20
add interface=ether1-trunk l2mtu=1596 name=VLAN0030-HSPT vlan-id=30
add interface=ether1-trunk l2mtu=1596 name=VLAN0040-PRIV vlan-id=40
add bridge=BRIDGE-AP-PRIV interface=ether2-priv
add bridge=BRIDGE-AP-PRIV interface=VLAN0040-PRIV
add bridge=BRIDGE-AP-PRIV interface=wlan-priv
add bridge=BRIDGE-AP-PRIV disabled=yes interface=ether1-trunk
add bridge=BRIDGE-AP-BUSI interface=ether3-busi
add bridge=BRIDGE-AP-BUSI interface=VLAN0010-BUSI
add bridge=BRIDGE-AP-BUSI interface=wlan-busi
add bridge=BRIDGE-AP-PUBL interface=ether4-publ
add bridge=BRIDGE-AP-PUBL interface=VLAN0020-PUBL
add bridge=BRIDGE-AP-PUBL interface=wlan-publ
add bridge=BRIDGE-AP-HSPT interface=ether5-hspt
add bridge=BRIDGE-AP-HSPT interface=VLAN0030-HSPT
add bridge=BRIDGE-AP-HSPT interface=wlan-hspt
/ip dhcp-client
add default-route-distance=0 disabled=no host-name=ap-debont interface=BRIDGE-AP-PRIV
/ip dns static
add address=192.168.88.1 name=router-debont
Maybe I’m missing something obvious and I just need a push in the right direction…
Any ideas?
Had some time to test yesterday;
If i disable the bridge traffic stops form vap to vlan and vice versa. This means that the bridge is working, but the traffic is just not showing and counted in the bridge.
Some Googling led me to some posts mentioning this, but only in early (<3) ROS versions. The mentioned work arounds (disabling/enabling bridge, assign IP to vlan and then move to bridge) aren’t working.
Seems like bug??
