Variable is Empty
Im using 3.23 ROS
THis is my Code:
:global info;
:set info [:put (/ip firewall mangle get 0 bytes)];
/tool e-mail send body=“$info” to=“stefand@aknt.co.za” subject=“Report”;
The email is blank. If I run it from comman line it has a value. Ive tried it without the “:put” there aswell but it still sends a blank email.
Please help.
You can’t use console numbers in scripts. So this “(/ip firewall mangle get 0 bytes)” line is invalid.
add comment to that mangle rule and make it something liek following
/ip firewall mangle get [find comment="myComment"] bytes
Thank you. You are a star!
