Variable UDP Probe
I would like to define an UDP probe which send message should contain a variable string identifying the device, for instance
Probe
Type: UDP
Send: TEST [Device.Name]
Of course the above example doesn’t work, as it is sent literally.
Is there a way to implement variable substitution or all send and receive messages in the probe definitions are constant ?
Thanks in advance,
Aldo Caruso
