Variable Variable... But.. In Mikrotik..??
Hello.. I Have A Problem.. I Can’t Set a Variable Variable in Mikrotik RouterOS..
Variable Variable Is translated as.. The Result of The First Variable is The Name of The Second Variable.. eg with PHP:
$a = “Hello”;
$$a = “What’s Up”; ( This Is The Same To Put [ $Hello = “What’s Up” ]…
But I have not Name of The Second Variable… Need to Use Variable Variable…
And I tried with:
:local a “Hello”;
:local $a “What’s Up”; ( But Not Work )
or:
:put $aa; ( But Not Work )
Help Me… Thanks.. ^^ (My English Is Bad.. Sorry)..
When you initialize the variable you can set it in one shot.
ex:
:local a “Hello”
Then if later in the script you want to change the value of a you use set.
:set a “What’s Up”
Demo (Tested on V3.6)
:local a "Hello"
:log info "a is: $a"
:set a "What's Up"
-Louis
I’ve been missing such a feature since 2.8.
There is a crude way of doing it but it does wear on your flash.
:global a “something”
:global b “a”
/ system script run [ / system script add name=assigna source=( ":set b " . $a ) ]
:delay 10ms
:put $b
(Written from memory, YMMV)
