amcrs
April 23, 2021, 3:51am
1
I have
:global eruWAN ether1
/ip firewall filter add chain=forward out-interface=!($eruWAN) …
which the CLI doesn’t like. Nor
/ip firewall filter add chain=forward out-interface=!$eruWAN …
/ip firewall filter add chain=forward out-interface=(!$eruWAN) returns “Script Error: cannot logically negate string” which makes sense, but
/ip firewall filter add chain=forward out-interface=!ether1 … works.
How can I use the variable $eruWAN there?
Jotne
April 23, 2021, 9:18am
2
In cli wrap the code i brackets. {code}
/ip firewall filter add chain=forward out-interface=!($eruWAN) ....
mrz
April 23, 2021, 9:31am
3
As error says you cannot logically negate string.
by specifying !“string” you are trying to perform logic operation on string and then apply it as a value.
To pass ! as part of the value you should pass it as a part of string “!$your_var”
[admin@MikroTik] /ip/firewall/filter> add out-interface="!$x" chain=xx
[admin@MikroTik] /ip/firewall/filter> print
Flags: X - disabled, I - invalid; D - dynamic
0 chain=xx out-interface=!ether1
do not matter, if you use GLOBAL, instead of local.
sorry.. missing
:global x "ether1"
[admin@MikroTik] /ip/firewall/filter> :global x "ether1"
