Hi.
This may be already in the “DUDE” product, but I cant see it. I would like to discover a range of IP addresses, not a whole subnet. Multiple IP ranges would be fantastic too. Is this possible?
Grant
Hi.
Grant
You can put specific range of addresses in if you just put a dash between them like “192.168.10.66-192.168.10.78”. And if it falls on a class boundary “The Dude” will change your range to a /27 or what ever the boundary is. i.e. 192.167.10.64/27.
I don’t think you can put a comma separated list of address ranges in one “auto-discover” but you can easily add multiple individual ranges to discover on the general settings tab under the “map” settings button.
HTH
SD
