Various RB433 on same network as Wireless AP problem!
Hi guys,
I have around 13 RB433 routerboards equiped with a R52N wireless card each so they work as access points throughout an office building with 3 floors.
The wireless signal is always available (there is no wireless signal loss) however each time a computer connects to the wireless network, after a while it loses connection and you have to press the connect button again on Windows to rejoin the wireless network.
It happens on all devices.
I’ve set up each device with a separate frequency to avoid one AP interfering with another but still the wireless network is failing to stay up with the computers connected to it.
How can I determine the culprit of this situation?
I’ve upgraded the firmware and everything but still no go.. it connects for a while, then disconnects and we have to manually rejoin all the computers to the wireless network.
We are using the RB433 as a AP bridge with the same SSID, same WPA2 password, different frequencies, etc.
What else could help?
Thanks much!
Teo
It could be interference, but this sounds more like a configuration problem. If you are using Windows clients, or most any client for that matter, they should reconnect all by themselves even if there are frequent disruptions in their service. Can you post the settings you are using in the MikroTik and from one of the clients. Do you have the wireless logs enabled? What are your logs telling you?
