some routerboards upgraded to 3.10 give some kernel failure.
I noticed on my rb133c that some failure appears randomly after ~24-48h of work, but one appear EVERY reboot!
I send supout.inf to mikrotik support, but think it’s useful if other user with same issue send the supout file to support.
Just try to reboot and check the log for kernel failure.
Put it in your ‘Files’ area. Then go to system>>routerboard and do a print. You should now be able to upgrade to 2.16. Do that, then do the 3.10 firmware upgrade.
I can’t try if upgrade bios to 2.16 on rb133c BEFORE upgrade ROS to 3.10 will fix the problem but, AFTER bios upgrade with 3.10 already on RB, the “kernel failure” message on every reboot still in log.
And i hope that -they at Mikrotik- don’t fix it, in next ROS version, simply deleting the message in the logs
