vb.net api execution?
——————————————————————————————————class————————————————————————————————————
Imports System.Net.Sockets
Imports System.IO
Imports System.Text
Class MK_ROS
Private connection As Stream
Private con As TcpClient
Public Sub New(ByVal ip As String)
con = New TcpClient()
con.Connect(ip, 8728)
connection = DirectCast(con.GetStream(), Stream)
End Sub
Public Sub Close()
connection.Close()
con.Close()
End Sub
Public Function Login(ByVal username As String, ByVal password As String) As Boolean
Send(“/login”, True)
Dim hash As String = Read()(0).Split(New String() {“ret=”}, StringSplitOptions.None)(1)
Send(“/login”)
Send(“=name=” & username)
Send(“=response=00” & EncodePassword(password, hash), True)
If Read()(0) = “!done” Then
Return True
Else
Return False
End If
End Function
Public Sub Send(ByVal co As String)
Dim bajty As Byte() = Encoding.ASCII.GetBytes(co.ToCharArray())
Dim velikost As Byte() = EncodeLength(bajty.Length)
connection.Write(velikost, 0, velikost.Length)
connection.Write(bajty, 0, bajty.Length)
End Sub
Public Sub Send(ByVal co As String, ByVal endsentence As Boolean)
connection.WriteByte(0)
End Sub
Public Function Read() As List(Of String)
Dim output As New List(Of String)()
Dim o As String = “”
Dim tmp As Byte() = New Byte(3) {}
Dim count As Long
While True
tmp(3) = CByte(connection.ReadByte())
'if(tmp[3] == 220) tmp[3] = (byte)connection.ReadByte(); it sometimes happend to me that
'mikrotik send 220 as some kind of “bonus” between words, this fixed things, not sure about it though
If tmp(3) = 0 Then
output.Add(o)
If o.Substring(0, 5) = “!done” Then
Exit While
Else
o = “”
Continue While
End If
Else
If tmp(3) < &H80 Then
count = tmp(3)
Else
If tmp(3) < &HC0 Then
Dim tmpi As Integer = BitConverter.ToInt32(New Byte() {CByte(connection.ReadByte()), tmp(3), 0, 0}, 0)
count = tmpi Xor &H8000
Else
If tmp(3) < &HE0 Then
tmp(2) = CByte(connection.ReadByte())
Dim tmpi As Integer = BitConverter.ToInt32(New Byte() {CByte(connection.ReadByte()), tmp(2), tmp(3), 0}, 0)
count = tmpi Xor &HC00000
Else
If tmp(3) < &HF0 Then
tmp(1) = CByte(connection.ReadByte())
Dim tmpi As Integer = BitConverter.ToInt32(New Byte() {CByte(connection.ReadByte()), tmp(1), tmp(2), tmp(3)}, 0)
count = tmpi Xor &HE0000000
Else
If tmp(3) = &HF0 Then
tmp(0) = CByte(connection.ReadByte())
count = BitConverter.ToInt32(tmp, 0)
Else
'Error in packet reception, unknown length
Exit While
End If
End If
End If
End If
End If
End If
For i As Integer = 0 To count - 1
o += ChrW(connection.ReadByte())
Next
End While
Return output
End Function
Private Function EncodeLength(ByVal delka As Integer) As Byte()
If delka < &H80 Then
Dim tmp As Byte() = BitConverter.GetBytes(delka)
Return New Byte(0) {tmp(0)}
End If
If delka < &H4000 Then
Dim tmp As Byte() = BitConverter.GetBytes(delka Or &H8000)
Return New Byte(1) {tmp(1), tmp(0)}
End If
If delka < &H200000 Then
Dim tmp As Byte() = BitConverter.GetBytes(delka Or &HC00000)
Return New Byte(2) {tmp(2), tmp(1), tmp(0)}
End If
If delka < &H10000000 Then
Dim tmp As Byte() = BitConverter.GetBytes(delka Or &HE0000000)
Return New Byte(3) {tmp(3), tmp(2), tmp(1), tmp(0)}
Else
Return New Byte(4) {&HF0, tmp(3), tmp(2), tmp(1), tmp(0)}
End If
End Function
Public Function EncodePassword(ByVal Password As String, ByVal hash As String) As String
Dim hash_byte As Byte() = New Byte(hash.Length / 2 - 1) {}
For i As Integer = 0 To hash.Length - 2 Step 2
hash_byte(i / 2) = [Byte].Parse(hash.Substring(i, 2), System.Globalization.NumberStyles.HexNumber)
Next
Dim heslo As Byte() = New Byte(1 + Password.Length + (hash_byte.Length - 1)) {}
heslo(0) = 0
Encoding.ASCII.GetBytes(Password.ToCharArray()).CopyTo(heslo, 1)
hash_byte.CopyTo(heslo, 1 + Password.Length)
Dim hotovo As Byte()
Dim md5 As System.Security.Cryptography.MD5
md5 = New System.Security.Cryptography.MD5CryptoServiceProvider()
hotovo = md5.ComputeHash(heslo)
'Convert encoded bytes back to a ‘readable’ string
Dim navrat As String = “”
For Each h As Byte In hotovo
navrat += h.ToString(“x2”)
Next
Return navrat
End Function
End Class
——————————————————————————————————————from————————————————————————————————
Public Class 硬件信息
Private Sub rsou_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim mikrotik As New MK_ROS(main.IP.Text)
If Not mikrotik.Login(main.user.Text, main.pass.Text) Then
mikrotik.Close()
Return
End If
mikrotik.Send(“/system/resource/print”, True)
mikrotik.Send(“=.proplist=uptime”, True)
For Each h As String In mikrotik.Read()
text1.Text &= h
Next
End Sub
End Class
why can’t get uptime value ? and text1.Text results “!trap=message=no such command prefix!done”
how can i to get the uptime value?thanks!i very need help!
print doesn’t work in api, you have to use getall:
"/system/resource/getall"
"=.proplist=uptime"
