HI.
Please help me on how to get/generate password with validity using vb6?
Thanks in advance ![]()
HI.
I don’t think you’ll get many takers. VB has been dead for well over a decade… if you want to use Visual Basic, switch to VB.NET. You can port samples easily from C# if you can find any.
el archivo adjunto es un ejemplo funcional de acceso a API desde vb6 compatible con ruteros 6.45.1
The attached file is a functional example of API access from vb6 compatible with routers 6.45.1
Saludos
MKT API Test 6451 ok.zip (13.1 KB)
Thank you very much…
