Vedios Cached in my web proxy ONLY youtube not !!??
Hi all
I have set and configured web proxy in my Mikrotik and its doing great , browsing , downloads and Videos are saved in the server and its all cached ..
I have only one problem , vedios in youtube and metacafe not caching .. i’v tried another videos in another web sites and all working very well .. only this youtibe and metacafe not ..
Can any one help in this
in the access list i have tried to add youtube and also tried without add youtube to allow in access list and both cases was same results .
here is my web proxy setting :
[admin@MikroTik] > ip web-proxy
[admin@MikroTik] ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 3128
hostname: “proxy”
transparent-proxy: yes
parent-proxy: 0.0.0.0:0
cache-administrator: “ahmed@gccitcom.com
max-object-size: 400000KiB
cache-drive: system
max-cache-size: unlimited
max-ram-cache-size: unlimited
status: running
reserved-for-cache: 29707264KiB
reserved-for-ram-cache: 2048KiB
[admin@MikroTik] ip web-proxy cache> print
0 ;;; Allow sado alahe
action=allow
1 url=“:cgi-bin \?” action=deny
2 url=“\.flv$” action=allow
3 url=“\.jpg$” action=allow
4 url=“\.gif$” action=allow
5 url=“\.exe$” action=allow
6 url=“\.zip$” action=allow
7 url=“\.jpg$” action=allow
8 url=“\.mpeg$” action=allow
9 url=“\.mp3$” action=allow
10 url=“\.avi$” action=allow
11 url=“\.pdf$” action=allow
12 url=“\.rar$” action=allow
13 url=“\.mov$” action=allow
14 url=“\.mpg$” action=allow
– [Q quit|D dump|down]
[admin@MikroTik] ip web-proxy access> print
0 url=“proxy” action=allow
1 src-address=10.5.50.253/32 action=allow
2 src-address=10.5.50.246/32 action=allow
3 src-address=10.5.50.252/32 action=allow
4 src-address=10.5.50.3/32 action=allow
5 url=“217.17.233.49” action=allow
6 url=“gov.tr” action=allow
7 ;;; block telnet & spam e-mail relaying
dst-port=23-25 action=deny
8 action=deny
Firewall setting :
[admin@MikroTik] ip firewall filter> print
0 chain=forward src-address=10.5.50.3 protocol=tcp dst-port=1863 action=accept
1 chain=forward src-address=10.5.50.253 protocol=tcp dst-port=1863 action=accept
2 X chain=forward src-address=10.5.50.0/24 dst-address=0.0.0.0/0 protocol=tcp p2p=all-p2p action=accept
3 chain=forward src-address=10.5.50.0/24 protocol=tcp dst-port=1863 action=reject reject-with=icmp-network-unreachable
[admin@MikroTik] ip firewall nat> print
0 chain=dstnat in-interface=ether2 protocol=tcp dst-port=80 action=redirect to-ports=3128
1 ;;; masquerade hotspot network
chain=srcnat action=masquerade
2 chain=dstnat dst-address=192.168.0.55 protocol=tcp dst-port=2007 action=dst-nat to-addresses=10.5.50.3 to-ports=4899
you can’t cache youtube.
Thanks for quiq replay , but why other vedios cached very well ? is it only youtube and metacafe can’t cached ? why ?
some of these video servers are designed differently
is there any other way to cache youtube or metacafe ?
see above
Hello, All
Pls can any help me out on this:
I have a system with mikrotik os 2.97 configure.
the system has 2network cards one for LAN and one for WAN
the LAN contain the following ip 192.168.0.1/24 and for the WAN is 81.199.232.178/29
i have set up hotspot, DHCP Server, i have a surc nat with surc add 192.168.0.0/24 with action masquerade for the LAN interface.
my question here is: How i can configure web-proxy for cache?
I want it to be on same hard disc on the OS.
And i want it to be in a way that no any additional configuration will be made for client to use the proxy?
Pls help me out
why don’t you upgrade to v3.30 or v4.1 first ?
