Vehicle Radios and Mesh
I have two towers serving as my backbone along an 8 mile track with several vehicles running along the track. All are set up as a mesh with single radios at 2.4Ghz (setup like here: http://wiki.mikrotik.com/wiki/Manual:Interface/HWMPplus except with dynamic wds). One problem is that sometimes the vehicles connect to the far tower directly at 1mbps instead of through the closer tower that has a 5mbps link to the far tower. How can I force the vehicle to connect through the better path?
Did you solved this problem?
wish to share your current result.
Thank you.
email also possible
smyeo(at)naver(dot)com
