Simple Queues are broken. It only shows static data, but all Rx / Tx / Totals do NOT accumulate (as before).
PS:
It would be nice if Simple Queues will remember your custom coloumn settings.
PS:
Some more info: Simple Queues did work in v3.10 on x86.
For the last 3 days, Simple Queues is working perfectly on a Routerboard 532.
It’s only on x86 giving a problem right from the start.
From changelog:
Code:
*) changed behavior of simple queues - queues with no limit and type default-small
and no children actually do not get installed, as if there was no queue;
Just change queue-type to default and everything will be fine.
Thank You macgaiver, your advice did the trick. I used the default queue and the problem went away.
I am not using x86 but I am having issues with the queuing, I am using rb450.
My config:
First I had the same problem as described in this thread and I change the default-type to default and it didn’t do anything. Then I changed the IP address from the “Target Address” to the “Dst. Address” and I started to get some results. But the only results I got was from the IP address that is on the bridge, I didn’t get any results from traffic that was being passed through the RB. I tried everything to get something to register for traffic that is passing through the RB… if I right click on the Queue and go to the torch tool it works… it reports the traffic.
Any suggestions?
/interface bridge settings set use-ip-firewall=yes
By default packets are not going trough the firewall if bridged
Are you using queue simple or queue tree
That worked, thanks… what version did that setting come about?
I am using simple queues.
Starting from version 3beta4
*) made ip firewall not be used for bridged packets by default;
