Verizon LTE USB Modem
I have a CRS 125 and I would like to add LTE.
Currently have an extra SIM on my Verizon plan in the US.
I was checking USB modems, so I can use as dongle, seems like the Huawei E8372 might not work in US.
Does anybody knows a good USB LTE Modem compatible with Verizon LTM that I could use on my MT box?
Dotty
The Verizon Pantech UML295 USB LTE modem should work just as soon as RouterOS v6.38rc14 is released. It used to work, but something broke after ROS v6.35.4.
See the thread…
http://forum.mikrotik.com/t/verizon-uml-295-support/65839/1
…for more info.
Best regards,
John
I should have been more explicit.
The Huawei E8372 I mentioned can be also used as WIFI hotspot, when not connected to the MT router.
This is what I want to do: Use the device as everyday hotspot for when I work outside the office, and then occasionally connect it to the MT so I can use it as demo for customers I would like to convince to add LTE on their own MT devices.
I like the USB form factor, but it can be also a Mobile Hotspot with battery, USB cable etc.
Thanks a lot.
