Very bad ping between 2 wireless devices on 951Ui-2HnD
Hi.
I have a 951Ui-2HnD, out of the box, fast config as ISP AP; just set a SSID up. Even not connected to our internet access.
It works fine. Gives an actual wireless LAN between devices, but with high latency: we can not have a ping between 2 (close) devices under 28 ms, that seems excessive for this configuration. And actually not suitable to VOIP.
Since we need the AP used mostly if not more as a private local VOIP gateway, I wonder if there is an easy set of configuration I could apply to fulfill our needs for low latency / good VOIP.
I have to confess I am not experimented in networking.
Thanks in advance if you can help me.
fxbodin
Bordeaux - France
